Split 66' Samba Member
Joined: October 07, 2010 Posts: 1257 Location: Bay Area, California
Posted: Tue Feb 15, 2011 8:33 pm Post subject: |
OG spring on the left, New Wolfsburg West spring on the right:
Ian wrote: |
you have to bend them real hard, your old spring has lost tension and is stuck in a worn out position.
spring looks right, hook is the right way
i have installed 3 of the WW ones and a couple of the "cheap" ones, they all seem to be fine |
I tried to get the WW spring in there but it really seems that bend is incomplete, it was too difficult to get the spring between the frame cross-member and the pedal stop. How were you able to compress the spring long enough to get the pedal lever in place?
peterxxl wrote: |
Report:
I guess you're more lucky than I am. I investigated today my spring and tried to mount it. It's not possible, but mine is different than yours. It's flipped, like in the mirror. The hook is on the other side that original. I guess the Bays have the pedal connected from the other side. |
I can send you a Wolfsburg West spring, the one seen in the photos. You'll have to use Ian's method of getting it to fit or bend it to look like the stock one. PM me an address and I'll send you the spring. Not sure how long it would take to get to Mexico from here but I can send it out tomorrow.
hazetguy wrote: |
unless that spring (on the left in the pic above) is actually broken, if you install it properly, there will be plenty of tension for it to return the pedal for a long time.
i have had genuine VW NOS springs, with VW stickers still on them (VW paper stickers, not the vwoa dealership stickers) and they looked like the spring on the left (in the pic above, on the right below).
in the above pic, the spring on the right looks like a poorly made repro, or perhaps a (repro of a ?) bay window spring.
broken spring on left, original spring on right
Thanks for pointing this out hazetguy, my OG spring is in good shape and the return is snappy enough. I wasn't sure what was going on and why it was so tough to get the WW spring to fit. I'll call WW tomorrow and let them know. Thanks again for sorting that out. _________________ "OG = Original German" -- TheSamba.com dictionary |
johny__utah Samba Member
Joined: September 02, 2008 Posts: 426 Location: Arizona/California
Posted: Wed Feb 16, 2011 10:21 am Post subject: |
I cant seem to install mine correctly?? Its either to tight "bolt not the spirng" that it doesnt return the pedal,, or to loose that the nut is half way on. A few times the spring angles the pedal causing it to rub against the side of the steering box mount. Its a og spring. |
Posted: Wed Feb 16, 2011 1:06 pm Post subject: |
I received an email from WW about their experience installing their own return spring, here it is:
Wolfsburg West wrote: |
So I was able to get the spring to go on, as you can see in the photos. We don't like the way it fits, so we will be fixing the part. Thanks for bringing it to our attention. We'll keep you posted once we have the new production spring available. |
Good to see that the problem will be fixed shortly. _________________ "OG = Original German" -- TheSamba.com dictionary |
Posted: Wed Feb 16, 2011 1:19 pm Post subject: |
Easy Duz It wrote: |
Can you post pics of what is causing the problem? If you are using an OG spring, make sure it is located like the one in hazetyguy's photo:
drumming123 Samba Member
Joined: April 04, 2004 Posts: 723 Location: Merced, California
Posted: Mon Feb 13, 2012 12:35 am Post subject: |
Can someone please confirm the orientation of these pieces? I took the brake pedal off so long ago and can't remember which pieces go where (except the snap ring and washer).
I looked in the obsolete documentation, but couldn't make out the image very well. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Mon Feb 13, 2012 12:59 pm Post subject: |
Thank you Everett. Just what I needed.
Can you tell what the 2nd item from the left in my picture is from?
It's a thick, stepped washer, I had it in the ziplock bag with the other brake components. Maybe I just slipped it in there on accident. |
dreadnotmusic Samba Member
Joined: March 04, 2003 Posts: 880 Location: Guam, USA
Posted: Mon Feb 13, 2012 1:19 pm Post subject: |
It looks to me like you have two different brake spring seats (#31).
I took the pedal assembly apart on my 66 to do a box raise and noticed I didn't have a spring seat (stepped washer) so I ordered one from Campingbox. I didn't end up using it because I couldn't reassemble the pedal as long as it was in there. It kept wanting to "crush" the spring seat up against the frame and bind the pedal. I left it out and put it back together as it was before. Problem solved.
Good luck. Be sure to post pics. _________________ 66 Riviera |
justinpirie Samba Member
Posted: Mon Mar 24, 2014 1:13 pm Post subject: Where can I buy the snap ring and washer? |
I'm missing my snap ring and washer- does anyone know the dimensions of either or where to buy them?
Is the beetle one the same? http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=N124241
What size washer does it take?
Thanks! |
nebkv Samba Member
Posted: Sat May 31, 2014 6:11 am Post subject: |
I have two version of pedal
images
Maybe black pedal going without part 31 from EverettB picture?
Or have longest part 30?
pic host
free upload pictures |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Sat Sep 03, 2016 5:16 pm Post subject: |
It says in the Bentley manual that from September 1964 Chassis No 255026862 that the support tube (211721141) of the brake pedal on all LHD models was lengthened 7mm to improve the location of the return spring. If you use the longer tube version, you do not use the "special washer" 211721235 (#31 I think). |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Mon Sep 05, 2016 6:09 pm Post subject: Re: Replacing brake pedal spring |
Stupid question but just want to make sure. With no master cylinder or pushrod installed, the brake pedal should always spring back to the "up" position, correct? When you push my pedal, it just stays at the floor. Spring is present, maybe it's cracked though. _________________ 1957 Beetle
1966 Bus |
Stanagon Samba Member
Joined: July 11, 2003 Posts: 4186 Location: Boston, MA
Posted: Mon Sep 05, 2016 6:55 pm Post subject: Re: Replacing brake pedal spring |
Stanagon wrote: |
GLHTurbo wrote: |
Stupid question but just want to make sure. With no master cylinder or pushrod installed, the brake pedal should always spring back to the "up" position, correct? When you push my pedal, it just stays at the floor. Spring is present, maybe it's cracked though. |
Yes it should spring up. |
Thanks Stan, another part for the shopping list. _________________ 1957 Beetle
1966 Bus |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Tue Sep 06, 2016 9:17 am Post subject: Re: Replacing brake pedal spring |
GLHTurbo wrote: |
Stanagon wrote: |
GLHTurbo wrote: |
Thanks Stan, another part for the shopping list. |
Or the pivot is just dirty and dry. I pulled both clutch and brake pedals out, cleaned, lubed and reassembled and it was a big difference after. |
Posted: Tue Sep 06, 2016 9:26 am Post subject: Re: Replacing brake pedal spring |
ToolBox wrote: |
GLHTurbo wrote: |
Stanagon wrote: |
GLHTurbo wrote: |
The brake spring is really strong, I would suspect it's messed up if it can be held down just by dirt and no grease.
Always a good idea to disassemble and inspect and grease it when you do the spring though. _________________ How to Post Photos
Posted: Tue Sep 06, 2016 10:21 am Post subject: Re: Replacing brake pedal spring |
Thanks, I'm going to break it all down, clean and grease and see what's up. My clutch pedal seems a little off too, so maybe this is the case and everything is just dry and dirty.
Does the clutch pedal use the same spring as the brake arm? I think it is the same? _________________ 1957 Beetle
1966 Bus |
Posted: Tue Sep 06, 2016 10:51 am Post subject: Re: Replacing brake pedal spring |
GLHTurbo wrote: |
Does the clutch pedal use the same spring as the brake arm? I think it is the same? |
No spring on the clutch pedal, just the spring on the transmission arm |
