RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Fri Jul 07, 2006 6:22 pm Post subject: |
Here's the motor in my '54 sunroof. It is just about 100% correct except for the color of the distributor cap. If anyone sees something incorrect, please point them out & I'll rectify the problem.
_________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Wiggy Samba Member
Joined: April 17, 2003 Posts: 6601 Location: Downingtown, PA
Posted: Fri Jul 07, 2006 6:37 pm Post subject: |
RareAir wrote: |
Whats the deal with the tarboard in the corner? _________________ Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval |
vdubinit Samba Member
Joined: July 11, 2005 Posts: 1870 Location: central coast
Posted: Fri Jul 07, 2006 7:57 pm Post subject: |
oldoval wrote: |
Just a little question, The add says that the engine for sale LOOKS like this one. The photos are not of the one for sale. Get some of the one for sale before you buy it, It may be even more incorrect. Just my 2 cents OLDOVAL |
Thats because i bought the 54 motor he "had" for sale _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
Posted: Fri Jul 07, 2006 9:23 pm Post subject: |
2splits wrote: |
Whats the deal with the tarboard in the corner? |
Jeez Kevin, you had me thinking there for a moment. There is no tarboard on the side panels, just on the firewall. What you see there is a reflection due to the curvature of the metal.
Here's a shot from the other side. See, no tar board.
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Fri Jul 07, 2006 10:52 pm Post subject: |
Your ignition coil strap should not be painted Glenn. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Fri Jul 07, 2006 10:59 pm Post subject: |
and your generator nut should be. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Fri Jul 07, 2006 11:12 pm Post subject: |
53 0val wrote: |
and your generator nut should be. |
OH got caught slippin _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
RickC Samba Member
Joined: August 04, 2001 Posts: 125 Location: Monterey County, CA
Posted: Sat Jul 08, 2006 10:59 pm Post subject: |
Here's a '54 engine in a 216. Worked a bit to get it correct. Guess I gotta paint the generator nut this weekend. Thanks for the tip.
_________________ Rick Clark in Monterey County, CA USA
... where the surf is happening and the lightweights are standing on the beach, checkin' it out... |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Posted: Sat Jul 08, 2006 11:07 pm Post subject: |
RareAir wrote: |
It looks like the wrong regulator to me. Look how it mounts and compare that with Rick's round regulator.
I think you have the wrong carburetor too. A '54 should not have a 28 PCI that says "28 PCI" on the side. I'm not 100% sure on that due to the angles of your photos.
I think the coil strap should be mounted with bolts, not screws? _________________ How to Post Photos
Posted: Sun Jul 09, 2006 12:18 am Post subject: |
EverettB wrote: |
I think the coil strap should be mounted with bolts, not screws? |
Damn!, Everette- good eye. It's a Porsche 356 12v generator. The regulator was a square version, so I trimed off the square cover & slid on a round regulator over the square innards.
I'll switch out the engine tin screws w/ 10mm bolts after I replace the coil bracket. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Buggeroff Argumentative Bastard
Joined: October 16, 2004 Posts: 1124 Location: Lake of the Ozarks, Missouri
Posted: Sun Jul 09, 2006 7:18 am Post subject: |
While we are being picky, why are the "Bosch" decals on the coil upside down ?
I mean, all the coils on all the air cooled's are inverted, you'd think they'd get the fucking sticker so's you could read it without slipping a disc !
Chris. _________________ "Chris of the Ozarks"
Headlinerless 57 Ghia
Thread deleter extrordinaire. |
Posted: Sun Jul 09, 2006 8:16 am Post subject: |
crtclff wrote: |
While we are being picky, why are the "Bosch" decals on the coil upside down? |
The decal is upside down when mounted on a car. When the coils where on the dealer shelves, the decal would read Rght-side-up _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Sun Jul 09, 2006 9:45 am Post subject: |
crtclff wrote: |
Chris. |
We're not being picky.......Glenn asked for it.......so he's getting it. Correctness is a Science. Just like your comment on the sticker, you learned something today. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Sun Jul 09, 2006 12:02 pm Post subject: |
RickC wrote: |
is there anyway for the intake manifold heatrisers not to get paint burned _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
RickC Samba Member
Posted: Sun Jul 09, 2006 12:07 pm Post subject: |
Try covering the intake with high heat ceramic coating inside and out OR block the opening in the heat riser. _________________ Rick Clark in Monterey County, CA USA
Posted: Sun Jul 09, 2006 3:16 pm Post subject: |
vdubinit wrote: |
is there anyway for the intake manifold heatrisers not to get paint burned |
The heat riser on the #2 cylinder side gets hotter due to the fact the manifold attaches directly to the exhaust side of the head. The #4 side has a pipe that runs up to the heat riser & has time to cool down a little before entering the riser so heat doesn't affect it as much. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Greg Armendariz Samba Member
Posted: Thu Aug 10, 2006 4:15 pm Post subject: |
a 54' Engine Complete |
Posted: Thu Aug 10, 2006 4:36 pm Post subject: |
EverettB wrote: |
Greg Armendariz wrote: |
Nice!
I'd add one more thing before starting it up though. |
And paint the generator nut while your at it. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
