NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Thu Sep 21, 2006 6:51 am Post subject: Unusual 1968~79 VW Type 2 and/or VW 181/182 ignition coil |
Hello Volks.
I'm hoping that one or more of you, will enlighten me, about an unusual VW Type 2 and/or VW Type 181/182 (i.e. VW Thing or Trekker, etc) ignition coil and connecting cable, I have in my possession, which are illustrated as Items 2 & 25, on page & frame 94-10, of the official 1968~79 VW Type 2, Replacement Parts Catalogue & Microfiche. I have recently taken a 35 mm format, colour photograph, which I shall have precessed shortly and hopefully post it in The samba Gallery, when and if my local public library's flat-bed scanner, is functioning properly.
The ignition coil (VW part No. 122 905 115 D and Bosch part No. 0 221 107 001), is approximately 170 mm (i.e. 6·7 inches) in total length and 60 mm (i.e. 2·4 inches) in diameter; weighing nearly 1·2 kg (i.e. 2·6 lbs), including the mounting bracket. This is noticeably larger and heavier than all other air-cooled VW, ignition coils, I have come across!
In addition to the VW and Bosch part numbers, it also bares the following markings:
Bosch Made in Germany
030 KMW V12
12V Widerstand Vorschalten
What particularly distinguishes this ignition coil, are the terminal connections, labelled 1, 4 & 15. These are some special kind of screw-fastening, water-proof, gland connection, with internal spring-loaded contacts, for terminals 1 & 15, whilst terminal 4, has an internal co-axial spike, on which to impale the central core of the HT cable.
The connection cable (VW part No. 181 905 721 and Bosch part No. 0 290 320 009), is approximately 275 mm (i.e. 10·8 inches) in total length, with screw-fastening, water-proof gland connections at either end; which would connect the ignition coil, to what looks like some kind of ballast.
The ignition coil and the connection cable, form just a small part of a complete ignition system, which seems to comprise several special components. In the official, 1968~79 VW Type 2, Replacement Parts Catalogue & Microfiche, these are illustrated in the lower half of Page & Frame 94-10 and Items 10, 11 and possibly 25, on page & frame 94. There also appears to have been a special distributor, but is not fully illustrated, merely depicted by a dotted line.
Several years ago, in an issue of the VW Motoring magazine, I noticed that a VW Type 4 industrial engine, used for the independent manouvering unit, of the now obsolete NATO 155 mm artillery howitzer (still used then, by the British territorial Army units), equipped with an ignition coil of this unusual pattern. I would therefore conclude, that it might have been standard equipment, on military versions of the 1968~79 VW Type 2 and VW Type 181, in countries such as Germany, Austria, Switzerland and The Netherlands.
To the best of my knowledge, the ignition coil and connection cable, were supplied to my father in 1975, by Ecta Motors, in Rochford, Essex (the then franchised VW dealership), as a made-up, overseas-touring spares kit, for our then newly acquired, 1973 VW 1600 Type 2 Westfalia Continental campervan. It wasn't until several years later, that we unpackaged the kit and discovered that these particular components, were not appropriate to our vehicle.
Although we had a few breakdowns and other technical hiccups, during our European touring holidays, it was fortunate that we never needed to replace the ignition coil, especially in Hungary or Czechoslovakia, in 1985 and 1987, behind the "Iron Curtain".
If anyone would like these unused, New Old Stock items, I am willing to sell them for a reasonable price or barter for things which I seek.
Regards.
Nigel A. Skeet
germansupplyscott Samba Member
Posted: Thu Sep 21, 2006 6:56 am Post subject: |
this?:
_________________ SL |
Posted: Fri Sep 22, 2006 6:22 am Post subject: Unusual 1968~79 VW Type 2 and/or VW 181/182 ignition coil |
Yes Scott.
The ignition system depicted in your picture, illustrating the engine compartment, of what appears to be a military VW Type 181/182, with manual engine-starting handle (a very useful accessory, which I would advocate for all rear-engined VWs, as I have retro-fitted to my 1973 VW Type 2!), is exactly the one to which I refer, as illustrated in the official 1968~79 VW Type 2 Replacement Parts Catalogue & Microfiche, on Page & Frame 94-10; reproduced on Richard Atwell's website, as follows:
http://www.ratwell.com/technical/Microfiche/t209410.gif
I have the paper Catalogue, which shows just the Page/Frame numbers and the Item numbers, with the line drawings, but does not give the part descriptions or VW part numbers. I do have a copy of the Microfiche, but have yet to source a microfiche viewer, with which to view it!
My ignition coil, has the symmetrical, Omega-shaped attachment bracket, appropriate to the VW 1600 Type 2 & VW 1600 Type 181/182 engines.
Are components for this system still listed as being available from VW or Bosch, or is it now a matter of sourcing unused New Old Stock and second-hand used parts?
Regards.
Nigel A. Skeet |
steponmebbbboom Samba Member
Posted: Tue Jan 23, 2007 3:06 pm Post subject: |
I just came. |
BusOK Samba Member
Joined: October 15, 2008 Posts: 32 Location: The Netherlands
Posted: Wed Jun 08, 2011 3:22 pm Post subject: |
So for what type of Baywindow engines where these used on?
chrz
Jeff _________________ www.busok.nl - quality parts for splits, bays and T25s |
Posted: Thu Nov 15, 2018 9:34 am Post subject: |
BusOK wrote: |
chrz
Jeff |
Potentially they would have been used on either the VW 1600 Type 2 (VW Type 1 style) or VW 17/18/2000 Type 2 (i.e. Type 4 style) engines.
The following link about which I learned recently, might shed some more light.
https://volkswagen.7zap.com/en/rdw/typ+2+syncro/t2/1976-29/9/905-94010/
Item 2 043 905 115 B ignition coil 12V screened
Item 24 181 905 721 line screened
Item 25 181 905 723 line screened
Page 94-10 of the official 1968~79 VW Type 2 Replacement Parts Catalogue
My ignition coil (VW part No. 122 905 115 D) has a different part number to Item 2 listed above, but my connection cable (VW part No. 181 905 721) has the same part number as Item 24 above.
Page 94-00 of the official 1968~79 VW Type 2 Replacement Parts Catalogue
https://volkswagen.7zap.com/en/rdw/typ+2+syncro/t2/1976-29/9/905-94000/ _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
Posted: Mon Sep 30, 2019 8:47 am Post subject: Re: Unusual 1968~79 VW Type 2 and/or VW 181/182 ignition coil |
Here's another picture which is in the German army manual, featured in The Samba technical archive.
1984 VW Bus German Army Parts Manual
https://www.thesamba.com/vw/archives/manuals/1984_Bus_German_Army_Manual.php
Shows the special ignition coil that I have _________________ Regards.
Nigel A. Skeet
Posted: Thu Oct 27, 2022 10:27 am Post subject: Re: Unusual 1968~79 VW Type 2 and/or VW 181/182 ignition coil |
There is an ignition coil of this type, presently listed in the VW 181/182 section of The Samba Classified Advertisements, but the vendor is located in Australia, from which shipping costs are horrendously expensive even for relatively small items.
Bosch Military Vehicle Coil | Price: US$100
https://www.thesamba.com/vw/classifieds/detail.php?id=2505153 _________________ Regards.
Nigel A. Skeet
