Mr. Loaf Samba Member
Joined: March 30, 2005 Posts: 2098 Location: Okra, Oklahoma
Posted: Wed Aug 16, 2006 6:42 am Post subject: What Happened??? |
Yesterday I was out driving my 58 Type 1 and all was well until my motor bogged down and died. Turned off the ignition and popped open the deck lid and saw fuel running out of the throttle shaft of my carb. Lots of fuel. No fire though, whew! The carb is a 28 PCI and the motor is a stock 36 HP that is Judson Supercharged. I first thought that maybe the Judson carped out. Tried to restart the car and fuel once again starts coming out of the throttle shaft and the motor will not start. The carb is like new, was rebuilt by Ed Fall here on the Samba, and has never failed me before. I have had it on the motor for about 4 months now. Got out my tools and pulled the carb off thinking that maybe my float was stuck. Not an easy job to do sitting on 100 degree asphalt by the side of the highway. Took the top off of the carb to check the float but could find any thing abnormal. Reassembled every thing and tried to start the car. She fired right up with no leaks any where. So, what I am asking is did I magically fix something by taking the top off of the carb? I am thinking that the float stuck. I put a new fuel filter and lines on the car 3 days ago. Any ideas? _________________ Never drive faster than your Angel can fly
$24,100 was too hard to resist................. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Wed Aug 16, 2006 6:46 am Post subject: |
If the float sticks, it will close off the check valve located inside the float bowl which in turn stops the flow of fuel. Sounds like the opposite problem in that you had excessive fuel pouring into the carb & the check valve wouldn't close. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Wed Aug 16, 2006 7:02 am Post subject: Float |
Thank you for your reply, Rare Air! So what do you think caused the problem. Fuel pressure too high? _________________ Never drive faster than your Angel can fly
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed Aug 16, 2006 7:14 am Post subject: |
Hi mkkraemer,
Things that could be causing the leak are:
1. Too long of fuel pump push rod, causing too much fuel pressure. Which in turn pushes the shut off valve in the carb open, and even the shut off float down.
2. Sticking, loose, or bad shut off valve, or missing, damaged gasket for the valve.
3. Too heavy of shut off float, or it is cracked.
4. Have heard of a crack occuring in the float chamber also! _________________ In Stereo, Where Available! |
Posted: Wed Aug 16, 2006 8:42 am Post subject: Float |
Thank you EricandBarb, What I do not understand is that this is the first time that this has happened and I drive the car every day. When you run a Judson on a 36HP motor you have to install a heavier spring in your fuel pump. I did this and am now wondering if my pressure is too high. The fuel pump push rod is the right length. I think I will check my fuel pressure using a guage and see what the Judson sight says is within specs. Thank you for your reply! _________________ Never drive faster than your Angel can fly
Posted: Fri Aug 18, 2006 8:41 am Post subject: So............. |
I have driven the Bug for the past 3 days, even got her up to 65 MPH for 30 miles and the original problem has not reoccured. Wish I knew what happened! _________________ Never drive faster than your Angel can fly
