gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Mon May 11, 2020 5:28 am Post subject: Re: 1954 & 1955 engines whats not correct! |
D-train wrote: |
Out of curiosity, what’s the underside of the oil bath look like? |
Here ya go!
_________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
D-train Samba Member
Posted: Mon May 11, 2020 12:50 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
gatorwyatt wrote: |
D-train wrote: |
Here ya go!
Epic!!
When did they stop using the round pressing and go to the other pressing I wonder.. _________________ shiny paint doesnt make it worth any more |
janerick3 Samba Member
Posted: Tue May 12, 2020 4:03 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
56samba wrote: |
gatorwyatt wrote: |
Actually... I believe that is a early 55 finger tin. Not even a 54’. There is provisions for only 2 sheet metal screws on the finger side and not three. Three screws are in 54’. |
Here’s some pics of the tin that Todd is referring to. I believe these were used from around October 54 to early 55? Guess they were introduced when they changed from 3 to 2 bolts per shoe box.
The change from three to two screws on each side took place between Dec 1954 and Jan 1955 (somewhere between engine # 922579 and 960717). _________________ Thanks,
Jan K. |
Posted: Tue May 12, 2020 4:29 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
janerick3 wrote: |
56samba wrote: |
gatorwyatt wrote: |
The change from three to two screws on each side took place between Dec 1954 and Jan 1955 (somewhere between engine # 922579 and 960717). |
Thank you for confirming as that is similar to the time frame I came up with. _________________ www.blastserv.com
wanted:
56samba Samba Member
Posted: Wed Jun 10, 2020 1:37 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
Found another rare and yet so unimportant detail on an engine that I’m currently working on. It really seems like they used a lot of early parts up to the around 1-2/55 and modified them to work along with later parts that were introduced in this period.
Late 54 to early 55 shoe box features three holes in the tin but only two threads to bolt the cylinder tin to the shoe box- you will not see this when everything is in place.
Jan
3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Posted: Fri Jul 31, 2020 8:37 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
I recently switched back to my original distributor VJU 4 BR 3T from the 010 I had been using. This distributor was original with the dished top pistons 6.1 compression. Does anyone know what the the timing and jetting should be when running this dist with flat top pistons? I swear I saw a chart on here somewhere but cant find it. |
Posted: Fri Jul 31, 2020 10:38 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
3foldfolly wrote: |
Found this for the timing. Looks like 2.5° BTDC with today's cheap gas. Still not sure about jetting.
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Sat Aug 01, 2020 8:39 am Post subject: Re: 1954 & 1955 engines whats not correct! |
EverettB wrote: |
Is your cheap gas below 80? Ours is 87. |
I think ours probably is too. It's been so long since I've been to a gas pump. I know there are two different ways to measure octane, not sure which method was used for this chart. I'm going to set it at 5°BTDC and see how it does. |
Posted: Sat Aug 01, 2020 8:52 am Post subject: Re: 1954 & 1955 engines whats not correct! |
3foldfolly wrote: |
EverettB wrote: |
I was wondering if it's the other rating system too.
If it is, the 80 would be even lower for the USA.
For example, their "91" octane is our 87 octane. _________________ How to Post Photos
Posted: Sat Aug 01, 2020 7:06 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
Am I correct in assuming that the advance curve is different on the early 36hp distributors to correspond with the lower compression of the dished pistons? Did they dial back total advance with the introduction of the flat top pistons to avoid detonation and hotter cylinder head temps from the higher compression? |
Posted: Sat Aug 08, 2020 7:16 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
3foldfolly wrote: |
Just to follow up on this I found when my BR3T was static timed at 7.5 degrees BTC the total advance was 34-35 degrees BTC. When static timed at 5 degrees BTDC total advance was at 32 BTDC. I left it at 5 degrees BTDC and it runs perfect. |
the boss Samba Member
Posted: Thu Nov 05, 2020 11:09 am Post subject: Re: 1954 & 1955 engines whats not correct! |
Hello ,can anybody confirm me that the uterus manifold have to be painted in black please ? |
sweden Samba Member
Posted: Wed Dec 16, 2020 12:57 pm Post subject: Red aircleaner 1955 |
What years was the aircleaner red inside?
The red are stamped 55-2, 55-5, 55-6 and the black is 1957.
_________________ Me and my sons cars Typ1 -49 -50 -51 -52 -52 -53 -53 -54 -55 -55 -56 -56 -57 -58 cab -64 cab
T3 TriStar airride with Audi 1,8T engine and Porsche 996 gearbox. |
Tempie Samba Member
Posted: Fri Dec 18, 2020 3:00 am Post subject: Re: 1954 & 1955 engines whats not correct! |
My 12/54 Mann oil bath filter is also oxide red internally _________________ When a deluxe is not enough.... you go standard
Early 55 standard sunroof
Visit the Standard Split and Oval Beetle group!!
VW Standard Split and Oval Beetle |
bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Fri May 07, 2021 1:46 am Post subject: Re: 1954 & 1955 engines whats not correct! |
This is my July 55 bus motor. What is and isn’t correct please? I shan’t be offended by any advice 😊
I have a spare fan housing if I cannot straighten this one out. I assume it had aircon or similar given the extra brackets.
Cheers. Dave |
Posted: Fri May 07, 2021 6:17 am Post subject: Re: 1954 & 1955 engines whats not correct! |
Fuel pump, crank pulley, distributor (probably) and tinware appear correct.
What is wrong:
- oil filler
- carburetor (early 40hp)
- generator/pulley
- oil pressure switch
- missing ignition wire tube/clamps _________________ Thanks,
Jan K. |
bally Samba Member
Posted: Fri May 07, 2021 4:31 pm Post subject: Re: 1954 & 1955 engines whats not correct! |
Thanks 😊 |
consvws Samba Member
Joined: April 07, 2009 Posts: 950 Location: Roseburg, OR
Posted: Thu May 20, 2021 2:27 pm Post subject: Re: Coil bracket differences |
transportertalkman wrote: |
Any light to be shined on the different coil brackets. Both Bosch, one has notched ears where it mounts to the fan shroud. Also the same one only has a single hole on one side above the clamping screw
Any answers to the old offset slotted coil bracket question? I found one in my stash & curious what it's for. |
Posted: Thu May 20, 2021 11:16 pm Post subject: Re: Coil bracket differences |
consvws wrote: |
This should depend on the exact date when the coil and bracket were made but I can’t tell exactly, should check some of my coils. There are also other differences of the brackets to be noticed. 52-53 brackets were usually painted and they have six tiny holes looking similar to the ones on the bracket of the earlier TL6/1 coils. |
