isotopez Samba Member
Joined: July 11, 2007 Posts: 97 Location: Sandy Eggo, California
Posted: Tue Sep 22, 2009 6:31 pm Post subject: Interior Metal Braces Broken |
So I am currently about to seal up my seams on the inside and then apply soundproofing/insulation but I noticed that some of the sheetmetal braces that attach the outer panels to the inside panels have pulled away.
It looks like the factory used some type of expanding adhesive, and then painted over it because my rear hatch was loose and when I pulled it fully seperated and some chunks fell down which are quite heavy.
My question then is what should I use to attach the inside metal panel to the outside panel? Liquid nails or something like that?
_________________ 1984 Westy Camper
1992 Subaru Legacy (About to donate its heart)
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12007 Location: Santa Cruz, CA
Posted: Tue Sep 22, 2009 6:34 pm Post subject: |
Posted: Tue Sep 22, 2009 6:36 pm Post subject: |
thx syncrodoka just noticed posted faulty url.. _________________ 1984 Westy Camper
1992 Subaru Legacy (About to donate its heart) |
dredward Samba Member
Posted: Tue Sep 22, 2009 6:50 pm Post subject: |
Hey Mario, when you gona go for a ride in the finished product? |
82WestyMan Samba Member
Joined: December 28, 2006 Posts: 1098 Location: Western OR
Posted: Tue Sep 22, 2009 7:12 pm Post subject: |
I'll say that I work in a auto manufacturing facility (BMW) and we commonly use an adhesive for just this
(think bonding the hood to the structure underneath where spot welding would impact the physical appearance of the hood surface)
3M is a great name and a google search should bring up the product you need and I'd suspect they have excellent documentation on their site on proper application _________________ "The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine |
Posted: Tue Sep 22, 2009 7:18 pm Post subject: |
I just did some searching and am thinking jb weld liquid might work?
My rear hatch (pictured) and the driverside strut near the zbed pulled apart, so I'm going to check the integrity of the other panels. The last thing I want is to install all my cabinets back in and have some godawful clanking like the rear hatch is since its no longer glued together. _________________ 1984 Westy Camper
vwlovr Samba Member
Joined: May 21, 2006 Posts: 1122 Location: on the road
Posted: Tue Sep 22, 2009 8:18 pm Post subject: |
isotopez wrote: |
My rear hatch (pictured) and the driverside strut near the zbed pulled apart, so I'm going to check the integrity of the other panels. The last thing I want is to install all my cabinets back in and have some godawful clanking like the rear hatch is since its no longer glued together. |
i used some metal epoxy and it has held up. i didn't have a clamp so i leaned a motorcycle up to the hatch
ThorAlex Samba Member
Posted: Tue Sep 22, 2009 8:22 pm Post subject: |
I'm not sure it's glue. The braces are loose on my doka too, the "glue" looks exactly like the stuff in the seams. That stuff is everywere! _________________ 1990 syncro 1.6TD "Smily"
Ex-vans:
1990 Caravelle coach 1.6TD
1986 Transporter Double cab syncro 2.1 112hp
"I'm wrong so often... It's great!" - Adam Savage |
Dogpilot Samba Member
Posted: Wed Sep 23, 2009 1:11 am Post subject: |
Go here and select the one you feel works best for your application. Then go to an automotive paint shop and get some. You will need the funky dual piston gun to dispense it. There are other brands that use a single ram system and a mixing nozzel. I really have had good luck with the Fusor products.
http://www.lord.com/Home/ProductsServices/Adhesive...fault.aspx _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Terry Kay Banned
Posted: Wed Sep 23, 2009 6:14 am Post subject: |
3-M body panel adhesive would work very well for this repair. _________________ T.K. |
