How much did this sell for? 1953 Barndoor 23 Window Deluxe
RockStock
RockStock is offline
PostPosted: Thu Mar 01, 2007 12:06 pm    Post subject: Reply with quote
all of a sudden, does this bus look like it was cheap?
very complete, primer bus, running, driving, some provenance, gersons panels available...
Rusting Hulk wrote:
So if it went to Germany when did it get to Canada?
1st post in thread mentions an approximation of this
uberwagen wrote:
So technically, the original paint was primer, the next paint was brown beige
my theory on this is that these Primer Buses weren’t actually the bare primer (ie gray) from the factory, but left the factory in that brown beige (or at least parts of the interior were painted in the brown beige)
-StockRocks-
kintail
kintail is offline
PostPosted: Thu Mar 01, 2007 6:42 pm    Post subject: Reply with quote
It would be odd if the pictures were of another owner other than Werner.... as there were photos at the auction such as these and that would be the only source that Kendall would picked these up.
Two pictures identified.....
Overlooking lake/cottage..... old Trans Canada Highway near Kenora.... (another photo was seen with the other '53 off a rockcut at auction)
The other overlooking a valley is on the east side of Osoyoos, BC from a hairpin going into the valley on Highway #3.... overlooks the town towards west along US/Cdn border.
Scott
kintail
kintail is offline
PostPosted: Thu Mar 01, 2007 8:11 pm    Post subject: Reply with quote
Forgot to mention..... look for upcoming NEATO story on known history of this Deluxe and other '53...... should appear sometime soon....
Scott
PostPosted: Thu Mar 01, 2007 8:31 pm    Post subject: Reply with quote
I don't know about Barndoors but there is a 57/58 Single Cab in FL that left the factory in primer and the whole interior is Primer.
malik
malik is offline
PostPosted: Thu Mar 01, 2007 8:32 pm    Post subject: Reply with quote
I agree with Rockstocks in regards to the brown/beige being the primer. As far as the original paint goes, I guess there could be some question. My assumption that Werner Damrath was the original owner and bought this bus new in Germany and brought over to Canada came from Kendall, the second owner, who bought it at the estate auction in 2003.
I would really like to get peoples opinions on restoration, paint color, metal work as I don't want to do a full restoration(i.e. show bus).
Thanks for all information. looking forward to hearing some suggestions!
UZI
Platinum FUBU
UZI is offline
PostPosted: Thu Mar 01, 2007 8:57 pm    Post subject: Reply with quote
too bad the trim got stripped off. that bus was bad ass the way it was.
good luck with it malik. i'm glad to see it's on the east coast. i'd love to see it sometime. maybe for the trailbash at jDOTs?
Extravagant Lifestyle
uberwagen
uberwagen is offline
PostPosted: Thu Mar 01, 2007 10:41 pm    Post subject: Reply with quote
On this particular bus, the brown beige was painted over top of a light grey primer, and it was a high gloss finish just like on my 54. The brown beige was also not limited to the inside of the bus, but was also applied to the whole outside of the bus including under the front window seals, and under the skylight seals.
I think the whole bus was most likely painted brown biege over top of the primer at the factory before its final assembly. What is the likelyhood of someone totally disassembling a "new" bus including removal of the interior, headliner, and all of the windows, just to paint it.
I know the birth certificate says it was delivered in primer, but the fact remains that this bus was painted high gloss L76 brown beige (over top of primer), ...in my opinion, before its final assembly.
(I'll put my pics of this bus back up in the gallery)
RockStock
PostPosted: Fri Mar 02, 2007 1:29 am    Post subject: Reply with quote
how about brown beige on the inside & all the shutwork
dash, windscreen area, cab, inner cargo doors, inner engine lid, maybe around the window apertures
that would leave you to just decide the external colours without disassembly of the dash components (hence why the dashes seen to stay the brown beige), windows, etc. just mask & go
otherwise why would VW have labelled them as in Primer? They would have called them Brown Beige
yes, brown beige on before headliner. so at factory. as uberwagen says, you can see overspray at the top here:
just like how the deluxes were painted:
this theory would mean this bus looks a little 'incorrect':
-StockRocks-
uberwagen
PostPosted: Fri Mar 02, 2007 2:17 am    Post subject: Reply with quote
So what you are proposing is that VW painted the whole interior, dash, around all the windows, doors, deluxe trim in a neutral final paint colour (brown beige) ...so that the customer who ordered the bus in primer would not have to do anything with the interior, or remove the windows...trim... from the exterior
...they would just have to mask the exterior of the bus and paint it the colour of their choosing.
I think you might be right!
It would make perfect sense for VW to do this to provide protection to the areas that would not be disassembled by the customer when painted. Having just primer in the whole interior and in all the nooks an crannies would not be very durable, and would likely rust and wear quite quickly.
That would explain why the brown beige does not seem to extend to far beyond the skylight windows, or beyond the deluxe trim.
Until now I thought that the rest of the brown beige paint on the large surfaces of the bus were sanded off down to primer before the application of the green or red paint.
But if you think about it, it would have been pretty difficult to sand off the brown beige paint with out going through the original primer in at least a couple of spots.
I guess if one were to remove more of the green paint to see what lies underneath, you might be able to tell if any of the large body panels were also brown beige at one time.
RockStock
PostPosted: Fri Mar 02, 2007 6:12 am    Post subject: Reply with quote
yes, absolutely, that would be my theory (& i think your pics currently back it up)
would be great to have a couple of factory colour pics of one of these early Primer Deluxes, just off the assembly line...
makes this one interesting!
for this bus, i guess maintain as much of the paint as is whilst fixing the metalwork issues (& blowing these areas in)
most of the bodywork looks confined to the floor?
for another Primer Bus, perhaps one which needs a full restoration, what paint combo would be the best route??
-StockRocks-
Mango Juice
Mango Juice is offline
PostPosted: Fri Mar 02, 2007 10:29 am    Post subject: Reply with quote
Very Cool Photos Mark!!!
I love the photo with the owner.....all smiles!!!
he loved that bus till the very end!!
I hope once you get it back into shape you enjoy it as he did in the past!!
Thanks for sharing the photos!!! Very Happy
RockStock
PostPosted: Fri Mar 02, 2007 2:26 pm    Post subject: Reply with quote
a pal has seen a vintage photo of a deluxe with the same/similar trim on it
so a period aftermarkert accessory?
malik, do you still have them?
-StockRocks-
Mango Juice
PostPosted: Fri Mar 02, 2007 2:36 pm    Post subject: Reply with quote
now that would be wicked if it is the same bus !!!!
malik
malik is offline
PostPosted: Fri Mar 02, 2007 8:30 pm    Post subject: 53 barndoor deluxe documents Reply with quote
Just thought I'd post the birth certificate and registration card from 1974.
Does anyone have any suggestions on the restoration?
thanks
Lind
Lind is offline
PostPosted: Fri Mar 02, 2007 9:03 pm    Post subject: Re: 53 barndoor deluxe documents Reply with quote
thanks
I would recommend making it just like it looks in those old photos. (truly restoring it to how it was originally used) there are so many brown and red barndoor deluxes out there that they are getting kind of boring. something like this bus is interesting looking. I love the swoopy side trim.
When you realize you are in a horror movie, its too late.
kintail
kintail is offline
PostPosted: Fri Mar 02, 2007 9:49 pm    Post subject: Reply with quote
Is that the pic of a BD Deluxe with the emblem removed and horizontal chrome strips on the nose, custom front roof skylights and other refinements..... Question
Scott
kendalwpg
kendalwpg is offline
PostPosted: Fri Mar 02, 2007 10:56 pm    Post subject: Reply with quote
It was me who stripped off that trim! Trust me, it was not a "period aftermarket accessory". It was the wood craftsmanship skills of the origional owner and it had turned to sh#t sitting out in the elements! It was half rotten and needed to come off and go into the garbage! Werner Damrath was a very talented craftsman (as seen in other works of VW art of his) and I believe this was his work. As far as if he was the origional owner from the factory, there is no reason to believe that he wasn't however there is no hard proof. He is also dead with no living relitaves so there is nobody to ask.
Lind
Lind is offline
PostPosted: Fri Mar 02, 2007 11:27 pm    Post subject: Reply with quote
the primer delivered westfalias and binz doublecabs have grey primer under where the radio blockoff and ashtray are on the dash. those items were not removed before the dash was painted.
uberwagen wrote:
malik wrote:
...Since there was speculation on whether this bus came from the factory in primer this answers the question. Also, the paint job that was on the bus was the original paint which I now have pictures of the original owner on vacation in the bus.
First of all, those pictures are fantastic!
I was just thinking last night that I should send you a pm to ask if you had sent for a birth certificate. I guess you were one step ahead of me.
As far as the paint is concerned, I think we both know that the whole bus was brown biege before it was green!
So technically, the original paint was primer, the next paint was brown beige, and probably soon after the bus was painted two tone green. Not to mention some patches of bright red here and there that I could not figure out. Two say that the green was the original paint job is a bit of a stretch.
In fact, to say that the guy in the picture (Werner), was the original owner of this bus is also speculation. ...Unless you have proof of that also?
Sorry about all the nay-saying. I'm just bitter that I didn't buy it when I had the chance Sad
perhaps it was delivered in primer, painted brown beige, and the red parts were part of some logos for the original owners company in Germany. then Werner got it and did the green/green thing.
it looks damn cool in the green/green.
that roofrack is ugly as hell though.
RockStock
PostPosted: Sat Mar 03, 2007 4:11 am    Post subject: Reply with quote
that swoopy trim looks ally to me. similar to the beltline trim
did it have wood in the space below?
(& what's that loop in the drivers window?)
the vintage pic i mentioned was seen at an auto show in germany. not sure of any other detail
here's the one you're referring to
http://www.thesamba.com/vw/forum/album_page.php?pic_id=325380
yes, as a primer bus, you would think there was a high chance it would be a logo bus
interesting to read the Whine thread, when this bus was discussed when it came up for sale by Kendal in 06 for $35k
starts on p105 (arthurnugen's post), & rumbles on for the next few pages
http://www.thesamba.com/vw/forum/viewtopic.php?t=1...start=2080
so just speculating here (but its interesting): bought in 03 at auction for $3.5k, advertised on thesamba in 06 for $35k, sold in 06 for $27k
-StockRocks-
kintail
kintail is offline
PostPosted: Sat Mar 03, 2007 7:56 am    Post subject: Reply with quote
With all due respect you weren't there........ the "important prices" you quote are wrong.... and once again are rumour...
Really killing eveybody to get the price facts down isn't it..... and for what purpose Question
Scott
Page 3 of 5
