jAndrew Samba Member
Joined: October 11, 2020 Posts: 306 Location: Atlanta, Georgia
Posted: Wed Dec 22, 2021 10:58 am Post subject: Another tower to air box question |
I'm gonna just throw it out to everyone- my hose seems a little short, about an inch.
The one from the breather tower to the air box as well. Talking about the one is this diagram #16.
The hose.
In the diagram this hose appears to connect to the fitting with the plug. On my truck it is opposite and always has been.
Which is correct? Should the hose be attached to the fitting with the plug, or the other? If mine is backwards I believe it might work out. Just worried about messing something up if I swap them around, but pretty sure it would not. _________________ '89 Syncro Doka |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6351 Location: Honolulu,Hawaii and France
Posted: Wed Dec 22, 2021 11:28 am Post subject: Re: Nother tower to air box question |
ALIKA T3 wrote: |
the heating element should be connected to the breather tower, that's why. |
Makes sense, but with all of the other oddities I wanted to make sure, thanks for setting me straight. _________________ '89 Syncro Doka |
Posted: Wed Dec 22, 2021 12:17 pm Post subject: Re: Nother tower to air box question |
Ugh. Now it will run for 2 seconds and die. All I did was take the heater box off to clean everything!
Will now do it over again to see what I messed up. Sometimes it seems better just not to touch any of it. Seems like everytime I attend to one thing another 2 or 3 crop up. _________________ '89 Syncro Doka |
jayinduluth Samba Member
Joined: August 16, 2012 Posts: 122 Location: Southern California via Duluth, MN
Posted: Wed Dec 22, 2021 1:08 pm Post subject: Re: Another tower to air box question |
Did you plug your AFM back in? _________________ 85 Westy with 91 2.1L |
Posted: Wed Dec 22, 2021 2:16 pm Post subject: Re: Another tower to air box question |
jayinduluth wrote: |
Did you plug your AFM back in? |
I did. I had taken the screws off the plug on the AFM to inspect the wiring. I might have disconnected something inadvertently.
Is that black cover on top of the AFM engineered to come off? I pried a bit but nothing. Didn't want to break it. _________________ '89 Syncro Doka |
Posted: Wed Dec 22, 2021 2:39 pm Post subject: Re: Another tower to air box question |
Heck. _________________ '89 Syncro Doka |
Timwhy Samba Member
Posted: Wed Dec 22, 2021 6:25 pm Post subject: Re: Another tower to air box question |
Odd that no one has ever tried to get the AFM apart. Perhaps it's meant to just never have anything ever done to it? I will try ans get it back together and see what happens. _________________ '89 Syncro Doka |
do.dah Samba Member
Joined: August 27, 2015 Posts: 444 Location: Washington
Posted: Wed Dec 22, 2021 7:43 pm Post subject: Re: Another tower to air box question |
That plastic cover on the AFM can be pried off, carefully. There are threads here pertaining to that. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32594 Location: Reading Pennsylvania
