NorCalWeekender Samba Member
Joined: April 13, 2000 Posts: 6531 Location: East Bay, CA
Posted: Wed Jun 28, 2006 10:27 am Post subject: Stock Exhaust Tail Pipe Clamp Issue |
Yeah, not the most slick thread title, but I finally bought myself a stock exhaust for the bus and connected it all up and I'm thrilled with how nice it sounds and clean it looks.
However, right where the tail pipe fits into the muffler itself...it appears as though the clamp supplied isn't sealing and I'm getting some exhaust blow-by there. There aren't any pieces missing from when I assembled it. I just want to see if anyone has any ideas on how to solve this. I might be able to shoot a picture later during lunch and get it up here.
-Taylor _________________ 9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995 |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Wed Jun 28, 2006 10:41 am Post subject: |
High heat silicon under the donut _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Type2meister Samba Member
Joined: July 19, 2002 Posts: 341 Location: Campbell River, BC
Posted: Wed Jun 28, 2006 10:43 am Post subject: |
I have found that brazing it with an oxy-acetylene torch is the easiest way to seal this up at the joint. If it needs to come off you can heat it up again with a torch and twist it off. I don't know if you have access to a torch setup, but it works great. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Wed Jun 28, 2006 11:00 am Post subject: |
Most clamp kits dont's have the correct donut in them, as you have found out. That donut is actually smaller than the other exhaust donuts.
So what do you do? A 40/36 hp donut is the correct size. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Wed Jun 28, 2006 11:08 am Post subject: |
Aha! Well, Crofty's answer sounds ideal! Sadly, I haven't access to a torch of any kind...unless you're British and then I have plenty.
Anyone have a 36/40hp donut? Plain, not creme filled. _________________ 9th Owner of a 1971 Tintop Westy
Posted: Wed Jun 28, 2006 11:14 am Post subject: |
http://www.thesamba.com/vw/classifieds/detail.php?id=267551
WW has them as well. _________________ Your Vanagon sucks, Stop waving at me.
Posted: Wed Jun 28, 2006 11:18 am Post subject: |
NorCalRiviera wrote: |
Anyone have a 36/40hp donut? Plain, not creme filled. |
If you bought the tailpipe install kit the correct donut is in that kit. The new resonater pipes are a little smaller diameter then original ones where they go into the muffler, _________________ Stocking distributor of "The Funky Green Panels"
Posted: Wed Jun 28, 2006 11:19 am Post subject: |
Brilliant, Sean! You're just a well of useful links today!
splitpile wrote: |
If you bought the tailpipe install kit the correct donut is in that kit. The new resonater pipes are a little smaller diameter than original ones where they go into the muffler. |
So you're saying I may have just put the wrong donut on? _________________ 9th Owner of a 1971 Tintop Westy
Posted: Wed Jun 28, 2006 11:37 am Post subject: |
splitpile wrote: |
If you bought the tailpipe install kit the correct donut is in that kit. The new resonater pipes are a little smaller diameter then original ones where they go into the muffler, |
The last time i bought an install kit I had to go through 4 of them just to find one that had the donut! _________________ Your Vanagon sucks, Stop waving at me.
Posted: Wed Jun 28, 2006 11:48 am Post subject: |
Lovely! I'll see about ordering up some 36/40s to be on the safe side. _________________ 9th Owner of a 1971 Tintop Westy
avocado_tom Samba Member
Joined: June 18, 2007 Posts: 235 Location: Pittsburgh, PA
Posted: Thu May 31, 2018 3:41 pm Post subject: |
crofty wrote: |
So what do you do? A 40/36 hp donut is the correct size. |
Could this be the reason that tailpipes sometimes blow out of the stock muffler with a new clamp installed?
Inquiring minds want to know... |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu May 31, 2018 4:56 pm Post subject: |
avocado_tom wrote: |
crofty wrote: |
The short, no.
Problem is the TP silencer when it is bent at the manufacture is not anywhere near a perfect circle, much more an oval which does not help.
Other problem is most folks seem to not know of the later 40HP and all 1500/1600 bracket on the left side of the muffler to hold the silencer. Without that and that the pipe is not shaped right, the dough nut seal is not going to hold well enough. _________________ In Stereo, Where Available! |
