bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4349 Location: United States, Iowa
Posted: Fri Jun 17, 2022 7:28 am Post subject: Re: Good deals on Nice Vans |
LAGrunthaner wrote: |
Yes I agree.
What surprises me is how much the Vanagon/Westy is in general. The high mileage (anything over 150K) is still starting at 20K and even reaching 50K. I know nothing about the Vanagon. Can anyone explain how many miles the Vanagon engine can reach before most step away?
I try to do most of the work on my 67 Westy, it's easy and simple but there will be a day that I upgrade to roll up windows and heat for winter. My daily driver is an 85 mini truck so I'm starting to think the Vanagon is the way to go in transition.
I don't know if there is an explanation regarding how many miles before stepping away. I bought my '87 with 270K mi on the engine, and did some top end work, and now its close to 340K mi. The rod bolt failure seems to be pointed at by many skilled, and knowledgeable owners and mechanics. However, there are some that say that is not as easily assigned the blame as plenty of other factors. The simple answer is to take care of the rig, drive it as intended, not like you stole it. Also, the rod bolt mystery is (almost) easily resolved. There are brand new rods to be found from several big vendors. All you need to do is to follow the 1.9 WBX specs to torque the bolts, and NOT Torque To Yield as the 2.1. One revered builder that sometimes posts here explained that it is not the bolt that is the problem, it is how TTY is actually partially destroying the bolt. If the tool that did the TTY on your particular engine was out of spec, or the bolt had been manufactured a little off, well, obviously the failure LOOKS like the mentioned rod bolt failure. The actual truth is that nobody can actually know. My advice would be to find a spare engine that came out of a running rig and install new rods/bearings/etc. You can get the rods out without splitting the case. I'm not saying any of that would be easy, but it sure would be peace of mind. Engines often can be found by calling around to places that do transplants.
Since you are an air cooled driver, you must have at least some basic skills to keep it running. If you've been inside your ac engine, there is very little difference, and quite a few parts that are exactly the same. I also came from the air cooled world and although there is a learning curve to the WBX, you will most undoubtedly be a fast learner.
Perhaps your question about stepping away is based on seeing that some folks transplant other engines into their rigs. I was hell bent on doing a transplant when I first got my '87 (my first Vanagon) and collected all the needed bits. I never drove a transplanted bus so little did I know about what the transplant would do. I've heard that a Subaru 2.5 will eat a manual transmission in short order if you don't get a proper rebuild done on it specifically for the 2X(+) 'power' that is now going to go straight out your foot. The Automatic trans is supposedly more able to handle it though. I did not put the Subaru in my '87 but instead, when my daughter's 2.1WBX (with auto trans) blew its floppy water jacket seal and all the coolant dumped, I steered the pile of Subi stuff on her Much later, I acquired an already converted TinTop with an EJ22 and manual trans. I truly fear for that trans, as it has been mated to the EJ22 for ~10 years. Super fun to drive though
However it turns out for you when you move to a Vanagon, I am sure you will enjoy it if you do the work of maintaining it. Nothing 30+ years old will be fun to drive or reliable without good maintenance. But, you already know that as an old bus owner. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
riceye Samba Member
Joined: March 09, 2006 Posts: 1661 Location: Caledonia, WI
Posted: Sat Jun 18, 2022 1:01 pm Post subject: Re: Good deals on Nice Vans |
In the Bozeman area.
https://bozeman.craigslist.org/cto/d/belgrade-1987-volkswagen-gl-van-retro/7497939381.html _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
campism Samba Member
Joined: September 07, 2007 Posts: 4491 Location: Richmond VA
Mckinleyvillian Samba Member
Joined: July 22, 2021 Posts: 506 Location: Macktown, CA
Posted: Thu Jul 14, 2022 12:35 am Post subject: Re: Good deals on Nice Vans |
that van must have been in the barn behind it for a long, long time. I grew up in that area of Massachusetts and lost more than a few vehicles due to road salt. _________________ so many roads i know
all i want is one to take me home
85 Vanagon GL 1.9 stick |
Tobias Duncan Samba Member
Joined: January 15, 2013 Posts: 1390 Location: Taos NM
Posted: Wed Jul 20, 2022 11:32 am Post subject: Re: Good deals on Nice Vans |
https://santafe.craigslist.org/cto/d/arroyo-seco-1990-volkswagen-vanagon/7510749083.html
Found this on my daily craigslist search. This belongs to a buddy of mine that has a history of selling stuff below market value. He sold his last westy to a mutual friend about 12 years ago. Same deal, mechanically sound, needed bodywork and a paint job which they had done in Albuquerque. I still see them driving it around town all the time.
I have only seen this van once when it was taken apart in his shop but I do know that he has been through every inch of the drivetrain and he is a highly competent mechanic .
As I recall its a rust free New Mexico van but I did not bother to read the absolute novel of an ad he posted |
vwolder Samba Member
Schnippzle Samba Member
Joined: February 04, 2021 Posts: 288 Location: Swede in London, UK
Posted: Fri Jul 29, 2022 1:35 am Post subject: Re: Good deals on Nice Vans |
Seen this one on Busman. Certainly a collectors item and a very interesting item at that. _________________ 1988 Caravelle - FB25B - Syncro converted
2016 MB E63 AMG S - The daily driver
2019 Harley Davidson FXFBS Fat Bob - The leisure |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 674 Location: Santa Cruz, CA
Posted: Sun Aug 07, 2022 12:06 pm Post subject: Re: Good deals on Nice Vans |
https://sfbay.craigslist.org/scz/cto/d/aptos-1985-vw-westfalia-vanagon/7516197720.html
1985 VW Westfalia Vanagon - $20,000 (aptos)
1
© craigslist - Map data © OpenStreetMap
Hillcrest Dr near Mar Vista
(google map)
1985 1985 VW Vanagon
condition: excellent
fuel: gas
odometer: 109675
odometer broken
paint color: brown
title status: clean
transmission: automatic
type: bus
This is a Wolfsburg Edition camper van in excellent condition. One owner with complete maintenance records. _________________ 1991 tin top GL
Some BMWs. |
revolution337 Samba Member
Joined: May 23, 2009 Posts: 372 Location: Pennsylvania
Posted: Sun Aug 07, 2022 6:16 pm Post subject: Re: Good deals on Nice Vans |
1988M5 wrote: |
1
(google map)
fuel: gas
odometer: 109675
odometer broken
paint color: brown
title status: clean
type: bus
This is a Wolfsburg Edition camper van in excellent condition. One owner with complete maintenance records. |
I never understood why people post "for sale" ads like this (assuming its real, and not a scam). One 10 foot photo, and two sentences that really don't do anything to describe the vehicle. GLWS I guess? _________________ 1982 Westfalia AEB 1.8t
2017 VW Golf Sportwagen
2001 Audi A4 4.2 V8 swapped
2000 BMW Z3 roadster
-Mark |
1988M5 Samba Member
Posted: Mon Aug 08, 2022 2:59 pm Post subject: Re: Good deals on Nice Vans |
revolution337 wrote: |
1988M5 wrote: |
1
(google map)
fuel: gas
odometer: 109675
odometer broken
paint color: brown
title status: clean
type: bus
I never understood why people post "for sale" ads like this (assuming its real, and not a scam). One 10 foot photo, and two sentences that really don't do anything to describe the vehicle. GLWS I guess? |
This isn't my van, simply just a Craigslist AD I happened across and thought it would be kind to share to the Samba community. _________________ 1991 tin top GL
Some BMWs. |
1988M5 Samba Member
Posted: Mon Aug 08, 2022 6:07 pm Post subject: Re: Good deals on Nice Vans |
I spoke with the woman selling the van and because it's close, I'm going to check it out tomorrow morning. $20K is a big number for me to spend on a vehicle I don't need but if it's super clean, I may just buy it just to flip or give to my dad. Advise is wanted here for value.
Thanks,
BK _________________ 1991 tin top GL
Some BMWs. |
Posted: Mon Aug 08, 2022 6:32 pm Post subject: Re: Good deals on Nice Vans |
1988M5 wrote: |
1988M5 wrote: |
1
(google map)
fuel: gas
odometer: 109675
odometer broken
paint color: brown
title status: clean
type: bus
This isn't my van, simply just a Craigslist AD I happened across and thought it would be kind to share to the Samba community. |
I understood that you are not the seller of this van. I was just stating a gripe in general I have with postings like that. I can see the confusion though. Thanks for sharing the post, and let us know what the van is all about once you see it in person. _________________ 1982 Westfalia AEB 1.8t
-Mark |
1988M5 Samba Member
Posted: Fri Aug 12, 2022 12:35 pm Post subject: Re: Good deals on Nice Vans |
https://sfbay.craigslist.org/scz/cto/d/soquel-vw-westfalia-camper-1989/7520473505.html
VW Westfalia Camper 1989 - $18,900 (soquel)
I'm going to check it out tomorrow.
How much discount do you folks think a salvage title is worth?
Cheers,
Some BMWs. |
EL31415 Samba Member
Joined: December 13, 2009 Posts: 192 Location: Los Angeles
Posted: Mon Aug 15, 2022 3:47 am Post subject: Re: Good deals on Nice Vans |
1988M5 wrote: |
Thanks,
BK |
Add $10k fir future mechanical fixes. _________________ ~~~~~~~~~~~~~~~~~~~~
1985 Westy |
elizer Samba Member
Joined: May 02, 2016 Posts: 1462 Location: Northern Virginia
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 784 Location: WestWorld Nanaimo BC
slapin Samba Member
Posted: Tue Sep 27, 2022 3:30 pm Post subject: Re: Good deals on Nice Vans |
If you're in the US, it's ~$18,500 for a syncro, which would be nice. That spare tire swingarm bolted to the side of the car hurts my sensibilities. |
RainierSyncro Samba Member
Joined: February 26, 2013 Posts: 806 Location: Seattle
Posted: Mon Nov 21, 2022 1:51 am Post subject: Re: Good deals on Nice Vans |
Decent syncro with some body work required: https://www.blocket.se/annons/stockholm/vw_t3_syncro/104748684
As long as you don't mind importing it from Sweden About $8300. _________________ 1988 Caravelle - FB25B - Syncro converted
4Gears4Tires Samba Member
Posted: Mon Nov 21, 2022 12:24 pm Post subject: Re: Good deals on Nice Vans |
It has new wheels and tires. Looks like someone was trying to restore it. Why is it for sale? Blown transmission? _________________ '87 Syncro
