Low Bräu Samba Member
Joined: December 12, 2003 Posts: 346 Location: Merritt Island, FL
Posted: Sat Jul 08, 2006 7:43 pm Post subject: 68 vs. 67 axle indentification - info request |
I already did a search but didn't find exactly what I was looking for. I am sure it there just not finding it.
I am compiling parts to lower a bus and have a question. I am trying to verify that the axles (axles only not tubes or bearing retainer) I have are 68 long/long type 1 or early type 3 and not 67 only type one. Could someone please give me some measurements so I can determine which axles I have? Length of the splines or length from the end of the threaded part to the machined step should get me pointed in the right direction I think. Pics would be good too.
Thanks
Josh |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Sun Jul 09, 2006 7:11 am Post subject: |
I know that the 67 and 68 look very much the same except the 68 has longer splines. I only have one set of axles in front of me right now so I can't determine if one is 5/8" longer than the other. They are definately long axles, just not sure about the spline length. How long should the splines be on a 68 axle? Or, how long should the splines be on a 67 axle? |
Posted: Sun Jul 09, 2006 7:53 am Post subject: |
67 and down spline= 3 7/8 from flat that skinney spacer sits/ so 68 would be about 4 1/2" from same spot. i missunderstood your question ,i thought you had both axles in front of you. this length of spline-not-spline plus threads. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Sun Jul 09, 2006 7:17 pm Post subject: |
Thanks Bill. Looks like I have the 67 long axles with short splines. |
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Mon Jul 10, 2006 4:09 am Post subject: |
Josh Gizinski wrote: |
thats what i just put in my trans,i beleive you have to run skinny beetle brakes and spacers on your wheels if your going to run stock rims.otherwise no spacers if you run raders or brms etc. due to offset. |
Posted: Mon Jul 10, 2006 8:21 pm Post subject: |
bill may wrote: |
machine 5/8" off snout and run type 3 brakes or use 68 and up brakes with wide thing drums-machine 5/8" off snout to get same length as 67 and down spline. |
where do you put your hands on everything you need to run type 3 brakes.(backing plates,springs, hardware,and drums)?i have been needing this stuff but have not found it. |
