Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Sun Sep 10, 2006 10:08 am Post subject: My version of Bob Hoover's fuel line pass through |
In the process of building a new engine I decided to use Bob Hoover's fuel line pass through to protect the metal line as it passes through the engine tin.
I was able to get everything at my local ACE Hardware for a few dollars. I used a 1" threaded lamp fitting, but cut it to 1/2" so the hardline can make it through without having to be bent. I also used threaded knurled fittings instead of washers.
(1) 1" pipe $0.50
(2) 9/16" nuts $0.30 each
(2) knurled threaded fitting $0.60 each
ACE also had a nice selection of rubber gromets for the valve cover breather hoses and my oil line for my mechanical oil pressure gauge.
_________________ Glenn
Member #1009
#BlueSquare |
John M. Samba Member
Joined: July 22, 2005 Posts: 3833 Location: Boulder, CO
Posted: Sun Sep 10, 2006 10:21 am Post subject: |
Nice job, Glenn. |
68Bug-lite Samba Member
Joined: July 31, 2005 Posts: 1087 Location: Tustin, CA
Posted: Sun Sep 10, 2006 10:33 am Post subject: |
Good deal...The fuel pipe wont wear with an 1/2 inch of support, like it would the thin engine tin edge. Does it have a snug fit to the fuel line, or do you plan to use a light coat of sealant where it passes through?
Thanks for the pics, think I'll do the same.
Greg |
Glenn Mr. 010
Posted: Sun Sep 10, 2006 11:01 am Post subject: |
I could slide in a thin piece of rubber, like from a bicycle tube.
This it nothing new, Bob Hoover came up with this years ago. I originally had a gromet there, but I found it sitting on the tin, cut in half. _________________ Glenn
Member #1009
#BlueSquare |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Sun Sep 10, 2006 12:05 pm Post subject: |
i have done this "mod" to every engine i have had for years....just that little bit of extra protection....i usualy just do it the way bob describes and it works great....lowe's, ACE, any hardware store should have the stuff....thanks for putting up pictures Glenn more folks need to *see* how easy it is... |
Yellowbeard Samba Member
Joined: March 07, 2006 Posts: 2288 Location: At large again...
Posted: Sun Sep 10, 2006 12:13 pm Post subject: |
Ditto what bugninva said. Cheap insurance against a catastrophic failure. One of the few times I advocate trash-canning VW's engineering in favor of a home-brew fix. _________________
Lohe wrote: |
Thanks. Thread went from me not being able to understand what Ipis was saying because English is obviously not his first language to me not being able to understand it because English is my first language |
Fuel pumps galore:
http://www.thesamba.com/vw/classifieds/detail.php?id=845378 |
mattlockwood Samba Member
Posted: Wed Oct 09, 2019 5:04 pm Post subject: Re: My version of Bob Hoover's fuel line pass through |
Glenn, can you repost your photos?
Glenn wrote: |
(1) 1" pipe $0.50
_________________ 1970 Bay Window Bus.
110 hp 6 cyl Aircooled automatic |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
Glenn Mr. 010
Posted: Wed Oct 09, 2019 6:30 pm Post subject: Re: My version of Bob Hoover's fuel line pass through |
Member #1009
#BlueSquare |
Posted: Wed Oct 09, 2019 7:23 pm Post subject: Re: My version of Bob Hoover's fuel line pass through |
Thank you-nice to see the Hoover link too. Been reading thru his 850 page blog...
Matt _________________ 1970 Bay Window Bus.
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Thu Oct 10, 2019 9:06 pm Post subject: Re: My version of Bob Hoover's fuel line pass through |
I love ace man....it’s amazing what you can come up with just by taking some time and strolling around. Fabulous idea for only a few bucks!
So, the original idea from vw......why was it not very good? To much rattling and it eventually wore through the fuel line and then the fuel leaked out? Why not make the hole larger so it would chafe? |
Glenn Mr. 010
Posted: Fri Oct 11, 2019 5:22 am Post subject: Re: My version of Bob Hoover's fuel line pass through |
No one expected these cars to still be on the road 60 years later. _________________ Glenn
Member #1009
#BlueSquare |
nshaddox Samba Member
Joined: January 18, 2005 Posts: 612 Location: Hammatramma, MI
Posted: Tue May 26, 2020 6:16 am Post subject: Re: My version of Bob Hoover's fuel line pass through |
I liked the low cost solution here, but wanted something to really hold the line in place personally, so I had a few of these made. They act like the lamp shade threaded rod concept but use Yor-Lok style ferrules to really clamp the line down and prevent it from moving around within the ID. Works with the 1/4" brakeline that I'm sure 90% of us are using as fuel line.
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
bedlamite Samba Member
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Wed May 27, 2020 6:37 am Post subject: Re: My version of Bob Hoover's fuel line pass through |
I use electrical conduit fittings
For just about everything
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Posted: Wed May 27, 2020 6:38 am Post subject: Re: My version of Bob Hoover's fuel line pass through |
yea, not going to argue that using a stock style fuel line is a better set up than running all AN fittings from the tank back. Just offering another alternative to anyone who doesn't want to invest in all that AN hardware but still wants to improve the situation between the stock hard line and the front tin. AN bulkhead fittings are available stateside. all options in this thread are better than the stock rubber o ring. |
