vwjoe Samba Member
Posted: Fri May 19, 2006 2:49 pm Post subject: Adding a 2nd alterator to my 69 bus, Any advice? |
I'm adding a 2nd alterator to my bus to run all my accessories. I have AC so I have an air compressour. If you go to Gallery up top and go under 68-79 Kombis, go to to page 37, 3rd picture down and this is what my motor looks like without the 2nd altenator. I know I will have to make my own bracket. Anyone have any advice before I get started?
*What alterator I should use? Atleast 110 amps.
*The smaller the better. In size.
*Any already made backets that I could modify?
*Have more pictures of this type of set up?
*Knows the guy who owns the bus in the picture?
Thanks for you time.
vwjoe |
steponmebbbboom Samba Member
Posted: Fri May 19, 2006 2:50 pm Post subject: |
What accessories are you running? List them. |
vwjoe Samba Member
Posted: Fri May 19, 2006 3:00 pm Post subject: |
PS2, Stereo= 12 speckers, 2 amps 1200 watts total, 17 inch flat screen, other lights, cell phone charger, lap top, and a few other things |
germansupplyscott Samba Member
Posted: Fri May 19, 2006 3:10 pm Post subject: |
look in the gallery, there are some photos of factory dual generator setups. _________________ SL |
Posted: Fri May 19, 2006 3:13 pm Post subject: |
vwjoe wrote: |
whyyyyyyyyyyyyyy |
casey79westfalia Samba Member
Posted: Fri May 19, 2006 4:15 pm Post subject: |
Dude are you serious. I hope you are living in there. _________________ 66 Westfalia
87 Westfalia Syncro "Phoenix"
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
Currently looking for 62 Double Cab, 66 Westfalia Parts!
(Rear seat and pedestal, bumpers, mirrors)
http://www.baycountrymotors.com
My 87 Syncro Westfalia 1.8t Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=418933
"Do it the right way, or you'll pay for it" |
vdubyah73 Samba Member
Joined: July 05, 2003 Posts: 2541 Location: somewhere in Texas, my house has wheels
Posted: Fri May 19, 2006 5:18 pm Post subject: |
Why not just find one big one say out of a police cruiser and make it work. We got a place here all they do is auto and marine electrics. You bring it in they rebuild it. Ask around and find a place like that and talk to them they may be able fix you up with an alternator that bolts rite up. Then if your 50 miles from nowhere you can fix it with the stock spare you're carrying in order to get back home. Remember the KISS principle. Keep it simple stupid!
No offense intended
Bill _________________ burning down the house
73 bounty hunter, sold.
'77 transporter, junked had crotch rot.
Dubless, but have a CPR built stroker waiting for a new to me Beetle
'93 Fleetwood Bounder 34' |
Posted: Fri May 19, 2006 6:15 pm Post subject: |
vwjoe wrote: |
Applying the KISS principle to make all this work is a contradiction. |
Duncwarw Samba Member
Posted: Fri May 19, 2006 6:20 pm Post subject: |
Assuming you're running a second (hopefully deep cycle) battery or two, there's not much wrong with the idea of running a second alternator, but I'd give serious thought to what you really need first.
For instance, DC-powered TVs generally won't even start at much below 12V. If you intend to run an inverter, they can be particular too. Then there's refridgerators...
Best to chart total draw of your devices, then buy appropriate batteries, THEN figure out if you need a second or third charging source.
No need to "put the cart before the horse".  _________________ “To find yourself, think for yourself”
Socrates, 470 BC - 399 BC |
typetwojim Samba Member
Posted: Fri May 19, 2006 7:31 pm Post subject: |
the pic on page 37 is a nice set up. very clean. but I would not do it quite like that. many years ago I mounted a second alt. on a baja bug. I put a metal plate under ther alt. pedistal. (4 bolts) and mounted the second alt to the plate. It worked well and the plate did not raise the hight of the doghouse very much at all.
jim
ps the air cleaner in that photo sucks |
i_want_a_pre_49_ratbeetle Samba Member
Joined: June 23, 2004 Posts: 442 Location: Martinsville Virginia
