Gauges
Page: Previous  1, 2, 3 ... 11, 12, 13
ib-bus
ib-bus is offline
PostPosted: Thu Sep 24, 2015 8:53 am    Post subject: Re: Stork Oil Temp Guage Reply with quote
buggen wrote:
Has anyone ever seen this Stork Oil Temp gauge? It is the mechanical dip stick style and it has a green light what the oil is to cold and a red light when the oil is to hot. When I got it the seller said it was NOS and the gauge holder came with the gauge and looks to have always been with the gauge. When you slide the gauge out of the holder there is clean ring around the gauge where the holder was.
We offer similar gauge holders by Aircooled Accessories , they come in black , ivory or chrome.
Check my ads here on The Samba.
View user's profile Send private message Visit poster's website Facebook Classifieds Feedback
Peter_KG
Peter_KG is offline
PostPosted: Mon Oct 19, 2015 3:56 am    Post subject: Reply with quote
Hi,
I have these two VDO temp gauges, as they go to 120C, could these both be oil temperature ones?
Anyone familiar with these VDO's?
Thanks!
Peter
VW Karmann Ghia '63
VW Kupla Dickholmer '64
VW Bubbla Oval '54
tstracy39
tstracy39 is offline
PostPosted: Fri Oct 23, 2015 3:01 pm    Post subject: Reply with quote
Peter_KG wrote:
Hi,
Thanks!
Peter
The first pic is of a water temperature gauge, so it's not for a VW. The redline on the dial is at 100 degrees Celsius (boiling point of engine coolant) so it's only for water cooled engines. The second pic is of an industrial temperature gauge that can be used for either oil or water temp applications, but not designed for VW.
Check my classifieds for kewl gauges:
http://www.thesamba.com/vw/classifieds/search.php?username=tstracy39
I like your fork.
Harris
Harris is offline
PostPosted: Fri Oct 23, 2015 6:57 pm    Post subject: Gauges Reply with quote
My short 12 year experience searching for a specific VDO gauge tells me one thing. VDO was prolific in producing gauges for numerous auto manufactures.
If you can by number on back of gauge determine a time span in years, then Google images of different car (European mainly) makers may lead you to the exact automobile your gauge was produced for. The VDO archives in Frankfurt has limited info left that gives the facts you need.
I don't think VDO had a long run of producing any one gauge even for one car manufacturer.
bigdish2 Premium Member
bigdish2 is offline
PostPosted: Tue Feb 06, 2018 1:18 am    Post subject: Re: Gauges Reply with quote
Just picked up this March 54 vdo clock. Not many this old posted on here.
For lastest finds check out
@texasvintagevdubs on Instagram or Facebook
In the stash
1954 & 63 Vert
1956 Dove blue camper
(2) 1958 23w deluxes
(2) 1958 PGSG 11w og paint
1958 logo dd panel
1959 dove blue 11w
(5) 15w deluxes
(3) 1960,63,65 double cabs
1963 swr/bg 11w w/t
1964 limo bus 350 powered
1964 SO36 Dormobile flipseat Westy
1965 Kombi Slammed Fuchs
1966 (2) so42s og paint
1969 (2) porsche 912s
1969 dart swinger 340
1983 Porsche sunroof coupe 911
NASkeet
NASkeet is offline
PostPosted: Tue Feb 06, 2018 9:14 am    Post subject: VDO Gauges Reply with quote
tstracy39 wrote:
Peter_KG wrote:
Hi,
Thanks!
Peter
VDO oil-temperature gauges commonly have 50~150 C temperature scales, although there were some on various Audi cars which were calibrated up to 170 C.
On German E-bay, I have seen some VDO temperature gauges with calibrated scales of 60~200 C, but I have yet to discover their intended application.
For at least 30 years, VDO have been making 40~120 C temperature gauges and a variety of matching sender units with different screw-thread sizes; some with a temperature-switch (various switch temperatures) incorporated to activate a warning light or audible warning device.
For a pressurised liquid-cooling system (typically 13 or 15 psi above standard atmospheric pressure), the boiling point of pure water exceeds 100 C.
Various mixture proportions of water & antifreeze (typically glycol) have different boiling points, which exceed 100 C at standard atmospheric pressure.
https://www.thoughtco.com/what-is-the-boiling-point-of-water-607865
http://www.compoundchem.com/2016/03/22/boiling-point/
Regards.
Nigel A. Skeet
http://www.vwt2oc.net
swanlakers
swanlakers is offline
PostPosted: Mon May 07, 2018 11:44 am    Post subject: Re: Gauges Reply with quote
Not the kind of gauge you can put in the dash, but pretty cool nevertheless
Bowmonk acceleration and brake gauge - measures in % of G.
In use:
NASkeet
NASkeet is offline
PostPosted: Wed Jun 13, 2018 8:41 am    Post subject: Re: Gauges Reply with quote
Until recently, mine was the only VDO Cockpit 'Night Design' instrument (i.e. VDO Cockpit 'Night Design' alternator-sensed 0~6000 rpm engine-tachometer) I have come across, but I have since discovered a few more on E-bay.
52 mm VDO Cockpit 'Night Design' alternator-sensed 0~6000 rpm engine-tachometer
52 mm VDO Cockpit "Night Design" 7000 rpm engine-tachometer
VDO Cockpit "Night Design" 50~150 degC oil-temperature gauge
VDO Cockpit "Night Design" 40~120 degC water-temperature gauge
VDO Cockpit "Night Design" -30~0~30 A ammeter
VDO Cockpit "Night Design" -25~0~40 degC ambient-air temp gauge
I also recently discovered a VDO Cockpit "Night Design" 120~350 F oil-temperature gauge listed in The Samba Classified advertisements as follows:
https://www.thesamba.com/vw/classifieds/detail.php?id=1893001
Regards.
Nigel A. Skeet
NASkeet
NASkeet is offline
PostPosted: Thu Aug 23, 2018 8:04 am    Post subject: Re: Gauges Reply with quote
Here is a VDO combination accessory gauge unit of a type I have never previously seen, which incorporates a fuel gauge and oil-temperature gauge. Although I cannot see any measurement units specified, I deduce from the number scale that the oil temperature is being measured in degrees Fahrenheit; much favoured in the USA, but declining in use even here in Great Britain where the metric system is now the norm for most things.
VDO combination fuel & oil-temperature gauge unit
I found it recently listed on British Ebay, for a prohibitively high asking price of 265 + shipping, but I thought you might be interested to see this example, which the vendor says he originally bought for his 1954 VW Beetle.
VW Camper Van / Beetle fuel & oil temp gauge made by VDO
https://www.ebay.co.uk/itm/VW-Camper-Van-Beetle-Fu...Sw4CFYodKl
Regards.
Nigel A. Skeet
NASkeet
NASkeet is offline
PostPosted: Fri Aug 31, 2018 8:46 am    Post subject: Re: Gauges Reply with quote
The asking price has now been reduced to 195 + shipping, which is still extremely expensive
Regards.
Nigel A. Skeet
Lind
Lind is offline
PostPosted: Fri Aug 31, 2018 3:19 pm    Post subject: Re: Gauges Reply with quote
That gauge was made by VDO for '58-'61 beetles. It fits at the top middle of the dash. It is also bulky, ugly and not desired by many people if anyone. It is a neat item, but not nearly as precious as the ebay seller thinks it is.
You define your own happiness
NASkeet
NASkeet is offline
PostPosted: Sat Sep 01, 2018 8:05 am    Post subject: Re: Gauges Reply with quote
If I had had a vehicle for which it was appropriate, I might have stretched my budget to maybe the equivalent of US$50 for one of those, but by my standards, even a reduction to 195 + shipping, would be a silly price. Rolling Eyes
Regards.
Nigel A. Skeet
NASkeet
NASkeet is offline
PostPosted: Mon Dec 24, 2018 4:58 am    Post subject: Re: Gauges Reply with quote
Here are a few more that I discovered recently, that have been listed on British E-bay for some time, at an asking price of 200, which is too rich for my taste:
https://www.ebay.co.uk/itm/VDO-GAUGES-OIL-PRESSURE...rk:41:pf:0
VDO Cockpit "Nightdesign" 0~10 Bar oil-pressure gauge
VDO Cockpit "Nightdesign" 8~16 V voltmeter
VDO Cockpit "Nightdesign" 50~150 C oil-temperature gauge
Regards.
Nigel A. Skeet
ALLWAGONS
Location: Fracc Soler, Tijuana Baja California Zona Norte
ALLWAGONS is offline
PostPosted: Fri Jan 04, 2019 8:46 am    Post subject: Re: Gauges Reply with quote
My VDO shop counter display.
"Don't laugh! That's my Wisconsin ID picture!" overheard at a Local California Hipster Restaurant.
Just found out I am allergic to lead in capsules(bullets)!
Page 13 of 13
