lovedavdubs Samba Member
Joined: April 30, 2004 Posts: 1597 Location: New York, NY.
Posted: Wed Aug 09, 2006 5:15 pm Post subject: new calipers |
I'll be installing a set of brand new Girling calipers this weekend. Can anybody post a link to a brake bleeding tutorial. I've never done this before and want to lay out a game plan before I start pulling things apart. _________________ 82 Air-cooled Westy (Lola)...My other vehicle is a subway. |
kevinbassplayer Samba Member
Posted: Wed Aug 09, 2006 6:25 pm Post subject: |
This is a link I had marked for changing a brake master cylinder, it does include info on bleeding (I haven't had to do this..... yet )
http://www.vanagonauts.com/index.phtml?catid=190
On a side note, you should update your avatar, your van looks awesome with the GW wheels! I was orginally lusting after the Reins for the last year but after seeing the pictures you posted, I'm leaning heavily towards the go westy 15" wheels! (It never ends does it?!) |
Posted: Wed Aug 09, 2006 6:44 pm Post subject: |
Thanks Kev
I've put quite a few miles on them since January and I highly recommend them. _________________ 82 Air-cooled Westy (Lola)...My other vehicle is a subway. |
riceye Samba Member
Joined: March 09, 2006 Posts: 1661 Location: Caledonia, WI
Posted: Wed Aug 09, 2006 7:30 pm Post subject: |
Here you go:
Pull all of the bleeders - one by one. Use a box end wrench - preferably six point - and be careful! Penetrating oil may help. Take the bleeder out, run a wire through the hole, and clean it on a wire wheel on a bench grinder (or the like). Apply a thin film of anti-sieze to the threads. Replace into the wheel cylinder or caliper.
When you have all the bleeders cleaned up and replaced, pull the shrouding off of the instrument cluster. Unscrew the cap from the master, and suck all the old brake fluid out with a bulb syringe or vacuum pump. Don't get brake fluid on paint or plastic, as it may soften the finish. Refill with DOT 4 fluid from a fresh, sealed bottle. I use synthetic. Buy a quart.
You will need the help of a compadre for the actual bleeding, unless you build or buy a bleeder. The total time to bleed with a helper will be far less than the time to purchase or assemble a pressure bleeder. The helper will operate the pedal, and replenish the fluid as necessary. They can also replenish their own fluids with their favorite beverage. It is a pretty mindless task.
Start with the right rear wheel - farthest from the master. Attach a piece of 3/16" clear tubing to the bleeder and run it into an empty jug. The old brake fluid will be recycled with your waste oil later. Tell the helper "Pump it up". A half a dozen slow, gentile pumps on the pedal. Then tell them "hold it". They must hold the pedal until you say "Okay". While they hold the pedal, you open the bleeder 1/4 turn which will release a mixture of old brake fluid and, perhaps, air. When the flow has stopped, close the bleeder, then tell the helper "Okay, pump it up", and "hold it" and repeat until the fluid in the clear tubing has become much cleaner than when you started. About six to eight fluid ounce should do it. The helper must keep pressure on the pedal whenever you have the bleeder open. Make sure the helper refills the master frequently. If it goes empty, you will need to start over again. Pour slowly to prevent bubbles. No pedal pressure when refilling the master.
After the fluid runs clear from the right rear, move to the left rear. This bleeder will not take nearly as long, as the majority of the fluid has already been flushed from the line through the right rear. Next is right front, then left front. I like to quickly repeat the entire procedure, just to be sure.
Important things to remember:
*Don't break a bleeder, or the job will become much more difficult! Clean them up and anti-sieze to ensure future successes.
*Your pedal pumper must listen to your commands, and be diligent with the pressure.
*The helper must keep fluid in the master. Always replace the cap after refilling. Otherwise, the fluid will shoot up like a Yellowstone geyser when the pedal is released.
* Watch the fluid coming through the tubing. You can see bubbles and impurities flow through.
When you are done, you should have a nice firm pedal, and the brakes should not pull or dive when the van is driven and stopped.
This should be done every two years. Clutch fluid, too!
Have fun!
Regards,
Ric _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
Posted: Wed Aug 09, 2006 9:04 pm Post subject: |
Man you guys are the best _________________ 82 Air-cooled Westy (Lola)...My other vehicle is a subway. |
jacob. Samba Member
Posted: Wed Jan 27, 2010 9:59 am Post subject: |
I figured I'd resurrect an old thread instead of posting a new one. I'm doing this tomorrow or friday, and I don't know where the bleeders are. Do I have to take the wheel off? Any pictures of where the bleeders are located? I get how the process works (same as a motorcycle, except that had 2 pistons), and i'm confident about that, but I just don't know where the bleeders are.
thanks,
Jacob. _________________
RCB wrote: |
jacob gets razzed a lot cause he has the only GEX engine thats lasted longer than half an oil change. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Wed Jan 27, 2010 10:04 am Post subject: |
No you don't need to take the wheels off, but if this is your first time, I would suggest pulling the wheels. The bleeders should be obvious on front and rear. The rear bleeders are next to the steel line where it connects to the wheel cylinder. I think 87 is single piston calipers. The bleeders should be near the top inner of the caliper. Old ones are easy to snap off. Don't rush it. _________________ ☮️ |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Wed Jan 27, 2010 12:50 pm Post subject: |
Once you locate the bleeders, slow down!
Spray them with PB-Blaster or something similar to help loosen them. let it sit for a while, maybe over night. Then do the job. If they have not been bled for a while, they may be seized and they do tend to break if you force them. Then you are F###ed.
The job is easy, but don't force anything. _________________ -- 1987 Westfalia automatic (Captain Vino) |
whafalia Samba Member
Joined: January 28, 2009 Posts: 685 Location: San Francisco
Posted: Wed Jan 27, 2010 6:23 pm Post subject: |
And use a box-end wrench. |
morymob Samba Member
Posted: Wed Jan 27, 2010 8:25 pm Post subject: |
so far the ones i have run into are 7 MM bleeders. Where did u get new girling calipers/ i've had a bitch of a time finally getting rebuilds. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Wed Jan 27, 2010 8:50 pm Post subject: |
Just took a look, they even look like a gold finish too! Thanks for info. |
epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Thu Jun 01, 2017 5:38 am Post subject: |
Great bleeding tutorial! I will be bleeding the entire system today or tomorrow.
ONE QUESTION ONLY - regarding WORK SEQUENCE:
1) REAR RIGHT WHEEL
2) CLUTCH
3) REAR LEFT WHEEL
4) FRONT RIGHT WHEEL
5) FRONT LEFT WHEEL correct? i.e. "start with the furthest away from the master, then work towards the master..."
riceye wrote: |
Here you go:
Have fun!
Regards,
Ric |
_________________ www.edwardpowell.com |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Thu Jun 01, 2017 7:03 am Post subject: |
epowell wrote: |
1) REAR RIGHT WHEEL
2) CLUTCH
3) REAR LEFT WHEEL
5) FRONT LEFT WHEEL correct? i.e. "start with the furthest away from the master, then work towards the master..." |
I would do the clutch separately from this sequence, i.e. stick with finishing the brakes once you begin on the brakes.
The pedantic among us might point out that the LR is farther from the MC than the RR (as the lines run vs as the crow flies) but I don't think it matters.
I do not own and have seldom seen a 6-point box wrench, I do the initial loosening of the bleeder with a 6-point socket and a tiny ¼" ratchet to remind myself not to wrench too aggressively. If it is pretty stuck more force is possibly not the best course of action. Heat, PBlaster & soak time may be needed. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6356 Location: Honolulu,Hawaii and France
Posted: Thu Jun 01, 2017 9:30 am Post subject: Re: new calipers |
I use an old cap with no sensor in, and a tire valve mounted to the cap after drilling.
Then bicycle pump, and you can bleed yourself without ruining the cups inside the master cylinder by pumping many times to the floor.
I also cleaned the whole system with rubbing alcohol and then switched to DOT5, but that's optional. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
amwaj Samba Member
Joined: February 18, 2017 Posts: 68 Location: the desert
Posted: Fri Jun 02, 2017 10:06 pm Post subject: Re: new calipers |
thats a neat idea _________________ the best way to make a small fortune in life, is to start with a big one, and become afflicted with Vanagon-itis |
