Godsbug Samba Member
Joined: April 29, 2006 Posts: 996 Location: Renton, WA
Posted: Sun May 14, 2006 7:15 pm Post subject: Carb fuel line question |
I have a PICT 34 carb on my 1600 DP. I was driving this morning and the fuel line that goes into the top of the carb came out and sprayed fuel everywhere. The thing is that the line was still attached the the brass piece that is part of the carb, but the brass piece came out of the carb itself. Has this happened to anyone else? I tapped it back in with a rubber mallet and it seems to be snug, but I'm concerned that it will happen again. Any thoughts, advice, suggestions? _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76948 Location: Sneaking up behind you
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Sun May 14, 2006 7:25 pm Post subject: |
try to ream out the end that goes into the carb a little bit and put a dab of locktite on it and tap it back in. should hold for a while. but since it came out once, you might want to use the wire method like in the pic above. |
Glenn Mr. 010
Posted: Sun May 14, 2006 7:26 pm Post subject: |
JB Weld will work also. _________________ Glenn
Member #1009
#BlueSquare |
KantDriveFast Samba Member
Joined: January 08, 2005 Posts: 4293 Location: Caldwell, Id.
Posted: Sun May 14, 2006 7:30 pm Post subject: |
Try any of the methods above, just do SOMETHING...you are VERY lucky you aren't staring at a new "charcoal" paint job!!! Most are not as fortunate. |
Posted: Sun May 14, 2006 7:33 pm Post subject: |
Thanks. Sorry to duplicate.
I couldn't figure out why the engine wasn't running right and parked the car (Leaving it running) and went back to investigate only to see a huge pool of gas expanding on the ground and a line of gas following me. I shut that thing down as fast as I could. It stripped the paint off my engine, but thank God that's all I lost. _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback
Glenn Mr. 010
Posted: Sun May 14, 2006 7:34 pm Post subject: |
All 3 wrote: |
Thanks. Sorry to duplicate. |
The search feature is your friend. And if that fails... ask. _________________ Glenn
Member #1009
#BlueSquare |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Sun May 14, 2006 8:11 pm Post subject: |
I have seen a recommendation to use a tight zip tie instead of a steel worm clamp, because the steel clamp absorbs heat and can cause it to loosen. I can't verify the claim, but it makes some sense. |
Posted: Sun May 14, 2006 8:30 pm Post subject: |
Standard zip ties loosen and tighten as heat rises and cools, but they don't necessarily shrink back to their previous size. Unless you buy aircraft grade. I would think that wire would be a better bet. _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback |
MedicTed Samba Member
Joined: August 12, 2005 Posts: 2110 Location: King of Prussia, PA
Posted: Mon May 15, 2006 4:51 am Post subject: |
KTPhil wrote: |
A steel clamp is not going to loosen enough from temperature expansion to cause a problem, UNLESS IT IS TOO LOOSE IN THE FIRST PLACE. Remeber that the line inside of the rubber hose is also going to expand. _________________ Ted Wojton
70 VW Bus Westfalia camper
2003 GMC Sierra |
Glenn Mr. 010
Posted: Mon May 15, 2006 6:05 am Post subject: |
The problem is not the clamp. It that the brass tube is one tapped into the carb and falls out with the hose still attached. _________________ Glenn
Member #1009
#BlueSquare |
KTPhil Samba Member
Posted: Mon May 15, 2006 9:12 am Post subject: |
The claim was not that the steel clamp loosesned with heat. It was that since the steel worm clamp absorbs heat, it then both hardens the rubber hose (increasing the likelilhood of cracking), and causes the carb fitting to heat up, allowing the brass tube to pull out more easily.
Tie wire is more work, but should work well.
How many burnt deck lids have you seen? Too many to count. I replaces hoses every year and didn't worry. Too much heat and smog in LA to take a chance. PITA for EFI--so many more hoses and connections. |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
