Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Mon Sep 25, 2006 1:59 pm Post subject: SO-42 metal edge protector stuff--source? |
I am looking for a source of some thin white plastic-like material that Westfalia used to protect the top edge of the poptop lip as well as the passenger side raingutter where the tent rail clamps on. It appears to be just folded-over plastic stuff.
Anyone who has had their poptop off knows the stuff I am talking about. Mine was intact and just fine on the poptop, but on the tent rail it was completely disintegrated. I need something there.
Anyone know either a source of a similar product, or have good ideas for what to use on the raingutter to protect it from the tent rail/clamps?
Thanks! |
Stocknazi Samba Member
Posted: Mon Sep 25, 2006 5:06 pm Post subject: |
woody
can you post some pics of the strips you are refering to? my top does not have this. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Mon Sep 25, 2006 5:23 pm Post subject: |
I don't know of a source for the correct stuff, but the first thought that comes to mind for a functional replacement is some door edge guard - you know, the kind of crap they sell at Kragen... |
Barnabus Samba Member
Posted: Tue Sep 26, 2006 6:01 am Post subject: |
Woody,
I think the stuff you are looking for is called "Pinchwelt".
McMasterCarr stocks it.
-O _________________ Slow Moving Vehicle Magnets available. Click here for details. |
Posted: Tue Sep 26, 2006 9:22 am Post subject: |
Pinchwelt is way way too thick.
This stuff is the thickness of a double layer of friction tape.
I will get some photos up soon.
I am thinking of going with outdoor grade polyurethane racer's tape, 14 mil. A roll is $30 though. I don't need 60 yards. |
velvetgreen Samba Member
Posted: Tue Sep 26, 2006 5:35 pm Post subject: |
i think you are referring to the "U" shaped piece of white plastic beading that fits on the perimeter of th flared metal on thepop top hole and prevents the canvas from being torn by the sheet metal flaring? Am I correct?? |
Rain's Westy Samba Member
Posted: Tue Sep 26, 2006 5:46 pm Post subject: |
hummm what about a junk westy? you may find it from someone who is parting one out in the classified's... my 66 has the stuff. is the pop top hole surround long enough for the tent strip as well?
wile on the subject ....anybody got a sorce for the "Y" shaped trim that fits the seam where the top cabinet fit's against the roof? the stuff that is stapled to the cabinet top edge? |
Tim Samba Member
Joined: September 04, 2003 Posts: 170 Location: Texas
Posted: Tue Sep 26, 2006 8:36 pm Post subject: |
The tape solution has worked just fine for me. I took the rails off a few weeks ago and everything still looks good underneath (5 years or so).... _________________ How we spend our days is, of course, how we spend our lives.
Annie Dillard
55 Rag Top
67 Westy |
Posted: Wed Sep 27, 2006 8:58 am Post subject: |
Yes Mike and Velvetgreen, that is the stuff.
I will watch for a junk westy. The stuff is super brittle, it would have to be local pickup. Nice to know that I could use tape if need be.
While on the subject, what do people use on the bottoms of their rack supports to protect the gutters? PO used foam tape, which disintegrated right away. I was going to dip the bottom half inch of mine in black Plasti-Dip--the kind you use on plier handles and the like. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Wed Sep 27, 2006 10:45 am Post subject: |
Major Woody wrote: |
My westy came with rubber/vinyl pieces that folded over the gutter but I've thought about doung the plastic-dip stuff as well. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Wed Sep 27, 2006 11:53 am Post subject: |
I will try out the plasti-dip and see how it works on the racks. It's pretty soft, might not stand up too well on the rack hoop bases but should be ok on the clamps. It doesn't really stick, it just sort of forms around whatever gets dipped into it.
You know what would be really good, would be spray-on bedliner, just on the surfaces that touch the bus. Have it sprayed on (would they even charge you, if you showed up with the pieces all masked?) and then sand down the lumps before installing? Done right, you wouldn't even be able to see it. |
Tim Samba Member
Posted: Wed Sep 27, 2006 1:25 pm Post subject: |
I use small pieces of cut inner tube from a bike which I place under each leg, it folds around the gutter really well. I also dipped the ends of each leg and coated the inside of each clamp with limited success. _________________ How we spend our days is, of course, how we spend our lives.
Annie Dillard
55 Rag Top
67 Westy |
Posted: Wed Sep 27, 2006 1:41 pm Post subject: |
Tim wrote: |
I use small pieces of cut inner tube from a bike which I place under each leg, it folds around the gutter really well. I also dipped the ends of each leg and coated the inside of each clamp with limited success. |
There you go, that's exactly what I'll do. Better than Plasti-Dip, and much easier too. |
Posted: Wed Sep 27, 2006 1:53 pm Post subject: |
Thats the original stuff even though he has it on wrong. _________________ Your Vanagon sucks, Stop waving at me.
Posted: Wed Sep 27, 2006 4:48 pm Post subject: |
inner tube, thats what i was thinking too. that should work good.
what about some cloth electrical tape. really tough stuff and about as thick as the white edging. cheaper than any 30 dollars too, about 5. _________________ WANTED:
Thomas Jefferson |
Posted: Wed Sep 27, 2006 9:32 pm Post subject: |
abeed wrote: |
what about some cloth electrical tape. really tough stuff and about as thick as the white edging. cheaper than any 30 dollars too, about 5. |
It's fabric. i was concerned about it holding water against the paint and also there is no way it would stand up to the UV. |
abuspilot Samba Member
Joined: January 19, 2002 Posts: 1012 Location: Mentally, I'm in Michigan
Posted: Thu Sep 28, 2006 8:17 am Post subject: |
Thanks for starting this thread. Didn't know about this stuff. My poptop still has it on there but the tent rail one is LONG GONE. I guess this is something I'll be needing when I redo my bus. Thanks again. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Thu Sep 28, 2006 7:09 pm Post subject: |
I use leather from an old leather belt. I crushes but won't punch through. It dries when gotten wet, too. |
turbo_g Father of Samba Cookie Lover
Joined: October 30, 2002 Posts: 717 Location: Laguna Hills, Ca
Posted: Thu Sep 28, 2006 7:36 pm Post subject: |
Major,
Are you talking about the underside of the clamp or the bottom of the rack support (foot) that fit's INTO your gutter. For the former, just some rectangular pieces of thin rubber (bike innertube works) and for the latter, I used cut pieces of clear tubing with a hole notched in them, then stretch them over the foot. _________________ Turbo_g
66 TinTop Westy SO42
63 Sub-hatch Westy SO33
SV2s Member #425
"Three out of four voices in my head say 'Go for it'." |
Posted: Tue Oct 03, 2006 9:25 am Post subject: |
turbo_g wrote: |
Major,
Are you talking about the underside of the clamp or the bottom of the rack support (foot) that fit's INTO your gutter. For the former, just some rectangular pieces of thin rubber (bike innertube works) and for the latter, I used cut pieces of clear tubing with a hole notched in them, then stretch them over the foot. |
Good ideas, all! Thanks |
