Busted-bolt Samba Member
Joined: April 14, 2018 Posts: 514 Location: minnesoota
Posted: Sun Jun 28, 2020 5:56 pm Post subject: Re: "Bastard" Engines |
BarryL wrote: |
Your case halves were poured a week apart in February of '60.
Is that main seal Bastard size? For some reason (without going to my shed and measuring) it looks regular size. |
I wonder what was the latest pouring date that had the large rear main seal casting "early bastard" ? _________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission. |
Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Sun Dec 06, 2020 5:12 pm Post subject: Re: "Bastard" Engines |
Does anybody have info on bastard transmission case part#s ..im looking for a bastard transmission and need info so it will lead me to one... |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sun Dec 06, 2020 5:48 pm Post subject: Re: "Bastard" Engines |
[email protected] wrote: |
Have you tried:
http://www.oacdp.org/
For the original VW dealer parts manuals there? _________________ In Stereo, Where Available! |
Posted: Sun Jan 31, 2021 7:35 am Post subject: Re: "Bastard" Engines |
Third generation heads reborn.1-30-21
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Sat Mar 20, 2021 8:52 am Post subject: Re: "Bastard" Engines |
I'm curious to know if anybody has any pliable / soft valve cover gaskets for these "bastard" engines?
I read somewhere on this thread that someone has 'em but can't find which post? Thanks. _________________
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
Posted: Sat Mar 20, 2021 12:09 pm Post subject: Re: "Bastard" Engines |
This is the special valve cover I modded to fit my bastard cylinder head. It started life as a regular 40 hp cover. The 40 hp valve cover offers a lot more surface area in the dip portion of the cover .I then spot weld retaining strips to properly locate the gasket so it can not slip out.
sundialer66 Samba Member
Posted: Tue Feb 01, 2022 1:08 pm Post subject: Re: "Bastard" Engines |
Do we have a definitive vin number when Vw Switched to the bastard? Some discrepancies between this site and prog. Ref.
Thanks. _________________ Wanted: lucksinger, redwood motors, veale plate frames. |
Redlocker Samba Member
Joined: January 25, 2010 Posts: 107 Location: I'm in southwestern PA, USA
Posted: Tue Feb 01, 2022 3:12 pm Post subject: Re: "Bastard" Engines |
According to the Bentley manual, page M-9, 6a:
The True Bastard Engine:
1ST GENERATION FROM ENGINE SERIAL NUMBERS: 3 400 000 - 3 491 699
The "hybrid" Bastard/40 Horse:
2nd generation from 3 491 700 - 3 520 332 (I believe that these are basically an ordinary 40-horse block / crank) I am not sure if the cam and its bearings, or lack of, are involved or not, with some Bastard accessories.
But hey... I am not an expert. Anyone else? Anymore advice? _________________ Search my other want ads. A wise man once said, "Do unto others, as you would have done unto you". We should all try that.
71 Super Beetle (stolen)
71 Squareback (rusted, junked)
71 Squareback (factory-dealer A/C, sold)
68 Bus, sold
68 Beetle (baja'd, sold)
78 "Golf" (total burn)
81 Scirocco S (sold, bought back, sold again)
81 Scirocco S (sold)
86 Scirocco (sold)
83 GTI (DSP auto-crossed, sold)
84 GTI (sold)
2000 New Beetle
'60 Microbus Std. / Mango (project in progress) |
Posted: Tue Feb 01, 2022 7:16 pm Post subject: Re: "Bastard" Engines |
Thank you! I meant the chassis number, but it has been cleared up as
469 447
May 19. 1959 _________________ Wanted: lucksinger, redwood motors, veale plate frames. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
velvetgreen Samba Member
Posted: Mon Apr 04, 2022 3:13 pm Post subject: Re: "Bastard" Engines |
Try this again
Posted: Mon Apr 04, 2022 3:15 pm Post subject: Re: "Bastard" Engines |
^^ 2 sets- one is 77.46 and the other is 77.95 |
House Minutia Militia
Posted: Mon Apr 04, 2022 7:55 pm Post subject: Re: "Bastard" Engines |
Nice!
I just got a set of long ago rebuilt heads out of a scrap bin…
I guess I should take some pics! |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4573 Location: St Charles, MO
Posted: Mon Feb 20, 2023 5:37 pm Post subject: Re: Possible exhaust damper for bastard bus? |
Redlocker wrote: |
Redlocker wrote: |
I recently acquired a Bastard engine with a serial number indicating the correct month of manufacture for my bus. I have not opened it up yet to see what I now own. But I know I will somehow piece a "corrected" version of this engine together as time / money allow.
I also have managed to secure an authentic N.O.S. Bastard bus muffler (the type with the exhaust outlet angled to the left side of the bus (but I will not have it for a month or so). I have a correct exhaust tip (Thanks Everett). I am now trying to find a correct damper to complete the assembly.
I am almost certain that the later 40 HP dampers designed to fit the straight exhaust outlet (not the angled one that early bastard engines had) are not the correct damper. But would they work if the 90 degree angled was opened up a little (meaning is that the only difference between the correct damper and the easier to find one)?
Additionally, does anybody know if a type III damper (it has the curved pipe to fit into the angled outlet) would work, assuming I welded on the missing tab that attaches it to the muffler ?
The Type III Damper I am referring to:
I also thought if I knew some of the measurements of the bastard dampers/muffler outlet that could help as well.
Thanks for any help, advice, or corrections. |
Well that answers the type III damper possibility.
Can anyone help out with any of the other questions? Especially this one:
"I am almost certain that the later 40 HP dampers designed to fit the straight exhaust outlet (not the angled one that early bastard engines had) are not the correct damper. But would they work if the 90 degree angled was opened up a little (meaning is that the only difference between the correct damper and the easier to find one)?"
Thanks again. |
This may have already been already answered long ago since the post was from 2013, but this evening I just measured my original outlets on my two NOS "Bastard" exhaust systems and the angled outlet pipe on both mufflers was about 32.5 mm inner diameter. I also have a couple of damper pipes for those mufflers with the angle pipe to match the exhaust systems and they were right around 31.9mm to 32 mm in outer diameter, so you can see that they slip right into the NOS mufflers. Sorry if that has already been posted here
While I was digging around in the dusty parts shelves in the basement I realized that I had two complete used air cleaners with pipes to the carb, the triangle brackets and the braces for "Bastard engines plus one NOS bastard air cleaner assembly. Damn I got to get down there a little more and dig around, pretty fun!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
buggen Samba Member
Posted: Mon Aug 07, 2023 6:20 pm Post subject: Re: "Bastard" Engines |
A Bastard was added to my family recently. 26k original miles. I am surprised it looks like the exhaust was changed. I can understand a new fuel pump but only 26k miles or less on an exhaust seems early. Is that bracket off the bumper to hold part of the exhaust?
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Thu Aug 10, 2023 9:05 pm Post subject: Re: "Bastard" Engines |
I have used those rubber pieces between the bumper bracket and the tailpipe, and they always break. _________________ .
Wanted:
Posted: Fri Aug 11, 2023 3:29 am Post subject: Re: "Bastard" Engines |
Lind wrote: |
I have used those rubber pieces between the bumper bracket and the tailpipe, and they always break. |
I wonder why Lind? I have had one of those rubberized support pieces between the muffler and metal bracket on the bumper bracket on my June of 1959 SWR Panel for over two decades of use now and it still looks to be in great condition. Well, so far anyway...
Lind Samba Member
Posted: Fri Aug 11, 2023 6:06 am Post subject: Re: "Bastard" Engines |
BulliBill wrote: |
Lind wrote: |
Bill |
How many miles in that time? Maybe my engines like to move around more or the old NOS rubber is just too hard and brittle. _________________ .
Wanted:
Posted: Mon Oct 02, 2023 9:25 am Post subject: Re: "Bastard" Engines |
All time best thread.
Does anyone have an example of a re-stamped case? I have a case with perfect bastard era numbers only to learn it’s a dealer stamped replacement? Did dealers have factory stamps? Thank you. _________________ Wanted: lucksinger, redwood motors, veale plate frames. |
