Daddybus Samba Member
Posted: Sat May 27, 2006 3:09 pm Post subject: gas guage adjustment |
Is there any way to adjust/recalibrate a 12v gas guage? I haave a '67 bus with a fatchick 15 gallon tank. The guage doesn't read full when the tank is full, so when it is on "R" if has more than 1.5 gallons left. |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Sat May 27, 2006 3:48 pm Post subject: |
Do you have the fatchick sender in the tank or the 67 sender. The later sender is a couple inchs longer then the early sender _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
mintonman Samba Member
Joined: October 20, 2003 Posts: 4245 Location: between Trenton NJ. & Philly Pa.
Posted: Sat May 27, 2006 5:08 pm Post subject: |
If the sender has an arm with a floaty thing on the end, you can bend the arm to adjust it, but if you have the tube type you're S.O.L. _________________ Hoockd on fonicks werkt for mee?
under the influance "DUH" |
Posted: Sat May 27, 2006 10:47 pm Post subject: gas guage adjustment |
I am running a fatchick tube sender. I was hoping that there was some adjustment dohiccus on the guage to calibrate it. |
Clara Samba Member
Posted: Sun May 28, 2006 6:09 am Post subject: |
I heard that there is a screw on the back of he guage that you can turn to adjust where the needle sits, but that was an unsubstantiated rumour and I never tried to do it. Seems every guage reads slightly differntly, too. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
