Free_Buggy Samba Member
Joined: February 13, 2006 Posts: 143 Location: Ont. Canada
Posted: Sat Mar 13, 2021 6:32 am Post subject: Re: Floor Pan Progress - Build Updates |
I always new that the top of the transmission bell housing was likely to foul the rear bottom corner of the parcel tray but now that I have the engine mounted I see the throttle cable tube is in a worse position. Am I right to assume my best option is to make a fiberglass modification to the body? I have searched The Samba a bit but don't see much information on this. Would love to see pictures of what others have done.
Throttle tube sits higher than top of bell housing
Witness mark on the rear edge of parcel shelf from when the body was mounted last _________________ Hugh
Genuine Manx Clone |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8688 Location: Sunset, Louisiana
Posted: Sun Mar 14, 2021 6:31 pm Post subject: Re: Floor Pan Progress - Build Updates |
That is a good point. I think I would have to push mine up about 1.5"...do you think yours sagged that much without the brackets?
Q-Dog wrote: |
Mine was sagging. I made these to fix it.
clonebug Samba Member
Joined: January 29, 2005 Posts: 4026 Location: NW Washington
Posted: Sun Mar 14, 2021 7:43 pm Post subject: Re: Floor Pan Progress - Build Updates |
I use the tin that goes across the bellhousing and has a hole for the dog house exit. It has a hole in it for the throttle cable and gives it some support.
It also help tie all the cooling tin together.
I have my coil mounted on it also.....along with it supporting my FI wiring harness.
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 849 Location: South Florida
Q-Dog Samba Member
Posted: Mon Mar 15, 2021 5:39 pm Post subject: Re: Floor Pan Progress - Build Updates |
Free_Buggy wrote: |
Q-Dog wrote: |
Yes. At least an inch. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Thu Mar 18, 2021 12:36 am Post subject: Re: Floor Pan Progress - Build Updates |
I may not be looking at this right...but it looks like your throttle tube goes through the shroud lower on the opposite side of the oil cooler than stock? Is that an FI location? Just curious.
[quote="clonebug"]I use the tin that goes across the bellhousing and has a hole for the dog house exit. It has a hole in it for the throttle cable and gives it some support.
Posted: Thu Mar 18, 2021 4:42 pm Post subject: Re: Floor Pan Progress - Build Updates |
Just got these mounted and balanced...the rears look bigger than I expected. Should be fine.
Front 215/60R14 on 14x6 wheels
Rear 255/70R15 on 15x8 wheels
Posted: Fri Mar 19, 2021 4:54 pm Post subject: Re: Floor Pan Progress - Build Updates |
Got these printed finally. Printer sent me these pictures...can't wait to pick them up.
Free_Buggy wrote: |
Thought I would share an idea that I had following confirmation from Winnie that I do not have an authentic Manx. The tubes under the sides are different? I created these models and may get them 3D printed. I may even try hand at casting them in aluminium. One is a nose badge and the other is a tail badge...
Posted: Sat Apr 24, 2021 11:04 am Post subject: Re: Floor Pan Progress - Build Updates |
Getting closer...
Posted: Sun Apr 25, 2021 7:57 am Post subject: Re: Floor Pan Progress - Build Updates |
[quote="Free_Buggy"]I may not be looking at this right...but it looks like your throttle tube goes through the shroud lower on the opposite side of the oil cooler than stock? Is that an FI location? Just curious.
clonebug wrote: |
It does go on the other side....It's a 75-79 FI shroud and I use it because I used to have the German FI Intake. I have since built my own intake and modified the Throttle Body linkage to work with my setup and use the same shroud exit.
You can easily bend that tube down after the shroud to get it lower if you need to.
I built my own out of some brake line. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Posted: Mon May 24, 2021 2:41 pm Post subject: Re: Floor Pan Progress - Build Updates |
One of my excuses, there are many, for taking so long to build this buggy is that I am working out of a single car attached garage. Some times I have to be creative with the use of space, when I make noise, when I spray paint....etc. Most of the process has involved having parts mobile. Pictured below I have the cage on a repurposed dolly originally used to hold the pan. This way I can roll the pan, now that it sits on its own, out and work on the cage then move everything back inside. Also, my fiberglass body is hanging from the ceiling....
Who else here has built up their kit car in a single car garage? How did you deal with lack of space?
Posted: Sun Dec 19, 2021 12:54 pm Post subject: Re: Floor Pan Progress - Build Updates |
Seats partially upholstered...not perfect but good enough. Done with an old singer sewing machine.
Posted: Sun Dec 26, 2021 10:01 am Post subject: Re: Floor Pan Progress - Build Updates |
Seat cushion coming together...all completed on this 60+ year old sewing machine.
GS guy Samba Member
Joined: December 03, 2007 Posts: 967 Location: Maryland
Posted: Sun Dec 26, 2021 10:06 am Post subject: Re: Floor Pan Progress - Build Updates |
Good looking seats!
Jeff _________________ 70's vintage Deserter GS buggy - undergoing transformation to Super GS! |
Posted: Sun Dec 26, 2021 6:54 pm Post subject: Re: Floor Pan Progress - Build Updates |
GS guy wrote: |
Good looking seats! :D
Jeff |
Thanks...loosely based on early 50's Jag seats. _________________ Hugh
