Need to replace high pressure power steering hose
bri4msn
bri4msn is offline
PostPosted: Thu Jan 07, 2016 2:28 pm    Post subject: Need to replace high pressure power steering hose Reply with quote
I have a 1986 Vanagon manual transmission. I saw a leak in the high pressure hose connecting to the power steering pump. A new hose costs 240 dollars at Van Cafe, so I ordered a replacement kit, made by GoWesty for 99 dollars. Mechanic is charging me $250 for installation. Should I do this myself or have the mechanic do it? I am not a mechanic, how technical is this work? Thanks in advance.
Here is the link to the high pressure hose I am replacing with on GoWesty:
http://www.gowesty.com/product-details.php?v=&id=23918&type=
Bassyaks
Bassyaks is offline
PostPosted: Thu Jan 07, 2016 2:44 pm    Post subject: Re: Need to replace high pressure power steering hose Reply with quote
Do it yourself it's easy spend the money and purchase a Bentley , it's your VW Bible.
It should that you about an hour
Tobias Duncan
Tobias Duncan is offline
PostPosted: Thu Jan 07, 2016 4:33 pm    Post subject: Re: Need to replace high pressure power steering hose Reply with quote
Wow, 250 is pretty steep.
I guess he is flushing the system with synthetic oil at 50 bucks a quart?
Grab some power steering fluid and do this yourself.
djkeev Premium Member
djkeev is offline
PostPosted: Thu Jan 07, 2016 4:43 pm    Post subject: Re: Need to replace high pressure power steering hose Reply with quote
Make sure that the new hose has the fluid restrictor in it or else your next post will be along the lines of......
"I put in a new PS hose and now my PS is noisy"
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=60
Dave
Ghia
Vanagon
Beetle
Skidub
Skidub is offline
PostPosted: Thu Jan 07, 2016 5:02 pm    Post subject: Re: Need to replace high pressure power steering hose Reply with quote
use automatic transmission fluid (ATF), maybe something like Chevron MD-3, not power steering fluid
http://alexisoil.com/wp-content/uploads/images/products/p-3949-atf-md-3_0.jpg
https://cglapps.chevron.com/msdspds/PDSDetailPage.aspx?docDataId=76854&docFormat=PDF
86 Syncro GL Tin Top
Subaru 2.5L Swap
Rblt Transaxle w/ R Locker + Decoupler
Tobias Duncan
PostPosted: Thu Jan 07, 2016 6:59 pm    Post subject: Re: Need to replace high pressure power steering hose Reply with quote
Damn it I meant to type auto trans fluid.
It was the big reason I was posting.
"Better make sure he does not buy power steering fluid" i thought.
Then what do I type?
Exactly the wrong advice. Sad
