67_13Deluxe Samba Resident Alien
Joined: February 18, 2005 Posts: 912 Location: Salt Lake City, Utah
Posted: Sat May 27, 2006 7:02 pm Post subject: Lost electrical Power |
I was driving at 60 MPH when I felt a jerk in the car and then I lost all my power. I mean all my lights radio, everything electric. The car is a 65 beetle converted to 12 volt. what could have caused that? _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
56 Beetle - Wilbur. I found a lot of lipstick on this pig so far.
63 Beetle - Luna
66 13 window Bus - Tetanus
71 Bay Window - Lola. Totaled.
Jason C Samba Member
Joined: June 14, 2005 Posts: 1028 Location: Portland Oregon
Posted: Sat May 27, 2006 7:49 pm Post subject: |
Did you check your fuses? _________________ Throw me a bone here. All I wanted were
sharks with friggen laser beams attached to their heads.
64 Bug |
Mielke Samba Member
Joined: July 08, 2005 Posts: 475 Location: Sherwood Park, Alberta
Posted: Sat May 27, 2006 10:43 pm Post subject: |
I agree, check fuses. It was raining here tonight & I was driving my '66 with the wipers on. The motor is weak so it draws a lot of amps, popped the fuse & the car quit. Changed it & away I went.... _________________ Greg
1966 Canadian Standard Beetle
1967 Beetle |
Posted: Sun May 28, 2006 5:47 am Post subject: |
All fuses are good. none are blown at all. that was the first thing i checked. NOthing tiurns on in the car. Its like the electric is shot!! battery still has about 12.65 volts in it. _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
63 Beetle - Luna
71 Bay Window - Lola. Totaled. |
Posted: Sun May 28, 2006 9:30 am Post subject: |
Could this be a bad voltage regulator? i have one of those motorola regulators in there. The battery still has a full charge which says to me the alternator is working. _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
63 Beetle - Luna
Posted: Sun May 28, 2006 11:01 am Post subject: |
Here is the regulator. The back of it has some sort of glue shit. I have no idea what it is. Can anyone tell me about this thing?
[img]https://www.thesamba.com/vw/gallery/pix/278690.jpg
[/img]
[/img] _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
63 Beetle - Luna
Posted: Sun May 28, 2006 12:59 pm Post subject: |
Does the starter still work? Do you have an ohm meter or a test light to check for power at the fuse block? _________________ Throw me a bone here. All I wanted were
64 Bug |
Posted: Sun May 28, 2006 1:55 pm Post subject: |
Jason C wrote: |
Does the starter still work? Do you have an ohm meter or a test light to check for power at the fuse block? |
I pulled out the volt meter and got nothing coming out at the fuse block. when i turn the key, nothing happens, the speedo lights dont even come on. _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
63 Beetle - Luna
Posted: Sun May 28, 2006 2:38 pm Post subject: |
OK fixed it. Chalk this one up to "dumb things previouse owners do" I found the wire that goes from the starter to the alternator basically sitting on the heaterbox. it melted right though and broke in half. so I did what should have been done in the first place and routed the wire where it should be after i replaced it. Thanks for the help. _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
63 Beetle - Luna
Posted: Sun May 28, 2006 2:41 pm Post subject: |
Glad to hear you figured it out. _________________ Throw me a bone here. All I wanted were
64 Bug |
rooket Samba Member
Joined: March 22, 2004 Posts: 160 Location: SF Bay Area
Posted: Mon May 29, 2006 1:22 pm Post subject: |
Exactly the same thing happened to me, I had to replace the ignition switch in my case. Entire car went dead when I was driving up to an overpass. _________________ -Dennis |
