Douglas Denlinger Samba Member
Joined: May 23, 2003 Posts: 1381 Location: Arizona's version of the east coast
Posted: Mon Mar 27, 2006 11:02 am Post subject: 58 ghia choke cable HELP |
Well, I'm pretty much down to this......I need the choke cable wire that runs thru the coiled tube that has the hard rubber protective sleeve.
I just need the wire!!! Anyone?
I tried KGPR and even bought a new one from WBW (for a bug) very nice, but it's not long enough....aaarrrrruuuuugggggh.
Any help much appreicated. Thanks
Douglas _________________ Transporter Restorations
Upholstery Haus
Active 23 Window Samba Collector/Restorer,since 1986 |
RockStock Samba Member
Joined: November 26, 2004 Posts: 3924 Location: England
Posted: Mon Mar 27, 2006 12:21 pm Post subject: |
yes, ghia choke cable are longer than beetle i believe
a bus one maybe? _________________ -StockRocks- |
65ghia Samba Member
Joined: May 29, 2001 Posts: 224 Location: Hayward ,CA
Posted: Mon Mar 27, 2006 12:53 pm Post subject: |
some people have used MTN bike cables&housing |
retrowagen Samba Member
Posted: Mon Mar 27, 2006 1:49 pm Post subject: |
The Ghia-specific item is very hard to find! I exploited my European contacts a few years ago and bought what I understood was the last NOS one left in Germany - just the inner cable element, not the housing, mind you...
RockStock wrote: |
a bus one maybe? |
The KG item is around 10 inches longer than the equivalent Oval Window Beetle cable. Bus cables are the same length as the Beetle units, IIRC.
This would work for the cable housing, but not the cable itself. I'll chat with my old pal John Copello - perhaps between he and I we can come up with an easily available solution. The solid steel cable stock is easy enough to find; the end with the knurled nut and shaft will need to be fab'ed. _________________ David Ruby
President, Karmann-Ghia World Club |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Mon Mar 27, 2006 2:11 pm Post subject: |
retrowagen wrote: |
RockStock wrote: |
a bus one maybe? |
This would work for the cable housing, but not the cable itself. I'll chat with my old pal John Copello - perhaps between he and I we can come up with an easily available solution. The solid steel cable stock is easy enough to find; the end with the knurled nut and shaft will need to be fab'ed. |
John is a remarkable machinist. If anyone can make it happen, he can. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
swanlakers Samba Member
Joined: July 17, 2005 Posts: 370 Location: Lost in space
Posted: Mon Mar 27, 2006 6:16 pm Post subject: |
I replaced my wire by using the original knob and piano wire. Too bad I forget where I came up with the piano wire. Cut off 1/2" of the metal rod and file square. Drill a small hole in the end. Kind of tricky to do if you can't find a drill press. Insert the wire and solder with silver solder. It has worked for me for years. _________________ https://www.thesamba.com/vw/archives/lit/56ghia/cover.jpg |
stripboat99 Samba Member
Joined: March 13, 2005 Posts: 10 Location: Shoreline, WA
Posted: Mon Mar 27, 2006 7:37 pm Post subject: |
Try CIP1.com part vwc-113-711-501. Looks like the right part to me, I bought one but have not installed it yet. It's looks complete, everything but the knob on the end. I'll really be bummed if it's too short.....
Mark |
Posted: Mon Mar 27, 2006 9:45 pm Post subject: |
stripboat99 wrote: |
Mark |
That'll be too short. The part with the "113" prefix is the Beetle one... Look for one with a "141" prefix... _________________ David Ruby
Posted: Mon Mar 27, 2006 10:34 pm Post subject: |
Thanks for the ideas....I'm going to try adding to the short bug cable first by welding it together. If that idea flops, I'll move on to swanlakers idea. If that fails, I'll try a sail boat shop....riggings! Thanks again, I'll let you know. _________________ Transporter Restorations
Upholstery Haus
Posted: Tue Mar 28, 2006 5:49 pm Post subject: |
Welding nor brazing would work.....on to plan B _________________ Transporter Restorations
Upholstery Haus
Posted: Tue Mar 28, 2006 5:54 pm Post subject: sorry I wanted to start a new thread |
I wanted to start a new thread. _________________ Transporter Restorations
Upholstery Haus
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Wed Mar 29, 2006 9:19 am Post subject: 58 ghia choke cable HELP |
If you guys repop one , put me down for one . I have been looking for one for my freinds 58 for a year now . None of the ones listed at the usual vendors will work , if it has a bug or bus part number , forget ordering it , it will be too short . TROY
Also looking for a NOS Ghia choke cable !!!! _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Wed Mar 29, 2006 9:21 am Post subject: Re: 58 ghia choke cable HELP |
Teeroy wrote: |
Also looking for a NOS Ghia choke cable !!!! |
That's how I got into refurbishing fuel senders. Someone can help a lot of people out by taking the time to re-pop them and make them available. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Posted: Wed Mar 29, 2006 11:07 am Post subject: |
John Copello dropped by my house last night and we discussed the idea of making choke cables. I'm hoping we'll have a prototype up in a couple weeks. Keep you all posted... _________________ David Ruby
whobba Samba Member
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Wed Aug 30, 2006 6:24 am Post subject: |
whobba wrote: |
I thought mine was missing from my '59 - - - but then found it tucked in the trunk! That is about the only lucky thing that has happened with my '59! |
I ran into the same thing - I started researching sources, and then I found it coiled up underneath the gas tank. _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Wed Aug 30, 2006 7:54 am Post subject: |
how about some mig wire? |
Posted: Wed Aug 30, 2006 8:01 am Post subject: |
I'm pretty sure I found a solution to the problem......a local speedo shop has a cable thicker in diameter.....yet it still slides thru the tube with no problem.
My only worry now is if the thicker cable will some how effect the performance of the choke? I'll find out soon enough. _________________ Transporter Restorations
Upholstery Haus
