65Westy Samba Member
Joined: February 15, 2005 Posts: 219 Location: Central Ohio
Posted: Tue Jun 20, 2006 8:20 am Post subject: Idler arm bushing |
How difficult a job is it to replace the idler arm bushing on a 1971 Super Beetle?
You guys (and gals) are the greatest. I have yet to post a question that somebody doesn't have an answer for.
Thanks,
Craig
1963 Beetle
1971 Super Beetle convertible
1960 Beetle |
abranz Samba Member
Joined: August 15, 2005 Posts: 116 Location: Osburn, Idaho
Posted: Tue Jun 20, 2006 10:50 am Post subject: |
Not bad. I used a press. I drilled the housing and the new bushing. Then installed a greese fitting so I can greese the assembly during oil changes. Works well, my 73 has no steering wheel shake/shimmy.
Anthony |
Dazed42 Samba Member
Joined: May 01, 2004 Posts: 1148 Location: Copperas Cove, Tx
Posted: Tue Jun 20, 2006 12:31 pm Post subject: |
Pretty easy, if you have a c clamp you can press the bushing out with it and some sockets. _________________ Proud owner of a super fatty.
Do you love the KAC?
www.dallasaircoolers.com |
Posted: Tue Jun 20, 2006 2:08 pm Post subject: |
Do you take out the whole thing by unbolting the 3 bolts thru the right side fenderwell?
Thanks,
Craig
63 Beetle
60 Beetle |
Posted: Tue Jun 20, 2006 3:25 pm Post subject: |
63bug wrote: |
Thanks,
Craig
63 Beetle
60 Beetle |
Yeah, first take off the cotter pin/castle nut then the three bolts then the nut on teh arm shaft pull it out press the bushing out press the new one(brass hopefully) grease it up put the arm back in then put everything back together. I don't think I missed anything. _________________ Proud owner of a super fatty.
Posted: Tue Jun 20, 2006 6:06 pm Post subject: |
Sounds easy enough. Hope to tackle it in the next couple of days.
Thanks,
Craig
1963 Beetle
1960 Beetle |
