barefootwestie Samba Member
Joined: September 19, 2005 Posts: 1551 Location: Johns Island, SC
Posted: Wed Aug 23, 2006 5:37 am Post subject: Source for Steering Support Ring |
I'm looking for a source for a support ring that is located in the Steering Column.
If you have a Bentley Manual, it is shown on Page 22 of Chapter 2 in Figure 9-12. This is the part that goes between the spring and the steering column bearing.
I've checked most of the places I'm aware of(Bus Depot, Bus Boys,etc) but have been unable to locate one. Is this a part that cannot be purchased new?
Thanks _________________ My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Wed Aug 23, 2006 7:25 am Post subject: Re: Source for Steering Support Ring |
lstoudenmire wrote: |
Thanks |
Your sig says you have a 73 bus?
If yes, the column pictured in figure 9-12 on page 27 of the 68-79 Bentley is a 68-71?. Look at the turn signal mount.
Your 73 should use this style of turn signal switch:
The column pictured here: http://www.ratwell.com/technical/Microfiche/t203800.gif
is close to yours but is from vin 214 2164 060. It uses the later style steering wheel. #36 is called a thrust ring and is part number 211 415 589C.
Your 72? to early 74 column uses a thrust ring also, but it is part number 113 415 589A.
Only the column pictured in the Bentley shows it as 'support ring'.
Neither of the 2 part numbers I listed are available new anymore. |
Posted: Wed Aug 23, 2006 8:05 am Post subject: |
Yes, mine is a '73 and my turn signal swithc does look like the one pictured. I thought I had the right figure but I'll take another look this eveniing. _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
steponmebbbboom Samba Member
Posted: Wed Aug 23, 2006 3:58 pm Post subject: |
Is it a steel ring about 1" in diameter, split at 12 o clock, three halfmoon cutouts at 3, 6, and 9 o clock? With the cross-section shaped like an "L"? |
Posted: Wed Aug 23, 2006 4:37 pm Post subject: |
Karl - According to mine Bentley it says the figure is for Steering Columns '68 - '74. I have the edition published in 1979. Maybe ours are different editions.
steponmebbbboom - I'm not real sure, as when I took everything apart it was in 4 pieces.I'll have to check my screws and bolts box in the bus in a few minutes and see if I still have the pieces.
Update: I must have thrown the pieces away. _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
Posted: Wed Aug 23, 2006 5:30 pm Post subject: |
well Im willing to bet it's the one you need, It came out of a '74.
PM me your address and I'll drop it in the mail for you. |
HerrFink Samba Member
Joined: November 14, 2013 Posts: 24 Location: United States
Posted: Wed Aug 27, 2014 3:43 pm Post subject: |
I'm taking apart my steering and just found the "support ring" in pieces... it is the one (per Bently diagram 9-12) which goes just below the spring. Anyone have an idea if this is available anywhere or do I need to find a junkyard? |
SGKent Samba Member
Posted: Wed Aug 27, 2014 3:54 pm Post subject: |
are we talking part number 36 in the diagram. If so used ones is all you will find. If you need it asap contact Ken Madsen at BUSCO or Chris at Busted Bus and they can get you one. I just got some parts from Ken a few days ago.
diagram page:
http://www.michaelknappmann.de/bulli/michaelk/vw_bus_d/fiche/t203800.html _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Aug 27, 2014 4:14 pm Post subject: |
hmm it shows as part number 2 in the diagram I have.. page 27, diagram 9-12 Circular ring with an inverted L shape cross section and there is a small notch making it about 340 out of 360 degrees in total.
Posted: Thu Aug 28, 2014 9:27 am Post subject: |
Wondering if anyone thinks that spot welding it and then grinding it would work well. |
SGKent Samba Member
Posted: Thu Aug 28, 2014 10:26 am Post subject: |
Herrfink - since you don't post what year you are working on it is really hard to give you the right image. Buy a used one if you want it right. The one on the late bay is spring steel so if the early one is also and you weld it, then you will have to heat treat it again. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Tcash Samba Member
Posted: Thu Aug 28, 2014 3:34 pm Post subject: |
Thanks! Sorry I just updated my signature to include my first ever VW project. in case it doesn't show up.. it is a 1971 pop top camper first registered in California in 1970 with original plates and been registered in California ever since. _________________ -1971 Bay Window Westfalia PopTop Purchased and first registered & Sold in CA in 1970. |
70Crew Samba Member
Joined: June 12, 2006 Posts: 776 Location: Grand Rapids, MI
Posted: Tue Oct 11, 2016 6:26 pm Post subject: |
HerrFink wrote: |
Does anyone happen to have a photo of this support ring (AKA thrust ring, part # 113 415 589A, for early bays)? Is it plastic or metal? My column has a lot of play so I am guessing mine is missing. I'd like to track one down in my parts stash before I pull my wheel but I can't tell from the exploded parts diagram what it really looks like. _________________ 1970 Crew Cab |
Tcash Samba Member
Posted: Tue Oct 11, 2016 7:14 pm Post subject: |
70Crew wrote: |
HerrFink wrote: |
Does anyone happen to have a photo of this support ring (AKA thrust ring, part # 113 415 589A, for early bays)? Is it plastic or metal? My column has a lot of play so I am guessing mine is missing. I'd like to track one down in my parts stash before I pull my wheel but I can't tell from the exploded parts diagram what it really looks like. |
http://www.thesamba.com/vw/classifieds/detail.php?id=1903247
70Crew Samba Member
Posted: Tue Oct 11, 2016 7:27 pm Post subject: Re: Source for Steering Support Ring |
Interesting.... I don't ever recall seeing one of those. Nice that the photo you posted was for an active classified ad, thanks TCash! _________________ 1970 Crew Cab |
