backcountrymedic Samba Member
Joined: February 17, 2006 Posts: 583 Location: Monterey, CA
Posted: Wed Aug 09, 2006 1:35 pm Post subject: Ash tray ipod dock holder? |
Has anyone converted their ash tray into an ipod dock holder? I finally got my ipod set up to a direct auxillary input on my stereo (no more FM transmitter!!!), and now I'm looking for a good spot to mount the ipod dock in the Westy. Maybe somebody smarter than me (and that's most everyone here) can come up with some ideas...?
Cheers!
-Jared _________________ No need to bear the weight of your worries, you let them all fall away...
Sector 9 longboard
Kona Kikapu Deluxe MTB
Novarra Big Buzz
Electra Cruiser
'01 Toyota Tacoma 4x4 |
Dogpilot Samba Member
Posted: Wed Aug 09, 2006 2:42 pm Post subject: |
Jared,
I don't think I'm any smarter, but I just put my iPod direcly into the ash tray, upright seems to work fine for me. It might be a little disgusting if your ash tray has been serving its primary purpose and not been cleaned out.
Cheers,
James _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
amishman Samba Member
Joined: March 09, 2004 Posts: 3217 Location: California
Posted: Wed Aug 09, 2006 3:26 pm Post subject: Re: Ash tray ipod dock holder? |
backcountrymedic wrote: |
Cheers!
-Jared |
What radio is in your Westy and what device did you use to wire up the iPod to it?
I am going to install a stock Heidelberg AM/FM Cassette back into mine so I can do the cassette tapes once in a while and wanted to connect my iPod to it also so I have a big sound selection. I was going to get one of those cheap FM Modulator units that connect direct to the antenna lead so it kills the station of choice and therefor, you get a better signal than a FM deal that is wireless.
What exact setup did you get.
tj |
Posted: Wed Aug 09, 2006 4:09 pm Post subject: |
My head unit is a Pioneer DEH-P4600MP. It's a single disc player, that'll play CD-RW discs in MP3, WMA, & WAV formats. It's also XM ready, and can control a CD changer. Pioneer makes a cable that'll convert the CD changer control port into an auxillary RCA input. I installed that adapter today, and then did some creative wiring...
I spliced into my existing 12V outlet on the dash, and installed a 'hidden' 12V outlet behind the glovebox. Then, I bought the Belkin Auto Kit for iPod w/dock connector which acts as both 12V power cable, and (here's the cool feature), has a 3.5mm audio out jack on the charging unit. I hooked up a 3.5mm to stereo RCA output cable, and stashed everything in the glovebox. Now I have direct iPod to head unit, without the issues of an FM modulator or transmitter. Beauty, eh?
Now, I just wanna figure out a good place to keep the iPod within reach.
Cheers!
Sector 9 longboard
Novarra Big Buzz
Electra Cruiser
grunwin Samba Member
Joined: April 05, 2005 Posts: 107 Location: Portland, OR
Posted: Thu Aug 10, 2006 8:34 am Post subject: |
As I have no more interest in cassettes and only play the occasional CD, I was looking for something to play my iPod almost exclusively while keeping a low profile. When I used the cassette adaptor for my iPod I always felt like I had to conceal it if I was leaving the van. With my new system the sound quality is better, it is always charging, there are no wires sticking out for adaptors or chargers (the one in the second photo is for a dashboard fan), and I never have to fiddle with the iPod itself.
Notice the iPod resting comfortably in the glove box.
It's only on the dash for the photo; otherwise I never see it. Also, you can disconnect at any time, unlike disconnecting from a computer. And it says Hello to me. _________________ '87 Westy
'04 Golf 2.0 |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Thu Aug 10, 2006 11:30 am Post subject: |
I just let mine sit in there sideways. But I use a Monster FM Transmitter/Charger (not good enough for you Audiophiles, but works well enough for me).
This guy made a very cool Ipod dock in his ashtray:
http://www.251.org/83VgoniPod.html
Joe T. |
Posted: Thu Aug 10, 2006 2:16 pm Post subject: |
joetiger wrote: |
Joe T. |
Now that is some cool stuff right there. I likey likey.
tj |
riceye Samba Member
Joined: March 09, 2006 Posts: 1661 Location: Caledonia, WI
Posted: Thu Aug 10, 2006 2:21 pm Post subject: |
I've got a JVC head unit that mounted up in about a half an hour. $120 including the VW specific wiring harness. The head unit has an input in the rear for a CD changer. I found a cable, manufactured by Soundgate (AUXPDJVC), for $28 that plugs into the CD changer input. This charges the iPod, but does not display the info on the head unit screen, or allow head unit controls to adjust the iPod. Plug and play. No wire splicing.
I ran the cable into the glove box. I usually put the iPod in the ashtray when in use, and close the glove box on the cable. Clearance is good. Great sound, too.
I'm saving my pennies for four Polk Audio 4" round speakers to replace the OE. Maybe a subwoof under the backward facing seat, as well.
Regards,
Ric _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
ianstone Samba Member
Joined: September 14, 2005 Posts: 195 Location: San Francisco, CA
Posted: Thu Aug 10, 2006 2:37 pm Post subject: |
i have a high end kenwood deck with RCA inputs in the back. I just wired up an RCA>Mini plug, which comes out right near the shifter at the very bottom of the dash. works quite well. |
shenan-agon Samba Member
Joined: May 11, 2005 Posts: 423 Location: Portland, OR
Posted: Thu Aug 10, 2006 6:32 pm Post subject: |
riceye wrote: |
I've been thinking about that as well - I have an old 12" Kicker just taking up space in my basement... |
vwjedi Samba Member
Joined: November 29, 2005 Posts: 1463 Location: G-ville, FL - hopefully on a trail.
Posted: Thu Aug 10, 2006 7:57 pm Post subject: |
I have an XM reciever wired into my Auxiliry port on the head unit, when I camp with buddies that have an iPod I can plug in their shit and listen to it too. It doesn't sit in any cool craddle but I like the ashtray mount.
I have a amp under the driver seat for the sub with cap. No drilling so if you want to steal it just pull it out.
The sub is a 12" Rockford Fosgate in a box that is too small, but it fits behind rear facing jump seat when camping.
The head unit powers 4" RF surrounds and has a built in crossover for low width bypass, it has enough power to keep me happily cruising down the road, and I didn't cut anything bigger or drill anything that can't be removed.
Jared-I know this way more BS than you asked about, 'cause I don't even have an iPod but I have been drinking tonoght and the wife is out of town so I have nothing better to do. _________________ 1987 Wolfsburg T25 still riding out. A bunch of other VW's passed on... |
Posted: Thu Aug 10, 2006 8:52 pm Post subject: |
Good times! Adult beverages and The Samba! Just had an adult beverage myself
And keep it up... I love the stereo ideas/tech talk.
Sector 9 longboard
Novarra Big Buzz
Electra Cruiser
Muskrat Samba Member
Joined: July 20, 2006 Posts: 184 Location: sacramento, ca
Posted: Wed Aug 16, 2006 1:38 am Post subject: |
i came across this site which details an actual plug in dock built into a vanagon ashtray. www.251.org theres a section titled my vw's, click on vanagon then click on 1983.5 vanagon/subby 2.2 then click on ipod dock and there ya go. |
bself Samba Member
Joined: October 18, 2004 Posts: 101 Location: Portland, Oregon
Posted: Wed Aug 16, 2006 7:29 pm Post subject: |
man, that's exactly what i'd envisioned doing/wanting but really hadn't put much thought into it. thanks for the link. _________________ 1987 VW Vanagon Westfalia SBX EJ25 |
thecaptian Samba Member
Posted: Fri Aug 18, 2006 2:47 am Post subject: |
If any one is looking for a lil' cheaper way and works great Clarion makes the best FM modulator (direct in to head-unit through antenna) I have found. Comes with all the wiring, 12 volt, disconnect switch the works. What i thought was cool is that instead of a 1/8 jack it has a/v (r/l) cables so your options aren't limited. Also for any one interested I am installing a old mac clamshell into my van as a media centre and will be posting the progress. _________________ '91 Vanagon Carat |
Posted: Fri Aug 18, 2006 8:47 am Post subject: |
thecaptian wrote: |
If any one is looking for a lil' cheaper way and works great Clarion makes the best FM modulator (direct in to head-unit through antenna) I have found. Comes with all the wiring, 12 volt, disconnect switch the works. What i thought was cool is that instead of a 1/8 jack it has a/v (r/l) cables so your options aren't limited. Also for any one interested I am installing a old mac clamshell into my van as a media centre and will be posting the progress. |
Tell me more about the Clarion modulator. I have been thinking about getting one of these generic ones on eBay. What model and where di you get yours and tell me more.
Thanks
tj |
Monoscope Samba Member
Posted: Fri Aug 18, 2006 10:33 am Post subject: |
In doing a lot of research on this I've found many, many options and even more opinions on the subject of the best sound quality for the iPod into a car stereo.
The consensus seems to say that FM transceivers Suck the most.
1/8" headphone jack to cassette Suck almost as much.
1/8" headphone jack to RCA is only barely acceptable.
Line out audio (dock connector) is the "Only" way to go.
But as far as options for the Dock connector to have line out (RCA) and charging while still having iPod based control (as opposed to stereo control) were really hard to find.
The Harman Karden Drive + Play looks cool and wasn't that expensive, but I don't really have a good place for the controller and the screen is more of an enticement to break into the van. It also got some not so good reviews for factors such as the fact that the firmware isn't upgradeable and poor scrolling with big libraries.
The other options all seemed geared to replace the CD changer option on most newish stereos (but that puts the stereo in control of the iPod) or plug into new cars. That is until I found the XtremeMac Roadshow connector. It has all the criteria I was looking for (charging, Line out, iPod based control and video if I ever choose to do that), it also is backwards compatible.
From the review at iPodLounge.com http://www.ilounge.com/index.php/ipod/review/xtrememac-roadshow-car-av-cable-for-ipod-with-video/
the opening quote said the most "It’s a professional auto installer’s dream cable"
and the best part is that it's $35 from clubmac.com. I'm ordering one today.
It's got 8' of cable so I'll probably run it under the carpet to the Alien Coffee Box between the seats and just keep it there.
Posted: Fri Aug 18, 2006 11:58 pm Post subject: |
I cant remember the model # but i Got mine form ebay for 30 dollars + shipping. I found that it works really great better than almost anything I have ever hear. It has volume control on the modulator itself so it can be adjusted along with the head-unit so when you switch over to ipod all control is there even volume. You might get something if you search clarion modulator or transmitter. _________________ '91 Vanagon Carat |
eargenbr Samba Member
Posted: Sat Aug 19, 2006 10:04 am Post subject: |
I put a "Bazooka" (power tube subwoofer with a built in amp (comes in its own enclosure that is tube shaped with the amp inside)) under my rear bench seat. Completely easy to install (just run a larger guage power wire from your batter back to the power tube, I hid mine under the carpet) and more bass than anyone needs. My whole system is higher end stuff but the "Bazooka" was only 100 bucks, if I remember correctly, and works killer. You can run your speaker wires the same as your power wire or use the ones that already run to the original rear speakers, which is what I did and it sounds great with after market speakers. The wire is a little thin but works o.k.. I don't know what this has to do with ipods but there you go.
Cheers. |
bread geek Samba Member
Joined: October 30, 2005 Posts: 266 Location: fryeburg ME
Posted: Sun Aug 20, 2006 5:42 pm Post subject: |
I just installed an alpine deck in my westy that is ipod ready.It has a cable that comes out the back of the deck wich i ran to my glove box.that is where i keep my ipod because all your scrolling and info is controlled from the deck.email me if you have any questions.Jeff |
