vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Sun Jun 04, 2006 7:32 pm Post subject: 3.88 Ring & Pinion gear |
Are the new Brazilian 3.875 R/P gears that are being sold for $110 as good as an original 3.88 out of a late tranny for a 12 second drag car? Or would I be better off tearing apart a few trannys until I find a good used one? _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Sun Jun 04, 2006 7:34 pm Post subject: |
I can't say about the Brazilian ones, but it's hard to beat a German Klinkenberg r/p. _________________ Glenn
Member #1009
#BlueSquare |
Alan_U Samba Member
Joined: July 10, 2004 Posts: 1762 Location: Vancouver, BC Canada
Posted: Sun Jun 04, 2006 10:31 pm Post subject: |
I'd go with a used klink or ottinger. A 3.88 Glieson will be even strong in the 3.88 r/p realm for a 12 second drag car. In time they will all fracture.
Call up a reputable tranny builder and ask. That'd be good info to know. _________________ 11.92sec pump gas true daily driver. Who says it cant be done.
No more time for VW's....... |
HBRag Samba Member
Joined: April 29, 2005 Posts: 735 Location: Huntington Beach, CA
What about nitrating the Brazilian gear? |
nsracing Samba Member
Posted: Mon Jun 05, 2006 5:31 am Post subject: |
I do not bother with the Brazilians. There are plenty of stock German 3.88 around. I stash a few of them... 20 sets or so I have taken out of late cases. Let me know if you still need them.
You need 3.78 mainshaft too?
I do not know of anyone running Brazilian Ring/Pinions in this neck of the woods.
The German stocks are hard to beat. |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Mon Jun 05, 2006 8:13 am Post subject: |
The Brazilian ones are somewhat brittle and will break fairly quickly in drag race use, although they're OK for lower horsepower road race use. The 3.88G has proven more reliable than the 3.88K for drag racing (although I would certainly agree that the 4.37K is much stronger than the 4.37G). |
Posted: Mon Jun 05, 2006 3:04 pm Post subject: |
The bad one has a G831 on it . Is that the Glieson?
Thanks for your help. I'm still learning about tranny internals. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Mielke Samba Member
Joined: July 08, 2005 Posts: 475 Location: Sherwood Park, Alberta
Posted: Mon Jun 05, 2006 5:48 pm Post subject: |
What trannies tended to have 3.88? I would like a set myself. I have a 73 IRS manual from a standard beetle & a '65 swing axle tranny. Is there a way, with out tearing them apart, to tell if any of them had a 3.88 that I could use in my '66? Is it even possible to put the 3.88 r&P from a later swing axle into an IRS? I am assuming this is a huge jobe regardless? _________________ Greg
1966 Canadian Standard Beetle
1967 Beetle |
Glenn Mr. 010
Posted: Mon Jun 05, 2006 6:34 pm Post subject: |
Late SSC trannys have them. _________________ Glenn
Member #1009
#BlueSquare |
Bruce Samba Member
Posted: Tue Jun 06, 2006 12:45 am Post subject: |
vwracerdave wrote: |
NO, you have it backwards. The G831 is the absolute strongest Type 1 R&P ever made. |
