orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1516 Location: South Hadley Mass
Posted: Sun Aug 13, 2006 11:08 am Post subject: lowering the idle speed on a 36hp |
so right now the idle in the 60 is a bit high for my likings. its a 28 PCI solex and i was wondering if it might be the manual choke or if it has something to do with the screws? how do i lower it without messing it up to bad. _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation. |
oc63rag Samba Member
Joined: June 03, 2003 Posts: 2625 Location: Huntington Beach, CA
Posted: Sun Aug 13, 2006 11:44 am Post subject: |
This should help:
http://www.vw-resource.com/30PICT2.html _________________ Designed for four soldiers and a machine gun...also for family use.
My food baby is crowning. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Sun Aug 13, 2006 7:54 pm Post subject: |
With the manual choke you can get a high idle if the cable is too tight. Unlike the auto choke, there is no separate adjustment at the choke itself--it's just the cable end adjustment. Then check the idle speed adjustment screw. |
Mr. Loaf Samba Member
Joined: March 30, 2005 Posts: 2098 Location: Okra, Oklahoma
Posted: Mon Aug 14, 2006 6:21 am Post subject: Choke |
Look down your carburator with the choke off and check to see that the choke plate is verticle and wide open. You can adjust it by loosening the clamp on the side of your carb and moving the cable housing to suit your needs. The idle screw is the big screw on your carb that faces the rear of your car. Clockwise increases idle and counter clockwise decreases it. Also, check to see that your return spring, the one on your throttle cable is not binding. If it hangs up your idle will be high. _________________ Never drive faster than your Angel can fly
$24,100 was too hard to resist................. |
Posted: Mon Aug 14, 2006 9:23 pm Post subject: |
the idle screw worked. now what happens if the idle is to low? _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
KTPhil Samba Member
Posted: Mon Aug 14, 2006 9:28 pm Post subject: |
Um, turn it back the other way? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
