Front Drum to Disc brake conversion with dropped spindles
Chopchop
Chopchop is offline
PostPosted: Sun Jun 07, 2009 6:02 pm    Post subject: Front Drum to Disc brake conversion with dropped spindles Reply with quote
Hi
This is my first post. I've been digging through thesamba.com archives but I haven't been able to find a post on this specific subject.
I have 4 wheel drum brakes and dropped spindles on the front. I bought the car as it is and I don't know how much of a drop I have with these spindles but I like the ride height right where it is now.
I want to upgrade to front discs - without spending any more money than I have to. Do I have to buy new dropped spindles or can I use the dropped spindles already on the car ?
I have seen many disc brake conversion kits on-line. Can anyone please give me first hand advice as to who I should buy from ?
Additionally, does anyone know of an internet site that I can decode my VIN to find out what year the pan is ?
Thank you for any help you can give me,
Dave
dubkrzy
dubkrzy is offline
PostPosted: Sun Jun 07, 2009 6:31 pm    Post subject: Reply with quote
I used the kit from CB.
Works great and was easy to install.
Don't know about pan #s, but you may try using the search.
vwracerdave wrote:
always modify the cheapest part and never modify the most expensive part.
Glenn wrote:
Sure... you can take a grinder to them. You can also use an adjustable wrench to assemble it.
Jake Raby wrote:
That looks like Tom Jones
Chopchop
Chopchop is offline
PostPosted: Sun Jun 07, 2009 7:32 pm    Post subject: Reply with quote
Did you have dropped spindles when you started ?
Did the CB kit come with dropped spindles ?
6t3vdub
6t3vdub is offline
Try the Technical tab at the top of the page...whole section on VIN Numbers.
1963 Sedan - L87 with 27,501 original miles
Chopchop
Chopchop is offline
PostPosted: Sun Jun 07, 2009 7:39 pm    Post subject: Reply with quote
Thank you. I didn't know about the section on VIN s
Dave
Hotrodvw
Hotrodvw is offline
PostPosted: Sun Jun 07, 2009 9:24 pm    Post subject: Reply with quote
You can't buy a CB kit to fit drop spindles, w/o buying the kit with the spindles. Ask me how I know.
You mightbe ahead buying a kit w/ the spindles, and then sell the ones you have now separately. The ones in the kit will be slightly different than what you have now. There are caliper mounting bosses cast into the spindle. As for anything other than CB, I can't say.
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
Chopchop
Chopchop is offline
PostPosted: Mon Jun 08, 2009 6:32 am    Post subject: Reply with quote
Okay, thank you for filling me in on the CB kit and spindle issue.
You'd think someone would offer a kit to retrofit the drum-brake dropped spindles with new discs..
Hotrodvw
Hotrodvw is offline
PostPosted: Mon Jun 08, 2009 7:06 am    Post subject: Reply with quote
Well, I did that exact thing.....on my own. Laughing
'67 Sunroof
Eric
lots of money!
Hose & Fittings
Chopchop
Chopchop is offline
PostPosted: Mon Jun 08, 2009 7:55 am    Post subject: Reply with quote
So you used drum brake dropped spindles and a CB disc brake conversion kit on them ?
What did you have to do to make the CB kit fit your dropped spindles ?
Dan2973
Dan2973 is offline
PostPosted: Tue Jan 26, 2021 1:39 pm    Post subject: Reply with quote
Hey could you explain or show photos of how you adapted a drum drop spindle with the new CB disc brake kit?
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Tue Jan 26, 2021 2:51 pm    Post subject: Reply with quote
You cannot use drop spindles and CB front disc brakes. It won't work. I've looked many times.
From what I have found. All lowered spindle disc brake upgrades. Require a disc brake drop spindle kit. The bad news is, the width of the front end is + 1.5".
