Is this car worth it?
TDC Auto Parts
Banned
TDC Auto Parts is offline
PostPosted: Sat Sep 09, 2006 11:53 pm    Post subject: Re: Would it be wrong for me to do this? Reply with quote
FASTBACKDON wrote:
Old School VW wrote:
Would it be wrong to change the brakes over to hydraulic? If the car was not cable the car would be on it`s way to CA!! I really like the car. I think a standard bug is really special, but I want to be able to stop. I want the car as a kinda daily driver car. I have 2 other cars I can drive, but when I feel like it I want to drive the bug.
buy Ben's the guy I GREW UP WITH THE TDC VW PART SPLIT THAT IS FOR SALE
Don never said I was selling the split for sure! Just I was thinking about it as would like a car all done as I kinda lost interest from working on it for the last 9 months, But with the help of some of The Samba member who offered to help me the car will get done.
TDC Auto Parts
Ben
Old School VW
Old School VW is offline
PostPosted: Sat Sep 09, 2006 11:27 pm    Post subject: Re: Would it be wrong for me to do this? Reply with quote
Don`t have that kinda money to buy the guys split.
I only have $11,000 to spend on a car right now. But from what I read from his post thought he was keeping it?
bastardbus
bastardbus is offline
PostPosted: Sat Sep 09, 2006 10:49 pm    Post subject: Reply with quote
My buddy owned a `51 standard with about 50,000 original miles...it has been for sale off and on several times on here and discussed the past couple months.
Anyhoooo...the car still had its "original cable brakes"...well since 1968 at least when the 2nd owner who we got it from bought it. Those damn cable brakes where as 95% as good the hydraulics in my Sept `50 deluxe split. Honestly I could really not tell the difference. I had heard so many horror stories...but usually from folks who never owned or had driven a cable brake car.
As far as adjusting them...the car had a rear drum with a stripped out lug nut, so we had to loosen that cable up to remove and replace the drum. Upon reinstallation, I just followed the adjustment instructions in the workshop manual. It was as easy as pie and the damn thing was perfect the first time.
I would not hesitate to drive a split with cable brakes at all.
Samba Member #95
Jason Eden
Jason Eden is offline
PostPosted: Sat Sep 09, 2006 7:57 pm    Post subject: Re: Would it be wrong for me to do this? Reply with quote
I know whos car that used to be and nothing is og, but if you have alot of time and $$ and he will let it go for 6000.00 then it might be worth it.
59 bug slammed with cosmics
FASTBACKDON
The other insensitive jerk like Neil
FASTBACKDON is offline
PostPosted: Sat Sep 09, 2006 7:50 pm    Post subject: Re: Would it be wrong for me to do this? Reply with quote
Jason Eden
PostPosted: Sat Sep 09, 2006 7:34 pm    Post subject: Reply with quote
How about my 50 split dlx it came with cable brakes but everyone said I should change them out. What do you guys think about that? I was going to use cable brakes I bought new cables and a few other parts I needed. But I also have all the parts to change it over also.
KantDriveFast
KantDriveFast is offline
PostPosted: Fri Sep 08, 2006 8:21 pm    Post subject: Re: Would it be wrong for me to do this? Reply with quote
Towel Rail wrote:
2splits wrote:
Yes it would be wrong. If the cable brakes are maintained, there is no reason you cant drive it.
I'll second that.
Thirds. There are so few real standards out there...gotta preserve it. Its not like you're gonna commute in it right?
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Fri Sep 08, 2006 7:18 pm    Post subject: Re: Would it be wrong for me to do this? Reply with quote
I'll second that.
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
steven wood
steven wood is offline
PostPosted: Fri Sep 08, 2006 2:45 pm    Post subject: Reply with quote
I don't think it's worth it. There WAY to many VW's in California to pay $12K for an oval and have to worry about shipping it. I live about hour and a half away and I've never seen it at any shows.
Wiggy
Wiggy is offline
PostPosted: Fri Sep 08, 2006 2:21 pm    Post subject: Re: Would it be wrong for me to do this? Reply with quote
Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval
Old School VW
PostPosted: Fri Sep 08, 2006 1:19 pm    Post subject: Would it be wrong for me to do this? Reply with quote
johnshenry Premium Member
johnshenry is offline
PostPosted: Fri Sep 08, 2006 1:12 pm    Post subject: Reply with quote
[quote="DMNCLNR"]
johnshenry wrote:
RareAir wrote:
DMNCLNR wrote:
Try driving around a hydraulic brake operated Beetle, then use the handbrake only to stop the car. That's what cable brakes are like.
Wrong. Not even close.
The handbrake operates basically 2 out of eight brake shoes on the car. And since the front wheels do about 70-80% of the braking, using the handbrake is equivalent to about 10% of the potential braking power of 8 shoes.
Cable brakes, when adjusted properly are fine. The biggest problem with is that you loose the dyncamic (fluid) balancing effect between hubs that hydro brakes have when one hub becomes slightly out of adjustment than the rest. If that hub has greater shoe clearance, then it basically is a non-playa, since the cables will stop when the other shoes make contact. If (not likely) it is closer than the others, it will grab first, and the others not nearly at all.
So the typical "problem" with cable brakes is that you don't get even side to side, and front to back braking, unless all the shoes are perfectly and evenly clearanced. The chore is that you really should give the shoes a quick adjust every few hundered miles. Depending on how much you actually drive the car, that may or may not be an issue.
In the DKF cruise, the cable braked cars always went in the front of the line.........!
To the original post about the car for sale, the pics show a very solid body (what they show anyway) for a car that age. Too bad its not a split.... Wink
Hey I got sheistered.. I never wrothe that! And thank god its not a split or else it would be a zwitter YUCK!
Sorry, my mistake, I was messing around with the quote tags. I fixed it in my post.
John Henry
'57 Deluxe
'56 Single Cab
DMNCLNR
Sir Camp'alot
DMNCLNR is offline
PostPosted: Fri Sep 08, 2006 12:19 pm    Post subject: Reply with quote
[quote="johnshenry"]
To his their own PBJ
[email protected]@ #1
PostPosted: Fri Sep 08, 2006 9:27 am    Post subject: Reply with quote
John Henry
'57 Deluxe
'56 Single Cab
RareAir
RareAir is offline
PostPosted: Fri Sep 08, 2006 7:20 am    Post subject: Reply with quote
DMNCLNR wrote:
If you decided to buy it and have it shipped out to orange county you would be into it about 13k. no its not worth that.
Shipping coast to coast usually runs about $1k. But $12k is still pretty steep. Also, mechanical brakes are great, but not for daily driving. Try driving around a hydraulic brake operated Beetle, then use the handbrake only to stop the car. That's what cable brakes are like.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
DMNCLNR
Sir Camp'alot
DMNCLNR is offline
PostPosted: Fri Sep 08, 2006 1:49 am    Post subject: Reply with quote
I think it would be worth it if they moved the tail lights up a little farther... Kind of expensive for an oval..If you decided to buy it and have it shipped out to orange county you would be into it about 13k. no its not worth that. nice car though.
Old School VW
PostPosted: Fri Sep 08, 2006 12:34 am    Post subject: Is this car worth it? Reply with quote
Is this 53 standerd ovel worth $10,950? Has anyone ever driven a car with mechanical brakes and is it safe to drive like this or am I better off buying a car with non mechanical brakes? Never had a car with cable brakes, but the car looks so sweet would love to have it, but dont want to make a mistake in buying it.
Thanks
http://www.thesamba.com/vw/classifieds/detail.php?id=347244
