FASTBACKDON The other insensitive jerk like Neil
Joined: October 08, 2004 Posts: 3592 Location: TORRANCE CALIF
Posted: Sat Apr 21, 2012 4:23 pm Post subject: |
Dfasty wrote: |
fastback don did them. I sold him the inner frames. |
Thanks again D _________________ FUCK CANCER FUCK CANCER FUCK CANCER!!
Mom 25 months of standing up to Cancer R.I.P I miss you so much.
Buy my best friends stuff
http://www.thesamba.com/vw/classifieds/search.php?username=56TIMOTEO
(21:10:42) Jennepher: Russell is our proudest achievment. I feel like Samba created him from a little nugget of crap into a full blown adult. |
sprintstar.com Samba Member
Posted: Sat Apr 21, 2012 5:25 pm Post subject: |
the seals are not left / right specific... installation instructions were lost on the iSP site when our forums were lost / server changed.... I have installed them myself and it did not seem that hard...
all original style window rubber follows the following rules
rubber onto glass, trim onto rubber, glass assembly into car...
the only thing different for fastback pop outs is the metal support frame goes into the rubber first, then the glass
the fastback rubber seal has a flap towards the inside, with the support frame & glass fitted to the rubber you will notice the frame studs poking at the seal, you will need to slice a hole or i call it a tit off the tip where the posts to mount the assembly to the body are wanting to poke thru the seal
once that step is completed, you can proceed to install the trim onto the window rubber
from there, install it to the car, last things to do are release any tension on the seal when it wants to roll under from pulling it in with the rope, install the molding trim fixed clip that joints the trim, then lastly install the 4 tension clips onto the rubber seal at the forward hinge points were the glass starts to bend open / where the inner frame starts
lastly hookup the popout latch, clean the window and enjoy
I hope this info helps.... |
66311 Samba Member
Joined: December 31, 2006 Posts: 1477 Location: Olive Branch MS
Posted: Sat Apr 21, 2012 5:28 pm Post subject: |
Brent wrote: |
Yes, the seals are L and R. I'm certain I'm using the right one as the profile wouldn't fit with the other.
The glass does need to go into the seal more. The corners are not molded, it's just a loop. It doesn't stay in place without holding it, it just pops out. I think if we could manage to somehow 'glue' that end in the seal it would work. Once is fit in the car the seal would get pushed into place.
I'm about ready to throw in the towel on these and just use stationary seals for now. Then I make an install appointment with ISP when I go down for the Classic. |
Before you throw in the towel. Call me or I can call you. I'll PM you.
ISP, OEM, Used. They are all like this. They are too cool and hearing all new sounds from the rear is worth it. |
66311 Samba Member
Posted: Sat Apr 21, 2012 6:22 pm Post subject: |
sprintstar.com wrote: |
the seals are not left / right specific... .... |
They better be or I am incredibly drunk. Please explain.
This is left.If it fits the right I cannot see how.
Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Posted: Sat Apr 21, 2012 9:52 pm Post subject: |
After reading the replies this afternoon I was encouraged to give it another go seeing as they have actually been installed successfully by DIY'ers.
Well, I got one side in! Trim, clips, nuts, and all. Fits really nice.
What I did different was pushed the glass as much and as hard as I could into the forward section of the seal. This left about a 3/4" gap at the back. From there, I stuffed a block between the end of the glass and seal/frame to hold it in tension and in place. While keeping pressure on the glass from popping out of the front, I worked in the trim. Then it's more or less a normal install, but you just need to be careful to get the studs from the frame in place.
I have the passenger side to do tomorrow. I'll take some pics of how I did it. _________________ 69 Fastback Build
Berg5 Build |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Sat Apr 21, 2012 11:13 pm Post subject: |
WhooHoo!!!
Just gotta hold yer mouth right! _________________ Bus Motor Build
What’s That Noise?!? |
Brent Samba Member
Posted: Sun Apr 22, 2012 12:37 pm Post subject: |
I have them both in now! I took a whole bunch of pictures. Hopefully this will help someone out in the future. If the first one takes four hours, the second will only take you two.
Here goes:
The seal is just a loop. There are two sections glued in that are about 2" long. These are for the U-shaped channel in the frame.
The shorter piece in between the two 2" pieces is for the forward part of the window.
Here's a shot of the U-channel that the frame goes into. Use some silicone spray and push it all the way in.
Now there are two flaps that need to go around the L shaped portion of the frame. One of the flaps has a rounded bump on the end of it. That one goes to where the center of the 'L' is and the other rounded one goes over top of that. The first picture here is a little fuzzy, but you can make out the round bump that goes on the inside.
Before you get it all worked around the corner, push in the other side of the U-shaped part.
And now the frame is completely in.
So now there are 4 bumps where the studs on the frame are. You need to cut a small slit on the inner side of the seal only to expose the stud. Don't cut through the outer flap.
Now to put the outside clips on. The rounded part faces toward the rear of the frame.
Get them started like this and use some silicone spray. These are hard to get on as the fit is very tight. But both of the rolled under clips need to grab the seal and slide over the 2" section.
And they're on.
Next start pushing the glass into the forward part of the seal. I didn't have to use very much of the spray here.
Once you get it situated, push hard in the forward direction from the rear of the glass to seat the two forward corners. There should be a pretty good gap at the rear when you get the front all tight in the channel.
Next, fit the trim into the groove on the outside of the seal. I did it a few inches at a time just using my thumb to pull back on the seal and let it fall into the trim. Be careful not to move the glass around too much and periodically push the glass into the forward part of the seal as before. This will take awhile, but when you're done it will be like this.
Now install the cord (or wire) that is used to pull the lip in place. I started here so that as I pulled the two forward corners would be the first to set in place. Again, careful not to move the glass around!
Poke some holes in the headliner material for the studs.
Get the window in place.
Press on the window while pulling the cord and get the lip around the window edge.
Now it's in place, but the studs are not really through the holes in the car.
It will take some pushing/pulling, but get the studs into the slots, adjust if needed, and put the nuts on. Might as well take out the seat and battery, because you will drop those nuts several times.
Now the inner clips go on. They grab the bottom of the seal and kind of snap into place against the top of the seal and glass.
Now just go around the seal and push it all into place to smooth it out and clean it up! Good luck, it's a pain, but CAN be done.
Berg5 Build |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Sun Apr 22, 2012 3:40 pm Post subject: |
Awesome, thanks for the pics and tips!
When I get my nut plates welded in, and a new headliner installed, I'll tackle my popouts. (I have a '71 so the holes are there but not the nutplates at the rear edges). |
Dfasty Samba Member
Joined: November 22, 2005 Posts: 528 Location: north bay,ca.
Posted: Mon Apr 23, 2012 8:18 am Post subject: |
great write up. now I know how to tackle mine. _________________ 70 fastback automatic 06 invader |
KIDSPEED Samba Member
Posted: Mon Apr 23, 2012 4:37 pm Post subject: |
Thanks Brent. You've done the community a great service with your instructions & pics. Car is turning out beautiful. Can't wait to see the whole thing finished. Your efforts & the results are truly inspiring.
-Laurence |
68vwfasty Samba Member
Joined: March 26, 2014 Posts: 277 Location: Portland, OR
Posted: Mon Aug 18, 2014 3:08 pm Post subject: |
I just finished installing my popouts and I wanted to thank Brent for his excellent step by step with pictures! He is right that is took about 4X as long to do the 1st window compared to the 2nd. I think that rule applies to almost ever step in a restoration.
I have a couple of recommendations to add.
1) I put the outside clips on after the glass. And I found that sliding them on is really tough. I put the edge closest to glass on first (just hooked it in) and then using a plastic trim tool I pushed the rubber on the bottom into the other hooked edge.
2) On the first window I used Silicone to put the glass in and I found that the glass moves around a lot and it is really difficult to get the front edge in and make it stay. And then I couldn't get the trim on. On the second one I did not use any Silicone and the rubber grabbed the glass and stayed in place. It was much easier. Do not use Silicone on the glass. |
T3man Samba Member
Joined: February 08, 2004 Posts: 163 Location: killeen tx
Posted: Sat Aug 13, 2016 1:44 pm Post subject: Re: Fastback Pop-out window seals |
I'm catching hell putting mine in! Clips and trim Bee ach! _________________ 1962 Blue notchback n model
1964 White Variant S Type 3 Squareback Euro
1966 Blue sunroof fastback
1969 Bahama Yellow camper bus
2170 Silver Alien space ship. Leaks Nuclear waste! |
Hooked Samba Member
Joined: October 09, 2013 Posts: 4 Location: Fair Oaks, CA
Posted: Sat Sep 03, 2016 9:10 am Post subject: Re: Fastback Pop-out window seals |
Just finished that, wow that might have been the most difficult part of the resto that i have come across. I agree don't use silicone spray. I feel most of my issues were related to the new trim not being bent to the proper curves, the trim really is what holds the seal to its final shape. i would have been better off using my OG trim. They are in so i am moving on. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Tue Jun 08, 2021 6:11 pm Post subject: |
Brent wrote: |
Nice writeup Brent! I know, old thread, but the best one I've found.
I need to order the frames but I'm also not sure I have the right seals. Did you have to open up your seals in order to put the frames in? Or did they come that way?
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Posted: Wed Jun 09, 2021 7:25 am Post subject: Re: Fastback Pop-out window seals |
AFAIK, Brent is now living a survivalist existence in a remote wilderness area far from civilization.
He left a fine legacy here on the Samba no doubt.
But i can answer your question..
Seals come with the little slide/pocket areas already molded in.
If you can't find the spot to slide your frames into, maybe you have the seals for fixed rear glass? _________________ Bus Motor Build
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3686 Location: San Jose, CA
Posted: Wed Jun 09, 2021 10:46 am Post subject: Re: Fastback Pop-out window seals |
Max Welton wrote: |
That's what I'm thinking.
Well, I have to order frames anyways. I'll just add seals to the order.
Thanks.
Max |
There's a huge difference between the two. It should be fairly obvious if you have pop-out seals or regular window seals. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Brent Samba Member
Posted: Thu Jun 10, 2021 10:40 am Post subject: Re: Fastback Pop-out window seals |
Clatter wrote: |
If you can't find the spot to slide your frames into, maybe you have the seals for fixed rear glass? |
Lol. I still hop on here now and then. _________________ 69 Fastback Build
Berg5 Build |
Posted: Thu Jun 10, 2021 2:57 pm Post subject: Re: Fastback Pop-out window seals |
Brent wrote: |
Clatter wrote: |
Lol. I still hop on here now and then. |
Did Steve just say your name three times into a mirror or what? _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
vwman18 Samba Member
Joined: March 22, 2005 Posts: 51 Location: Port St. Lucie, Florida
Posted: Sat Jun 12, 2021 9:56 am Post subject: Re: Fastback Pop-out window seals |
Is there anywhere I can source the black trim clips for the Fastback popouts? I have frames, latches, and seals but no clips, no trim. I bought the car many years ago with Cal Look seals installed, and I'm hoping to bring the popouts back into service. |
