Tom N. Samba Member
Joined: May 21, 2005 Posts: 781 Location: dReading, PennsylRAINia
Posted: Sun Aug 13, 2006 8:59 pm Post subject: 1600 w/ 40s... Jets/ Venturies? |
I am about to help a friend install a set of Italian Weber 40s on a stock 1600 DP, with 009. I am asking for a good place to start as far as jets, venturies, and anything else you may want to add. I think that this setup is overkill for this engine, but it is his choice. Can we make this work? I am not sure what jets/ venturies are installed at this point.
Thank you,
Tom |
stan_tichomirov Samba Member
Joined: May 24, 2005 Posts: 1719 Location: San Francisco, CA
RIS Samba Member
Joined: December 18, 2003 Posts: 3043 Location: Youngstown, Ohio
clearsurf2001 Samba Vaccinator
Joined: February 26, 2004 Posts: 1671 Location: Dave-AKA-fortyeye-Oceanside, Ca
Posted: Sun Aug 13, 2006 9:10 pm Post subject: |
Don't forget proper fuel pressure. _________________ Get ready for the injection
EverettB wrote: |
Make sure it is coherent. Rodney |
mharney wrote: |
I think Glenn has an EMPI crank in his engine. |
Tom N. Samba Member
Posted: Sun Aug 13, 2006 9:24 pm Post subject: |
Proper fuel pressure being what?
I know that currently there is a mechanical fuel pump installed, but can be swapped out for an electric one. Kads take 2 1/2 psi, what is required for Webers? Guess we will have to get a regulator too.
Stan, that link is awesome!!! Thank you. Between yours and RIS reccomendations.... we will have a good head start.
I know that this is somewhat related... Stan, what mileage do you get, and overall, anyone else (RIS, etc) what mileage are you getting.
RIS, I agree that these carbs are not overkill if tuned correctly, hence venturie/ jet changes before the carbs are installed. When working in 112 deg heat, we want to be ahead of the game, before we melt. |
spongeworthy Samba Member
Posted: Sun Aug 13, 2006 10:02 pm Post subject: |
what about an 1835cc , two 44s, and a stock twin pea shooter muffler... can this be done??? |
Bruce Samba Member
Posted: Sun Aug 13, 2006 11:50 pm Post subject: |
Tom Newpher wrote: |
I know that currently there is a mechanical fuel pump installed, but can be swapped out for an electric one. . |
Webers need 3psi or less. You don't need an electric pump, the stock mechanical pump will more than suffice. |
mharney Samba Member
Posted: Mon Aug 14, 2006 5:16 am Post subject: |
Have to be careful with Italian carbs. If you have a dead or weak spot around 1/4 throttle (2500 RPM range-ish), that you cannot get rid of even if your floats are right, and your jets are right, there's a chance that the idle air bushings are oversized. It happens more on the 36 IDFs, but it can be the case here too. Check this:
http://www.thesamba.com/vw/forum/viewtopic.php?t=177232 |
Posted: Mon Aug 14, 2006 8:07 am Post subject: |
Mileage.. hard to say, I never measured it. This is my play car, and not daily driven. It seems the mileage with the Webers was close to, if not better then what I was getting with the single 34PICT. It's hard not to step on the gas though.. Currently, the engine is out for maintenance
Oh yeah, my fuel pressure is at 3.5psi, measured.
Stan _________________ Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build |
Posted: Mon Aug 14, 2006 8:13 am Post subject: |
Yeah, mine started out as maintenance too Stan. Be careful. A few slips with the wrench and your case will be apart! lol |
Posted: Mon Aug 14, 2006 9:49 am Post subject: |
I already replaced the transaxle mounts, which was the original reason for taking the engine out.
I want the case to be apart! All of the top-end stuff is off and has been cleaned thoroughly already. Now I'm stuck because I can't get the gland nut off.. Plans are to replace all bearings, put in a Web 118 and new lifters, lighten the flywheel to 12 pounds, 8-dowel my stock crank and flywheel. I'd appreciate any suggestions or comments.
Jansen Enterprise
My 1835cc build
