early and late backing plates
TinCanFab
TinCanFab is offline
PostPosted: Thu Sep 21, 2006 9:18 am    Post subject: early and late backing plates Reply with quote
i searched the gallery and forums already and had every qestion but one answered. what are the differences between small and big nut tranny backing plates? i'm going to dig through my friend's pile of parts to look for big nut parts. i've never looked at them side by side and every picture i've seen doesn't show any obvious differences..thanks
Lind
Lind is offline
PostPosted: Thu Sep 21, 2006 9:31 am    Post subject: Reply with quote
the early backing plates are held on by three bolts up top, while the later onesa are held on by two.
the early backing plates have a seperate clip to hold the E-brake cable on, with a weldnut on the inside of the backing plate. the later ones have a tube that the cable slides into.
When you realize you are in a horror movie, its too late.
TinCanFab
PostPosted: Thu Sep 21, 2006 9:37 am    Post subject: Reply with quote
bueno! Very Happy
hazetguy
hazetguy is offline
PostPosted: Thu Sep 21, 2006 10:23 am    Post subject: Reply with quote
also
the diameters are different. later ones are larger.
where the brake adjuster stars are: on the early ones, they are separated, and angled. on the later ones, they are in the same "holder" and stick out horizontally.
early ones have 4 holes in them for the brake springs (tiny holes around the big central hole. NOT the big holes for the bearing cover bolts).
https://www.youtube.com/watch?v=UYmtzaHwCKo
Parts and mechanical restoration services available. I restore and rebuild fuel pumps, distributors, spindles, etc.
Check my ads or send a PM.
TinCanFab
PostPosted: Thu Sep 21, 2006 1:51 pm    Post subject: Reply with quote
thanks hazetguy.. i can't wait to drive my first bus. one that I own anyway...
