panic_fan Samba Member
Joined: April 21, 2008 Posts: 711 Location: Mcdonough GA
Posted: Mon Feb 02, 2009 9:42 am Post subject: |
poptop tom wrote: |
May have to get on the lookout for some of these! I believe I still I have my brackets! |
This is the guy I bought them from. He had several sets, but I got them for $35 shipped to my front door! Good Luck _________________ Rich
Brilliant Blue/Cloud White
1970 Baywindow Bus
http://www.thesamba.com/vw/forum/viewtopic.php?t=291988&highlight=
"Still learnin the way around my VW bay"
topaz. Samba Member
Joined: October 13, 2008 Posts: 155 Location: Athens Greece
Posted: Sat Feb 21, 2009 8:23 am Post subject: Mud Flaps Mounting T2b |
To link to this post
Code: |
[url=https://www.thesamba.com/vw/forum/viewtopic.php?p=3622345#3622345]Mud Flaps Mounting T2b[/url] |
Hello to all.
This is how we mounted ours.
At first we had to collect everything to do the job right.
Then tightened the brackets and the flaps.
Next step we took the wheels off and marked to drill the holes.
Since we are still runing 1584cc we had to switch the brackets from left to right to work well, until we start runing a type IV engine.
Then tightened the bolts,however not enough so we could balance the flaps horizontally.
At last, after the balancing procedure we tightened the flaps and the brackets.
503Tim Samba Member
Posted: Sat Mar 06, 2010 10:36 am Post subject: |
can you tell us where you gathered all your parts from? |
chabanais Samba Member
Posted: Wed Aug 04, 2010 6:00 pm Post subject: |
I bought some too they have the brackets I'll post pics next week when they're on. Bought them from Central Texas Autowerks. _________________ "I spud therefore I yam." |
topaz. Samba Member
Posted: Wed Aug 25, 2010 6:14 pm Post subject: |
503Tim
I still have some brackets however I dont have any flaps left.
The type1 mud flaps might work. |
sibz Samba Member
Posted: Fri Apr 08, 2011 4:56 am Post subject: |
any clue for VW beetle mud flaps? |
Tomato Soup VW Samba Member
Joined: September 07, 2009 Posts: 20 Location: Central Texas
Posted: Wed Apr 27, 2011 6:52 pm Post subject: |
I have beetle ones as well with brackets (up to 73), or bus with brackets up to 72 |
sibz Samba Member
Posted: Thu Apr 28, 2011 12:06 am Post subject: |
anyone with 1966 beetle? |
Boesen Samba Member
Posted: Sat Jan 12, 2013 3:48 pm Post subject: |
I just received in the mail, the "Made in Venenzula" VW Emblem Mudflaps. Came without brackets, but have fabricated my own "late bay brackets" as shown here http://www.thesamba.com/vw/forum/viewtopic.php?t=3...b413f789a7
Went out to start the install earlier. Wanted to mount them behind rear wheels, already have a set of the blank ones up front. Seems to be that my side heat dump pipes (79-Westfalia)keep the angled bracket away from mounting on the engine carrier. Anyone else had this problem and if so a solution. I'm fine with having to fab up anything additional that may be needed. _________________ 1979 Westfalia Deluxe http://www.thesamba.com/vw/forum/viewtopic.php?t=474334&highlight=iowa |
Boesen Samba Member
chimneyfish Samba Member
Joined: July 28, 2009 Posts: 881 Location: United Kingdom
Posted: Mon Feb 24, 2014 8:04 pm Post subject: Mud Flaps T2 |
Can anyone advise or confirm to me if mud flaps part number 111 821 805 will fit our bays OK, and more importantly that they will look OK on a bay?
I bought these reproduction T2 mud flap brackets from Topaz (Eleny) last year.
They are fantastic, really well made, excellently priced, and loyal to the original dimensions and design. I fitted them to my bus as soon as they arrived.
However, I am running some T2 mud flaps with a moulded rubber Wolfsburg logo by VW's other OEM manufacturer of mud flaps Votex at the moment as a stop gap, which seemed to have been quite common as a VW aftermarket accessory here in the UK (they made them for the Beetle, T2, T3, Passat, Golf, regardless of the actual real factory location of vehicle manufacture, a bit like the Formula-Vee accessories). So I have them fitted whilst I have been hunting down a pair of WEGU flaps, as really want the VW logo.
I now might have the opportunity to get hold of some boxed NOS genuine WEGU flaps from the late 60s with the riveted (not moulded) VW logo.
The issue for me is that they are VW part number 111 821 805:
Ignore the brackets, I intend to keep using the T2 brackets I have already fitted from Topaz.
Refering to Ratwell on mud flap part numbers: http://www.ratwell.com/technical/Mudflaps.html
Ratwell wrote: |
The Genuine Article:
Genuine VW mud flaps have the VW logo stamped once or more and often are stamped WEGU by the German rubber manufacturer who made the mud flaps for VW.
They are part number 111 827 827 (beetle coded early style) or 271 821 821 (bus coded later style). The beetle variety often has the logo riveted on and the bus version has a logo that is molded into the rubber and painted white. There is a set of Genuine mud flaps without the logo and the part number is the same.
Genuine VW images:
I am concerned before that if I buy them, due to the different part number that I end up with the wrong flaps!
I found by searching on here that Everett discussed this part number in the Split Bus Forum, but they never seemed to get to the bottom of the multiple part numbers for so many similar mud flaps: http://www.thesamba.com/vw/forum/viewtopic.php?t=338759&view=previous
Any advice greatly appreciated before I go ahead and buy them. _________________ 1965 Type 1 Deluxe (1200cc)
1976 Type 2 T2b Microbus L (1800cc Type 4)
Previously...
1972 T2 Camper (Devon), 1988 Golf, 1972 Type 1, 1984 Polo, 1972 T2 Camper (Danbury) |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Feb 24, 2014 8:55 pm Post subject: |
The flaps look right but not the brackets, bug and bus use the same flap. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Hoody Samba Member
Posted: Mon Feb 24, 2014 10:23 pm Post subject: |
Those are the correct size mud flaps and yes they will fit just fine. The only issue is if you are a purist....the Bus mud flaps were not riveted. BTW good move by buying a set of brackets from Topaz. I will ad that the flaps Eleny posted pics of are too long. By 2 inches and as Richard stated many years ago. Yes they work....are they correct for the purist....no. The ones the guy in Cyprus or Turkey depending on when he changed his name are not NOS nor correct. But they are cheap. I have NOS Venezuelan mud flaps and Nos German Wegus. Lots of things that are different. But for most people 20 bucks from Turkey or Cyprus for re popped mud flaps probably stamped elsewhere does not matter. As Bus Daddy stated the length of the flap top to bottom is the same for a Bus and a Bug. Otherwise you are going to scrape them. |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Tue Feb 25, 2014 8:26 am Post subject: |
Does anyone have those YOM flaps? I got a set and might put them on today. These say 1969 on them, pretty cool imo.
_________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
Posted: Tue Feb 25, 2014 12:04 pm Post subject: |
Thanks for the replies, greatly appreciated. I will let you know how I get on. The different part numbers are making more sense now.
The repros mentioned are for sale from Istanbul in Turkey, and also Famagusta in Northern Cyprus (Turkish Republic side of the island). They are the closest looking repros I have seen, and I have considered them:
The only thing that gives them away as not being original, stamps aside and not up too close, is the lack of that texture that seems to define the genuine WEGU, and the gap between the bottom of the V and the top of the W seems slightly bigger than the rubber moulded ones pictured on Ratwell's site. They look however the right height compared to the Venezuelan ones. _________________ 1965 Type 1 Deluxe (1200cc)
Previously...
