Speedo pod question
Plums
Plums is offline
PostPosted: Wed Jan 23, 2013 12:58 pm    Post subject: Speedo pod question Reply with quote
Can anyone tell me if there is a seal/gasket that goes between the speedo and the bakerlite cluster?
Or does it simply fit in the hole and fixed in place?
Cheers, Sean.
West Ham United Football Club
God save the Queen, Old split buses & Lambretta's
streetwagens
streetwagens is offline
PostPosted: Wed Jan 23, 2013 1:47 pm    Post subject: Reply with quote
I'm pretty sure there's meant to be a felt seal, pretty square in section that's there to stop rattling and vibration, only way to tell is to pull apart a bus thats not been taken apart! Someone on here will know whats there, and whee to get it from! Cool
Edit: I misread the question, my answer is for the Bakelite to pod sorry! Laughing
To catch a fish, you must first think like a fish....
djfordmanjack
djfordmanjack is offline
PostPosted: Wed Jan 23, 2013 3:09 pm    Post subject: Reply with quote
I just disassembled for you a near mint original never messed with standard BD 54 Speedo, that I collected for my 54. There is NOTHING beetween the speedo and the bakelite ! of course there is a rubber seal in the bakelite that faces the speedo pod (dash)metal itself. earlier buses will probably have felt lining there, like earlier split beetles.
Hotrods, Fords, Veedubs and Triumph Twins ! ______Barndoor + Kohlruss Coachbuilt DLX afficionado
'51 Brezel project, Azurblau L36
'52 BD Coachbuild project
'54 Oval Sunroof project with my son, L275 Lichtbeige
'55 Wolfsburg panel project, Taubenblau L31 all original paint
'56 Oval, Polarsilber L324 og paint og chrome og everything
Plums
Plums is offline
PostPosted: Wed Jan 23, 2013 3:14 pm    Post subject: Reply with quote
Thanks dude, I wonder if anyone sells the rubber seal that goes between the bakerlite and pod?
beetleseb
beetleseb is offline
PostPosted: Wed Jan 23, 2013 3:41 pm    Post subject: Reply with quote
My bug had a felt seal
Easy to cut one from some rubber or felt
Seb
Wanted - OG 50 split bug door panels, brown mats and old running boards
PostPosted: Wed Jan 23, 2013 5:41 pm    Post subject: Reply with quote
Brezelwerks sells the felt.
http://www.thesamba.com/vw/classifieds/detail.php?id=145501
EA57RHD
EA57RHD is offline
PostPosted: Wed Jan 23, 2013 7:46 pm    Post subject: Reply with quote
My March of 53 Panel had a rubber seal.
Brezelwerks does have the felt ones as Everett pointed out, but I would like to find a replacement rubber seal if anyone makes them or has an NOS for sale.
----VW's in my garage----
March 1953 DD Panel with rear hatch
11/58 Single Cab
********WANTED********
* Your old SOTO newsletters
* 29 Part number lug nuts
djfordmanjack
PostPosted: Thu Jan 24, 2013 5:23 am    Post subject: Reply with quote
judging from my near mint speedo bakelite this is not a molded one-piece seamless rubber, but it has open ends in the middle suggesting it was made from straight stock. The rubber is 6 x 2.5 mm in cross section and approx. 600mm long. shouldn't be to hard to get this in a machinery equipment store or specializing in seals or have it cut by such a shop from flat rubber stock.
52 deelux
52 deelux is offline
PostPosted: Thu Jan 24, 2013 11:05 am    Post subject: Reply with quote
Sean,
I've used these on my bus, fit perfectly and only 1 each. They are slightly narrower than the original.
http://www.speedoheads.co.uk/p/category/0812065328-Rubber+and+Seals/
Cheers
52 BD Deluxe
57 Ghia golde
54 Ragtop
Trevor P
Trevor P is offline
PostPosted: Thu Jan 24, 2013 11:27 am    Post subject: Reply with quote
I searched for a new rubber seal for my 53 and never found a suitable replacement. I ended up using the felt strips like previously mentioned.
53 Barndoor singlecab
53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
63 Beetle
70 911T
bigbulli
bigbulli is offline
PostPosted: Thu Jan 24, 2013 12:13 pm    Post subject: Reply with quote
I'm sure I got mine from Mark L.
1954 Barndoor
1955 Oval
Barndoor Mirror Arm Screws - http://www.thesamba.com/vw/classifieds/detail.php?...5d3c7d7793
Barndoor Wheel Tray Bolts - http://www.thesamba.com/vw/classifieds/detail.php?id=1997654
