Texasdoc Samba Member
Posted: Thu May 09, 2019 11:11 am Post subject: Re: Long studs |
I bought a set of thread-in repair studs. I'm just waiting for the 14mm x 2.0 tap to arrive from Amazon.
One of my long studs is loose and needs repair. To get the long studs out - are they just press fit thru the head into the top of the combustion chamber? Are they threaded? Do I need to yank or twist to get them out? |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Thu May 09, 2019 12:27 pm Post subject: Re: Long studs |
They screw in. Many of them have broken off when tried to be removed. As seen in the top example shown here:
I would try double-nut and unscrew, or use a stud extractor tool. _________________ Andy T.
Posted: Thu May 09, 2019 7:35 pm Post subject: Re: Long studs |
Piece of cake. Double nut unscrew for the long stud removal. The long studs just run thru the top of the head and screw into the base. Once out, I just had to tap the boss with a 14mm x 2.0 pitch tap. I didn’t even have to drill - the hole left by the original long stud was the perfect size for the tap. Ran the threads with some cutting fluid and the short-stud repair base threaded right in. Set those with some red loctite and called it good. |
Posted: Thu May 09, 2019 8:17 pm Post subject: Re: Long studs |
Glad to hear it worked out so well.
I will say, if you change one rocker stud, you need to change the other one on the same head! _________________ Andy T.
calebmelvin Samba Member
Joined: July 19, 2006 Posts: 3140 Location: Seattle, WA
mukluk Samba Member
Posted: Tue May 14, 2019 7:25 pm Post subject: Re: Long studs |
calebmelvin wrote: |
I have long studs on the 3/4 head and short studs on the 1/2. Am I correct that I should set the short stud side to .006 and the long stud side to .008/.012? |
Yes. _________________ 1960 Ragtop w/Semaphores "Inga" |
dehate Samba Member
Joined: December 16, 2019 Posts: 7 Location: Ormond Beach, FL
Posted: Thu Oct 29, 2020 8:27 am Post subject: Re: Long studs |
Thank you!
Has anyone installed a set of "pull though" short studs yet? I bought a set but I am wondering if I should also get a set of "machine in" instead? |
been a while since your post but for whats its worth (and hopefully this may help someone in the future) i recently pulled the threads on the original cylinder 1 rocker arm stud. it was my first time dealing with something like this but i purchased a knurled pull through stud replacement kit here in the classifieds and i can say install was super easy and it is working great. in my opinion, the design makes way more sense anyways as the insert and bolt pull against one another opposed to being threaded in the same way like some of the screw in inserts that you have to drill and tap for. picture of the parts i used below...
