jimf909 Samba Member
Posted: Sun Apr 08, 2018 2:45 pm Post subject: Re: Gauges - Post Pics! |
^^^ Well done (as usual), Kourt.
How do you divide use of the Speedhut gauges v. the Ultragauge? Do you rely on the Speedhut gauges for normal driving and the Ultragauge for details such as mpg, etc?
I’ve settled into using both the stock gauges and the Ultragauge (although my speedo works and we got the tach to be w/in about 100 rpm accuracy at hwy speeds) and enjoy that combination.
Regardless, it’s nice to see a stock-looking Speedhut install! _________________ - Jim
Abscate wrote: |
kourt Samba Member
Joined: August 13, 2013 Posts: 1949 Location: Austin, TX
Posted: Sun Apr 08, 2018 2:59 pm Post subject: Re: Gauges - Post Pics! |
Right now I'm just using the Ultragauge to check the accuracy of the Speedhut gauges. I think I will move the Ultragauge to a less conspicuous area but keep it connected for diagnostics.
Before these Speedhut gauges, I used the UG exclusively for speed, tach, CHT and fuel range. I didn't really look at the old Vanagon gauges. I disliked having this big useless instrument cluster, so that really motived me to fix up the analog gauges with Speedhut units and rely less on the UG.
kourt |
Gizmoman Samba Member
Joined: September 10, 2011 Posts: 1554 Location: Nevada
Posted: Sun Apr 08, 2018 3:12 pm Post subject: Re: Gauges - Post Pics! |
Very nice! _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale). |
Posted: Sun Apr 08, 2018 5:44 pm Post subject: Re: Gauges - Post Pics! |
kourt wrote: |
kourt |
Ah, I can follow the evolution now: UG replaced decaying stock gauges. Now Speedhut gauges are replacing somewhat rudimentary and clunky UG gauge panel.
That makes sense. You’re one step ahead of me.
p.s. I just saw the explanatory paragraph on this in the original post. Doh. _________________ - Jim
Abscate wrote: |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
unibagel Samba Member
Joined: December 02, 2004 Posts: 529 Location: Bflo, NY
0cean Samba Member
Joined: February 29, 2012 Posts: 1149 Location: California
kourt Samba Member
Posted: Tue May 22, 2018 5:46 am Post subject: Re: Gauges - Post Pics! |
Just an update: I moved my UltraGauge to stick to the windshield in the lower left (driver's perspective) corner, behind the state registration sticker. It serves as a good heads-up display there, and remains helpful by providing speed and MPG in big numbers, and programmable service reminders and OBD diagnostics within its menus.
kourt |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Sat Sep 28, 2019 2:11 pm Post subject: Re: Gauges - Post Pics! |
Today I put together another set of three Gauge pods for a different Van but slightly updated the method of mounting the Pods to the Van. My first set was from 2014. The original magnet system used 3/4” rare earth fixed to the base of the gauge mount with VHB tape. The tape has deteriorated and the gauges were constantly shifting around before that, never perfectly aligned...
The same gauge pods are still available
This time I am using 1” diameter magnets inserted into metal cups which focus and increase the magnetic force while also providing a convenient mount point for the gauge pod ball joint. 8-32 flat head screws and a nut hold the ball firmly to the magnet cup.The 8-32 nut recesses nicely into the top of the ball and allows full articulation of the joint. I used a self adhesive anti slip cover to provide friction so the pods stay in place and aligned. (The black dots)
Important tip: Make a notch in the side of the magnet cups to permit a screwdriver tip or pick in order to facilitate magnet removal in the future.
Here is an image of my pods in position with the new system, plus some shots of the new pods attached to the A pillar.
Tweeter enclosure application.....?
Very flexible positioning, great visibility, no drilling.
_________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
bajaleo Samba Member
Joined: March 21, 2009 Posts: 211 Location: San Juan Capistrano, CA
Posted: Mon Sep 30, 2019 7:10 am Post subject: Re: Gauges - Post Pics! |
Great idea!
T3 Pilot wrote: |
_________________ Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered. |
valvecovergasket Samba Member
Posted: Mon May 25, 2020 2:22 pm Post subject: Re: Gauges - Post Pics! |
figured id add my contribution as i just wrapped up the speedhut install. went a slightly different route than kourt, i wanted to use the mounting hardware and lighting that the gauges came with. had some scrap abs and pushed the mounting forward. used jb weld plastic epoxy and a tight physical fit to get the new mounting face in there. along with a new center stack with glowplug light and MIL from smallcar.
so far no issues with the fuel level - i used a decade box to calibrate the min/max - but will report back once we get more miles on it.
_________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Mon May 25, 2020 3:11 pm Post subject: Re: Gauges - Post Pics! |
valvecovergasket wrote: |
f
So does the instrument lights from the new gauges reflect in the windshield at night?
I just bought a VDO GPS Speedometer, not sure when I'm going to install it. _________________ This free advice is worth exactly what you paid for it.
captmatthew1 Samba Member
Posted: Mon May 25, 2020 8:09 pm Post subject: Re: Gauges - Post Pics! |
I recently relocated my extra gauges from the dash to the A-pillar.
_________________ Matthew Alig
1980 VW Vanagon Tin-Top Camper Conversion |
Posted: Tue May 26, 2020 7:45 am Post subject: Re: Gauges - Post Pics! |
Steve M. wrote: |
f
I just bought a VDO GPS Speedometer, not sure when I'm going to install it. |
in the testing ive done in the dark-ish garage they dont seem to. we'll see how it goes in actual dark road driving _________________ MegaSquirt resource - SpitfireEFI.com
T3TRIS Samba Member
Joined: October 30, 2017 Posts: 299 Location: Portland, OR
Posted: Mon Jun 15, 2020 2:37 pm Post subject: Re: Gauges - Post Pics! |
Hey there,
I'm almost ready to pull the trigger on some Speedhut gauges. I'll be buying the same gauges as both valvecovergasket (I assume your gauges are also the 4" and not the Speedhut 4-1/2") and kourt though I haven't quite decided between placing the gauges on the front like valvecovergasket or the back like kourt. I already have the GoWesty circuitry installed in the back, so wiring should be relatively straight forward. I'll also be adding a 2-1/16 engine oil temp gauge and another for transaxle temp somewhere around there too (haven't figured out that one yet either).
Do any of you have a little more input on your choices regarding the position (same as original vs on the face of the cluster), feedback on reflections, visibility at night, or through the steering wheel?
I've also read that the fuel gauge can be all over the place but I believe that was feedback from 2WD van owners (we have a syncro). Any additional info or testing on that?
Thanks, and both setups look awesome and so much more usable by the way!
kourt wrote: |
I finally finished my gauges project.
_________________ Guillaume, Jennifer & T3TRIS
87 2-knob Syncro
- 94 Subaru EJ22, 225/70-R16 CLK 16x7 ET37
- Transaxle rebuild, Mexico paint job, Front end rebuild, 320Ah LiFePO4 Battery |
Posted: Mon Jun 15, 2020 6:32 pm Post subject: Re: Gauges - Post Pics! |
Steve M. wrote: |
f
followup to this - no reflections at night, and i really like the backlighting and needle lighting of the speedhuts..
the only reflections i get a bit of are the ashtray gauges, but its minimal.
T3TRIS wrote: |
Hey there,
i bought the same ones as kourt - the 4"
the actual hole saw size i used to cut those panels was a bit smaller as i recall 3-7/8? so the gauge is actually ~4" as measured at the bezels.
im really happy with my setup and especially like the backlighting of the numbers and the needle lighting. i find it looks a bit more modern.
as i recall kourts thread he was looking for a much more original setup and preferred the face lighting as a result but ill let him chime in...
my interest in mounting them toward the front was just because i didnt want to make any extra hardware or brackets and clamp the gauges (kourt had a really clever way of doing this), and wanted initially to mount them in the same location as kourt (or thereabouts) but use the speedhut mounting ring and all that.
unfortunately the cluster tapers way too much to allow for that, so i pushed it as far forward as i could to make it look not too out of place and gave me enough room to mount the gauges with the bezels and mounting rings they came with.
fuel gauge can be an issue below around 1/4 tank. the 2wd tank likely exagerates this as the sender is in one corner of the tank.
others ive seen also mentioned that their low fuel light comes on and off as a result, but mine doesnt...
i dont know if this is a software difference as some of those threads were a few years old, or if they turned their light on via settings and i neglected to when i set mine up.
all i did to the gauges when they came out of the box was test the filtering, calibrate with a decade box, and then plug them in.
im finding the oil pressure gauge to perhaps be a bit under damped as well, for what thats worth...
i reached out to speedhut this morning to see if this was something they could fix with reprogramming (this should be a simple filter constant calibration on their end...) but we'll see.
im not hacking together aftermarket level senders or dropping the tank again, as they should be more than capable of compensating for filter constant changes.
the gps speedo is also good, but not perfect and i think suffers from a similar filtering issue as the rest of their gauges (dropouts can cause a hard plummet to 0, proper software would have accommodated for a dropout to not be treated with the same filtering as a true value).
just something to be aware of. _________________ MegaSquirt resource - SpitfireEFI.com
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2332 Location: Southeast Kentucky
Posted: Mon Jun 15, 2020 6:55 pm Post subject: Re: Gauges - Post Pics! |
Jetta Cluster
Scan Gauge
Below: These descriptions are as of now, 6/15/2020
Top, left to right: EGT/Coolant combo, Turbo, Oil Temp
Bottom, left to right: Cooling system pressure, Vacuum, Volts, Oil pressure
_________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Mon Jun 15, 2020 8:39 pm Post subject: Re: Gauges - Post Pics! |
Hey Andy,
What kind of sending unit for water pressure gauge- mechanical or electric? There is a bad glare in your picture, what's the pressure range of the gauge? Do you have a link to it?
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
livethevanlife Samba Member
Joined: May 18, 2015 Posts: 204 Location: La Paz, Baja California Sur
Posted: Mon Jun 15, 2020 8:47 pm Post subject: Re: Gauges - Post Pics! |
Heres a look at the speedhut gauges I have on my Syncro. The cluster was modified by northwesty to fit the 3 gauges.
_________________ www.LiveTheVanLife.com
www.VentureLibre.com
https://www.PeaceVans.com/baja
1991 Syncro Triple Knob Westfalia "Miki" 2.2WBX
1992 Syncro Triple Knob Tintop "Schnitzel" 1.9AAZ
1990 Syncro Rear Locker Doka Subi 2.2
1974 VW Thing 1835cc
1989 VW Carat |
Posted: Mon Jun 15, 2020 9:11 pm Post subject: Re: Gauges - Post Pics! |
livethevanlife wrote: |
I think I replied to your post of that shot, hopefully SpeedHut gets back to one of us _________________ MegaSquirt resource - SpitfireEFI.com
