Chrisisw Samba Member
Joined: May 30, 2004 Posts: 148 Location: Amsterdam, Holland, Europe
Posted: Fri Sep 08, 2017 9:06 am Post subject: Re: 1954 & 1955 engines whats not correct! |
Thank you, then I know what to do. |
Posted: Thu Sep 28, 2017 10:30 am Post subject: Re: 1954 & 1955 engines whats not correct! |
One additional question. I just received a new Fuel line from my fuel pump to my carburetor, however, this is copper colored. Is this correct? should this not be silver colored? If so, any suggestions where I can get the correct fuel line?
Thanks again, Chris |
D-train Samba Member
Posted: Thu Sep 28, 2017 3:16 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
Pick away... I know it’s not a screw Terminal oil pressure switch.. _________________ shiny paint doesnt make it worth any more |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Thu Sep 28, 2017 4:12 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
Chrisisw wrote: |
Use a magnet. It should be copper coated steel. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Posted: Thu Sep 28, 2017 4:46 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
D-train wrote: |
Pick away... I know it’s not a screw Terminal oil pressure switch.. |
I think this engine is late '55 but still the 1955 model year (before August)?
It has a '54 fuel pump. 55s don't have the screw in the bottom half, just a boss there with no screw.
Mid-late '55s have the oil filler with the cap
Nice find on the thumbscrew air cleaner!
Nice spring clip distributor too
Wrong exhaust but I'd run it. _________________ How to Post Photos
mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5001 Location: Nor Cal 707
Posted: Thu Sep 28, 2017 4:52 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
EverettB wrote: |
D-train wrote: |
Wrong exhaust but I'd run it. |
Along those lines. If you want to ditch that exhaust, let me know. I have the perfect car for it. |
Posted: Thu Sep 28, 2017 6:50 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
EverettB wrote: |
D-train wrote: |
No screw hole for the later oil filler, so it’s the correct one. The dizzy, fuel pump (wavy top) came with it when I got it from dry storage. Took an hour to seperate the top and bottom on the fuel pump so I’m guessing it hadn’t ever been apart.
I have a couple of wire clip distributors too.
The exhaust is a 50s Aussie only lukey that I’ll repair and run, otherwise it would have a single tip on it.
OgCalLook Samba Member
Posted: Thu Sep 28, 2017 9:03 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
mr. warehouse wrote: |
EverettB wrote: |
D-train wrote: |
That exhaust is BadAss!! _________________ Tom
Barndoor Mafia wrote: |
VIVE LE CUÑADO WEAR !!!!!!!! |
http://www.thesamba.com/vw/forum/viewtopic.php?t=306079 |
FRK Samba Member
Joined: December 09, 2002 Posts: 2652 Location: Orange county, CA
Posted: Thu Sep 28, 2017 10:06 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
'55 shortblock done.
_________________ 64 Ghia
55 Kab
50 11G
50 11A
49 11
48 11
RVA Car Club
FRK Samba Member
Posted: Thu Sep 28, 2017 10:13 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
D-train wrote: |
EverettB wrote: |
D-train wrote: |
For general reference, -20-1081288 is June, 1955
Cool, thanks for the info that it's not drilled, I was wondering when that started and though it was earlier in 1955.
Is the generator/regulator/coil/etc. all dated around 6/55? _________________ How to Post Photos
Posted: Thu Sep 28, 2017 11:36 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
EverettB wrote: |
D-train wrote: |
EverettB wrote: |
D-train wrote: |
Is the generator/regulator/coil/etc. all dated around 6/55? |
I’ll check it all out for you ev. All the bits that are on it came with it. I know it’s a bit earlier than the bus it’s going in but it was complete an good. _________________ shiny paint doesnt make it worth any more |
Posted: Fri Sep 29, 2017 3:05 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
EverettB wrote: |
D-train wrote: |
Sorry sir, won’t ever sell this one. _________________ shiny paint doesnt make it worth any more |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Sat Sep 30, 2017 10:51 am Post subject: Re: 1954 & 1955 engines whats not correct! |
I believe that 55 calendar year progressed thru at least three types of fuel pump bottoms. '55 Started with a screw on the bottom, then screw boss without the port being machined and eventually the base with no screw provision in the casting by approximately the time the 56 model year started. I really don't think it's so simple as to say "All 55s should have the screw boss casting, but not machined". The 55 model year was all about progressive refinement and change
Mid 55 fuelpump with the non machined screw casting is one of the rarest fuel pumps around, I believe it was likely only made for a few months at most. _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Posted: Sat Sep 30, 2017 12:19 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
D-train wrote: |
Looks like a 25hp crank pulley. |
Posted: Sat Sep 30, 2017 1:04 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
3foldfolly wrote: |
D-train wrote: |
Yes it’s a thin lip pulley, with a nos 3 piece gen pulley (kept the original one still), and also has the finger on the front crank tinware. I have tried to find if they are correct, but in Australia, we got all sorts of mismatching things compared to other countries.
Considering Australia only started getting vws in 54, so any 25hp in this country is hens teeth if you could could ever find one. But I’ve had a few finger crank tinware and thinlip pulleys in my collection. _________________ shiny paint doesnt make it worth any more |
Posted: Sat Sep 30, 2017 1:17 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
3foldfolly wrote: |
edit: you're right _________________ https://instagram.com/mr.ogpaint
Patrick Hall
Posted: Sat Sep 30, 2017 5:01 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
Mr. OGPaint wrote: |
3foldfolly wrote: |
25hp pulley is smooth not ribbed |
That's a 25 hp pulley. |
Posted: Sat Sep 30, 2017 5:41 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
Mid 55 fuelpump with the non machined screw casting is one of the rarest fuel pumps around, I believe it was likely only made for a few months at most. |
Yes, I totally agree with you it's not that clear, I think early 55s - Jan/Feb/maybe slightly longer still had the screw.
My text above was confusing as I thought he had a late 1955 engine but after searching the site a bit for past posts, I'm not absolutely 100% sure he would have the boss only for a June engine.
The "56" style pump wasn't brought in until 15 Feb. 1956 as I believe this is the change in Progressive Refinements:
I know earlier in this thread I posted this 54 vs. 55 pump question as I couldn't find a reference to this in Progressive Refinements. A few members listed some engines they had with and without the screws and the fuel pump serial #s. Page 13. _________________ How to Post Photos
Posted: Sat Sep 30, 2017 7:04 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
3foldfolly wrote: |
3foldfolly wrote: |
https://www.thesamba.com/vw/forum/viewtopic.php?t=145323
That’s another thread on pulleys.
As I’ve mentioned, Australia had random parts used throughout the years also, so hard to clarify what’s correct. All the feedback is grey thoz _________________ shiny paint doesnt make it worth any more |
