2bugtony Samba Member
Joined: July 02, 2005 Posts: 345 Location: Sherman Wv
Posted: Wed May 31, 2006 5:05 am Post subject: fireing breaking down when car get hot |
Hello all
It has been hot here in WV the last few days. I took the fastback out the other day and after the car had been on the interstate about a half hour it started to missing like the fire was beaking down or something. The engine was overhauled stock just a few months back everthing is stock but over the top headers. I had drove the car in cooler weather and no problems at all. Any Ideas
Thanks |
69sqbck Samba Member
Joined: August 12, 2004 Posts: 311 Location: Savannah, GA
Posted: Wed May 31, 2006 8:24 am Post subject: hot |
Check to make sure that the timing, valves, spark plugs, points, etc.. are all set up correctly. This is usually overlooked and will make a huge difference in how the car runs when the temperature gets hotter. _________________ Don't think of yourself as an ugly person, think of yourself as a good looking Monkey!!!!!
1968 Ghia Vert
1969 Type 3 Squareback
1969 Type 3 Fastback
(o)\|/(o) Sole Designs, VW Restorations, Savannah, GA |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed May 31, 2006 10:31 am Post subject: |
Does it have a newer Blue Bosch coil?? They are known to crap out when they get hot. If so, try just putting a stock old black Bosch coil on and try it. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Wed May 31, 2006 11:29 am Post subject: |
It does have a blue coil. I will try a black one and let you know.
Thanks |
