Whats the correct stock tire size?
TimGud
TimGud is offline
PostPosted: Thu Jul 11, 2002 2:22 pm    Post subject: Whats the correct stock tire size? Reply with quote
I need tires for my 74 thing with the factory steel wheels and have no idea what size tire to put on it. Anyone know?
58Type2
58Type2 is offline
PostPosted: Thu Jul 11, 2002 2:27 pm    Post subject: Whats the correct stock tire size? Reply with quote
I may be wrong here, but as far as I knew...unless these are 14 inch rims, that the tires would be 165R15...I think that is right. I think that is almost every VW I know for stock tire size.
Jax
TimGud
TimGud is offline
They are 14" wheels like the later(68-70) bus.
bljones
Resident Wit
bljones is offline
PostPosted: Thu Jul 11, 2002 6:36 pm    Post subject: Whats the correct stock tire size? Reply with quote
correct size is 185/14
[email protected]
sanbar@solidnet.com is offline
PostPosted: Thu Jul 11, 2002 10:02 pm    Post subject: Whats the correct stock tire size? Reply with quote
The original tires were Metzler Monza in 185-14
TimGud
TimGud is offline
PostPosted: Fri Jul 12, 2002 8:29 am    Post subject: Whats the correct stock tire size? Reply with quote
Thanks!
58Type2
58Type2 is offline
PostPosted: Sat Jul 13, 2002 3:02 am    Post subject: Whats the correct stock tire size? Reply with quote
oops, new.
58Type2
58Type2 is offline
PostPosted: Sat Jul 13, 2002 3:16 am    Post subject: Whats the correct stock tire size? Reply with quote
Sorry, now I know something knew. Thank you for informing me here as well.
lastsafari
lastsafari is offline
PostPosted: Thu Feb 27, 2003 8:31 pm    Post subject: Whats the correct stock tire size? Reply with quote
most original tires were 185 14 m/s BF Goodridge.
edgy
edgy is offline
PostPosted: Fri Feb 28, 2003 7:15 pm    Post subject: Whats the correct stock tire size? Reply with quote
We run 185x65R14 Uniroyal. See a trend here?
[email protected]
kubelken@aol.com is offline
PostPosted: Fri Feb 28, 2003 8:17 pm    Post subject: Whats the correct stock tire size? Reply with quote
the first tires were Metzlers, then Continentals later in production became standard. All were 185 SR 14 M+S
I even think they has studded snow tires without the studs installed in some markets.
[email protected]
PostPosted: Mon Mar 03, 2003 8:26 am    Post subject: Whats the correct stock tire size? Reply with quote
The 14 INCH wheels from 73-83 are NOT bus wheels, but 181 specific. Bus wheels will rub on the front upper control arm from incorrect offset.
TimGud
TimGud is offline
PostPosted: Mon Mar 03, 2003 9:10 am    Post subject: Whats the correct stock tire size? Reply with quote
Thanks for trying to let me know that. I should have made it clearer that they are "like" the bus wheel but not the same. I went to great lenghts to come up with the correct wheels from a good man in Canada.The way to tell if they are thing or bus easily is the bus has slots where the center part of the wheel meets the rim and the thing does not. Of course the offset is didderent as well.
ChrisM181
ChrisM181 is offline
PostPosted: Mon Mar 03, 2003 10:56 am    Post subject: Whats the correct stock tire size? Reply with quote
Kubelken, so when I go to get some centerline wheels, Douglas wheels or some other kind of 15 inch offroad wheel what offset do I need to get???
And does the offset only really matter in the front because of the upper control arm rubbing?
