How do ya mount a license plate on the front bumper
surfrider1960
surfrider1960 is offline
PostPosted: Thu Jun 29, 2006 5:10 pm    Post subject: How do ya mount a license plate on the front bumper Reply with quote
I want to mount a Black plate cali on the from of my "new" 67 Type I but dont want to start drilling holes. I assume there is a bracket that you can use for this that want harm the bumper. Any suggestions? Can you tell I'm mechanical or what?
G
Ragman
The Sambinator
Ragman is offline
PostPosted: Thu Jun 29, 2006 5:12 pm    Post subject: Reply with quote
does your bumper have the overrider bar?
surfrider1960
PostPosted: Thu Jun 29, 2006 5:26 pm    Post subject: Reply with quote
Yes
Tru-Dubs-Bri
Tru-Dubs-Bri is offline
PostPosted: Thu Jun 29, 2006 5:36 pm    Post subject: Reply with quote
Just get a pair of these, then you can mount your license plate on the overrider bar:
http://www2.cip1.com/PhotoGallery.asp?ProductCode=C16%2D113%2D901B&PhotoNumber=2#largerphoto
German Classic, Not Japanese Plastic!
TRU-DUBS
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
surfrider1960
PostPosted: Thu Jun 29, 2006 5:41 pm    Post subject: Reply with quote
Thanks! Very Happy
surfrider1960
PostPosted: Fri Jul 07, 2006 11:36 am    Post subject: Reply with quote
I just installed the mounting kit on the overider bar. The clamps are loose and much larger in diameter than the overider bar, so it's not a snug fit. Is this the correct fit? There is aprrox a 1/4" play, seems like the clamps are to large. Any suggestions?
Thanks
my59
my59 is offline
PostPosted: Fri Jul 07, 2006 11:45 am    Post subject: Reply with quote
Mine have been loose for decades- the plate just slides around on the over rider. You could get some automotive hose of about the right diameter, cut it to make a spacer.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, 77 Mercedes 300D
Alan Willis
Banned
Alan Willis is offline
PostPosted: Fri Jul 07, 2006 2:45 pm    Post subject: Reply with quote
Sounds like you have a cheap replacement bumper. The WW bumpers I used on my oval held the clamps perfectly
die schwarzen Schafe #666
surfrider1960
PostPosted: Sat Jul 08, 2006 5:30 am    Post subject: Reply with quote
What is the dimension of your overrider bar?
Alan Willis
Banned
PostPosted: Sat Jul 08, 2006 6:56 am    Post subject: Reply with quote
I have no idea, I went to WW to buy a set of bumpers, and they showed me the difference in quality. If your bumper has a black grommet where the overrider meets the bumper, it is a cheapie
SuperDave63
SuperDave63 is offline
PostPosted: Sat Jul 08, 2006 11:11 am    Post subject: Reply with quote
I bolted a piece of 1/8" by 3/4" metal between the two inner bumper brackets on the backside of the bumper and bolted the license plate to that. It sits below the bumper and also acts as feeler so I don't bang the lowered front end. I had to bend the bottom up a bit so it wouldn't always drag.
"Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats."-H.L.Mencken
Mr. Loaf
Mr. Loaf is offline
PostPosted: Sat Jul 08, 2006 12:10 pm    Post subject: Clamps Reply with quote
If you can go to an Ace Hardware Store you can find the clamps there that will fit around your overider bar. Should be a 1 1/4 size clamp. They are metal with a rubber sleeve on them. Mine fit tight on my bar.
Never drive faster than your Angel can fly
$24,100 was too hard to resist.................
Mielke
Mielke is offline
PostPosted: Sat Jul 08, 2006 12:23 pm    Post subject: Reply with quote
They prev owner of my '66 had the insight to just drill 2 holes through the OG bumper to mount the plate Crying or Very sad I just use the same 2 holes, they are there I might as well cover them up.
Greg
1966 Canadian Standard Beetle
1967 Beetle
Mr. Loaf
Mr. Loaf is offline
PostPosted: Sun Jul 09, 2006 8:23 am    Post subject: License Plate Reply with quote
Gotta love those previous owners! You can still go with the straps and your plate should cover the holes. If you use the straps you can plug the holes with chrome caps or black plastic ones. You could even put bumper bolts in the holes and still look good.
krazkayaker
krazkayaker is offline
PostPosted: Fri Oct 13, 2006 9:23 pm    Post subject: Reply with quote
All good ideas but what was correct for a 63? I have also seen mounting brackets for the front out there. Do I assume they were a dealer installed item and there is no real 'correct' way?
BYeaton
BYeaton is offline
PostPosted: Thu Nov 26, 2009 5:48 pm    Post subject: Reply with quote
What does everyone do to mount to the blade style bumpers?
I'd really rather not drill through them.
Michael Fischer
Michael Fischer is offline
PostPosted: Thu Nov 26, 2009 6:06 pm    Post subject: Reply with quote
They sell these in the electrical section of my autoparts store. All sorts of different sizes. I have a set in the package from back in the day. They where made for mounting VW bug license plates.
ladybug89
ladybug89 is offline
PostPosted: Thu Nov 26, 2009 6:42 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=706844
1958 bug - 1958 baja - 1962 vert - 2000 Golf
The_Codeman
The_Codeman is offline
PostPosted: Thu Nov 26, 2009 7:48 pm    Post subject: Reply with quote
i made some brackets that wrap around the bumper
www.codemans-bug.com
www.808vwclub.net
50ate
50ate is offline
PostPosted: Thu Nov 26, 2009 8:06 pm    Post subject: Reply with quote
that aint bad at all
