Help - late transmission into '57 Oval
Page: Previous  1, 2, 3
sufidancer
sufidancer is offline
PostPosted: Thu Feb 14, 2019 8:12 pm    Post subject: Re: Help - late transmission into '57 Oval Reply with quote
I have a line on 67 trans with axles,starter,drums. 300 bucks and a 5 hr road trip. Getting cold feet after reading about dimples and the trans sitting slanted once completed. How do you like your modification? How's the old girl getting about?
I was thinking of the future,being able to put in more modern smoother trans and a 200mm fly wheel,12v and few more ponies all without having to grind the old split case bell housing or making any permanent mods is my reasoning. And save the old trans,and 6v gen for when I win the lottery to rebuild . Thanks for the response.
tmdenis
tmdenis is offline
PostPosted: Thu Feb 18, 2021 11:37 pm    Post subject: Reply with quote
IN2RUST wrote:
They make an adaptor for this infact. You can buy it at a reputable volkswagen shop, they should have one. What it is, is a solid mount adaptor that bolts to the frame and to the transmission. Very easy and is about 20.00. Your shift linkage should line up fine after that....Hope this helps you. I bought one at bugformance in sacramento. phone # 916-929-4320
Hello, I found this thread and I have a questions regarding the adaptor. Using this adaptor? Do I have to change the nose cone & hockey stick to the bus type or canI need to use the beetle nose cone & hockey stick for my 54 bug project.
Kjell Roar
Kjell Roar is offline
PostPosted: Fri Jul 23, 2021 12:21 am    Post subject: Re: Help - late transmission into '57 Oval Reply with quote
One information, if you are running a 36hp engine, and changing the trans to a newer full synchro one, you need a 1500 box to get equal rpms as the original splitcase gearbox.
Its because the 36hp runs on lower rpms (max power @ 3400rpms / 108kmh/68mph) than the 40hp (3800rpms/115kmh/72mph).
Max power = @ cruising speed.
I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
RandyV
RandyV is offline
PostPosted: Fri Jul 23, 2021 6:37 am    Post subject: Re: Help - late transmission into '57 Oval Reply with quote
sufidancer -- I wouldn't worry about it. Dimples could easily be tapped back down if you even cared to. (THat spot in the luggage tray is pretty obscure & unless you're going full show or pulling carpets out to show somebody sheet metal I can't imagine anybody would care) I've been driving mine for a few months now and didn't even know about this until I saw this thread a month ago. All good, imho! (BTW, I also wouldn't worry about grinding bell housing either. Many a 200mm modded beetle have had to do it & definitely no ill effects. Just making room is all) Wink P.S. I remember my 5 speed trans back in the 90's dimpled my '63 as well, in fact I even hammered a bit when I realized why I couldn't get the trans to go all the way in)
tmdenis --- I believe you do *have* to use the bus nose cone & hockey stick. (Somebody correct me if I'm wrong)
Roar ----- Nice to see those #'s. Though I always feel like my 1200 cruises best at about 63mph. 70+ feels like it's revving out so I keep it under 70. (stock 1200 w/ stock syncro trans @ 4.12 r&p with 205/65-15 rears)
Peter - Belgium
Peter - Belgium is offline
PostPosted: Tue Jan 04, 2022 2:16 am    Post subject: Re: Help - late transmission into '57 Oval Reply with quote
Hello all,
I have done this mod as well using the splitscreen nosecone and hockeystick to get a later tunnel gearbox in my 57oval.
I also had to do some little massaging of the metal to clear the nosecone, other than that is was a straight fit to get the gearbox in.
What I'm not reading in any of the posts (or I missed it) is that:
1/ It seems to place the engine a bit more (around 1cm) towards the rear?
2/ Also slightly higher?
I'm using an original cradle at the end of the gearbox, but the 4 bolts to fix those 2 rubbers on the cradle are really at the far end of the slots versus more centered? No freedom there anymore (and I do tighten everything at the nose cone first before tightening the rears).
I also see about a 2cm gap between the firewall and the front engine tin.
The slots for the horizontal rubberseal are bit lower versus the engine tin, so the seal is not well centered here?
Also the rear tin is not fitting at all, I had to modify by cutting off quiet some material before it would even be possible to install?
I did read somewhere about differences in gearbox/engine angle placement between different chassis (one being horizontal, others under a slight slope). Would that be the case here as well?
Note: the engine is a 1600cc with a DynoMax so can not judge on how the tailpipes sit versus the rear apron, but my gutt feel is they would sit pretty close together / touching?
Thanks!
Peter
356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight=
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Tue Jan 04, 2022 10:22 am    Post subject: Re: Help - late transmission into '57 Oval Reply with quote
Peter - Belgium wrote:
Hello all,
Thanks!
Peter
Hey Peter,
2 items pop into my mind immediately. Has the Bug been in an accident? It may have shifted the body a bit. The other is the rear mounting plate, at the transmission. I believe that these can be installed backwards and cause your exact description of problems. Got any pictures?
Jimbo
TDCTDI wrote:
67rustavenger wrote:
Peter - Belgium
PostPosted: Wed Jan 05, 2022 8:28 am    Post subject: Re: Help - late transmission into '57 Oval Reply with quote
VW_Jimbo wrote:
Hey Peter,
Thanks for the reply! that cradle should be the right way, will try to take some pics when the beetle gets back on the lift.
But even if backwards, dont think it would not explain why the overall assembly seems to be slightly further to the back / bit higher?
Thanks!
Page 3 of 3
