73kombi Banned
Joined: April 11, 2006 Posts: 1215 Location: ~The London Bridge, AZ~
Posted: Fri Aug 18, 2006 9:47 am Post subject: How much is too much? Horn Voltage... |
Ok, so I got the day off today(unexpectedly), and it's Bus, Bus, and more Bus.......Installed the SVDA(a cardone rebuilt) and Bessie seems almost turboesque.......I can pull the 8% grade up into town(9500ft elevation) at over 40 mph instead of 33 mph, and acceleration is better and smoother! Best $60 I have spent on Bessie...Who ever decided the 009 was a good idea for a bus, needs to be taken out in the woods and SHOT!
And now to the question you have all been waiting for.....I took off the steering wheel, with my knees under the wheel pushing up hard and smacked the shaft using a maul and a wood dowel. It took a few smacks, but just as steponmebbbom says, it will pull off without a puller. I reconnected the unconnected wire to the insulated shaft housing, black taped it all up good, and all is well.
Execpt that I seem to be showing a 4~5 volt draw on the wires right at the horn all the time with the key on. My horn is non-functional at the moment so I dont know if that is acceptable or not. When I depress the horn button it goes right up to 12.75.....I am waiting for Richard at OE VEE DUB to get some more in stock, as his store is just up the highway from me.
So, what say the bus gurus of the Samba? Is a 4~5 volt draw too much? Do I need to replace the wire in the shaft?
On edit: If your bus is running, or just with the key ON, what kind of voltage do you have at the horn wires without depressing the button?
Peace
p.s. Thank Budha this site exists, as I have really learned so much from lurking, and reading a zillion posts!
Joined: June 14, 2002 Posts: 1663 Location: Palominas AZ
Posted: Fri Aug 18, 2006 10:20 am Post subject: |
Are you saying the draw is all the time? Even when the key is off? It may indeed be too much --- SOMETHING is grounding out somewhere it sounds like - possibly. I aint a horn guru but in my own experience
x = reading
if x=0 volts = off
if x > 0 volts = on
Congrats on the Cardone --- I did the same for my 71 and I am very happy as well. _________________ Ryan
1963 Beetle
73kombi Banned
Posted: Fri Aug 18, 2006 10:46 am Post subject: |
Yeah, I'm saying when the key is off it's .016 volts......digi meter. But when the key is on, I'm showing 4 volts at the horn, which makes me believe I'm getting a small grounding somewhere in the column, which really sucks.......as it's all back together now.
Just wondering here if that is kind of normal (I know it's not), or if other folks have a similar kind of working horn. In other words, if a working horn is getting 4 volts, will it remain quiet?
Sound confusing?
peace |
barefootwestie Samba Member
Joined: September 19, 2005 Posts: 1551 Location: Johns Island, SC
Posted: Fri Aug 18, 2006 10:52 am Post subject: |
You are at the stage I wanted to be before I decided to pull my steering column to fix a few other issues. Have you tried to adjuest the horn at all, to see if the horn is functioning properly? I beleive I read in the Bentley, that the adjustment should be set at the lowest possible amperage pull AND the horn sounds proper. Have you tried to pull th ehorn off and get it to work properly with another power source? _________________ My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia |
73kombi Banned
Posted: Fri Aug 18, 2006 11:01 am Post subject: |
The horn is dead, no worky on the bench, no worky at all.......I can afford the $12 for a new one, I'm even considering putting on an aftermarket ahoooogaa type horn.
Does anyone have any ideas on ahoooga horns and where to get them? Like checker or advance auto? |
Opossum Samba Member
Joined: February 26, 2005 Posts: 735 Location: Islets of Langerhans
Posted: Fri Aug 18, 2006 12:48 pm Post subject: |
Aaahooga Booga!! I put two semi truck air horns under my bus on the left and two old cadillac horns under the bus on the right. Please cut in front of me. _________________ "You can lead an aircooled to water, but you can't make it drink"
"Live and learn or crash and burn"
"It's only Cool, If it's Air-Cooled"
Virginia Whiteface (Opossum) the first VW
Camper Special Club Member
1973 Orange Westfalia Hard top, Original owner |
73kombi Banned
Posted: Fri Aug 18, 2006 1:01 pm Post subject: |
Semi trick horns run on compressed air........did you install an air comp on the motor? or do you just have a semi truck simulated electronic horn?
I am thinking now that stock will not be loud enough to cover my stereo.......so perhaps I will install an aftermarket noise maker under Bessie........
But I am still concerned about the constant 4 volts at the horn with the key ON. I'm sure it's a mild ground short in the column now!
peace |
Posted: Fri Aug 18, 2006 2:16 pm Post subject: |
They have their own compressor and tank. go to http://www.groverproducts.com/index.html _________________ "You can lead an aircooled to water, but you can't make it drink"
