nsracing Samba Member
Posted: Wed Sep 27, 2006 2:49 am Post subject: Stroking a 36HP VW and Chevy Carrillo rods... |
I have always been fascinated by the 36HP VW engine. I am going to HotRod one just to see. I wonder how much stroke you can grind in the stock crank will fit in that thing.
I am also contemplating longer rods...in the 6 inch range.
The Chevy Carrillo or Eagle units seem like good donors.
Is there any performance cams for the 36HP? Everything else can be grafted from other VW engines but the cam I am not so sure if any aftermarket supply out there.
I will set up a TruLine for alignboring the mains. Cam inserts will be a must on this one.
Main bearings? Well...these are going to have to be custom machined.
I know these are more rare than rooster teeth. |
Al Fodel Samba Member
Posted: Wed Sep 27, 2006 3:11 am Post subject: |
you must be really bored Nick. How's that notch drag car coming along? |
Posted: Wed Sep 27, 2006 3:15 am Post subject: |
Al Fodel wrote: |
I got me a crank grinder, Al. I am excited. I will finally be able to do what I have always wanted. Stick some BigBlock Chevy rods in the flimsy 36HP VW.
You think Titanium valves will be nice in the heads too?
The Notch is coming along good. The garage is getting expanded a little.
More room is good. How is everything down there? |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Wed Sep 27, 2006 8:33 am Post subject: |
I've got one set up right now with H beams on a 72mm stroke,5.4 rods.I'll post some pictures later today.Two ways to tackle the cam bearing problem.Cut the case for stock 40hp/1600 cam bearings and weld/regrind the mains on the 36hp cam for the bigger bearing,works fine but is a pain in the neck (hard to find a welder that can do it).Or cut for the smaller size and make some bearings from a donor set,you'll have to cut the oil holes by hand.Two performance cams in stock,if I can get a local grinder motivated,I may have a couple more choices.
My faux paux,rods are 5.4,not 5.6 as previously stated. _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy
Last edited by Mr. Motorhead on Wed Sep 27, 2006 3:16 pm; edited 1 time in total |
jamestwo Samba Member
Posted: Wed Sep 27, 2006 9:22 am Post subject: |
Mom told me if i couldn't say something nice, not to say anything at all. _________________ hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY. |
bugnut68 Samba Member
Joined: June 10, 2003 Posts: 4180 Location: Eugene, OR
Posted: Wed Sep 27, 2006 11:20 am Post subject: Re: Stroking a 36HP VW and Chevy Carrillo rods... |
nsracing wrote: |
Seems to me it'd be more resourceful to sell off the parts to a vintage restorer who'd make good use of the engine rather than try to reinvent the wheel again, but hey, that's just me. |
Posted: Wed Sep 27, 2006 12:27 pm Post subject: |
Mom told me not to say something just like that bugnut68, she also said that a short stroke and long rod is going to make for a lazy bottom end. _________________ hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY. |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Wed Sep 27, 2006 6:40 pm Post subject: |
jamestwo wrote: |
Mom told me not to say something just like that bugnut68, she also said that a short stroke and long rod is going to make for a lazy bottom end. |
Lazy bottom end ...my foot. Sure...if you have teeny--weenie valve size.
I for one really do not like soggy bottom end. The combo will make sense. Let me handle it. |
Iowa Mark Samba Member
Posted: Wed Sep 27, 2006 8:00 pm Post subject: |
Maybe since you've got that new crank grinder, you should start looking into regrinding cams too! .520 lift in a 36horse? Why stop now. After seeing those guys at the Bug-in a couple years ago with the turboed 36 on the strip, I say go nutz, dude! |
Posted: Tue Oct 03, 2006 8:07 pm Post subject: |
Iowa Mark wrote: |
cam grinding? Doesn't somebody grind cams already for the 36HP?
I just brought the STorm Vulcan crank grinder home from Alabama. It is trully one nice machine....loaded too.
Maybe we can do more 74mm strokers than 69mm strokes. No more 1776cc? more 2054cc? |
Terry Cloyd Banned
Joined: March 23, 2004 Posts: 2218 Location: Valley Center "SO CAL"
Posted: Tue Oct 03, 2006 9:02 pm Post subject: |
There should be drug testing on this post. |
Droolman Samba Member
Posted: Wed Oct 04, 2006 2:40 pm Post subject: |
nsracing call Clarke Sr. at oakhill automotive 903-297-3496. clarke sr. has been grinding vw cranks for 40 years. he can tell you more about it than anyone in this country. hope this helps _________________ 1967 blue bug
1965 drag bug |
Posted: Wed Oct 04, 2006 3:41 pm Post subject: |
Terry Cloyd wrote: |
What is wrong Terry? You do not like a little Viagra to help out a smaller motor?
Hell...I had just gotten done putting Titanium valves in my Sears Lawnmower...Briggs and sTratton. There was not much porting though. |
Vayabroder Samba Member
Joined: April 04, 2006 Posts: 989 Location: Hollywood, FL
Posted: Wed Oct 04, 2006 4:28 pm Post subject: 36 hp |
I recall seeing old school VW drag cars with souped-up 36 hp powerplants in magazines so I guess it's not too farfetched. Okrasa used to supply some performance parts; maybe Joe Ruiz (Mr. Okrasa) might be able to shed some light on this subject. |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Wed Oct 04, 2006 4:37 pm Post subject: |
I have been working with an individual utilizing a 36HP engine for land speed racing. His car will be unveiled next season..
Lets just say it makes power in the 3 digit levels on my dyno.
For a cam we used a roller profile from a BB Chevy with some changes on a 8620 CNC machined blank. Till that point he was shearing cams at the center main.
This 36 HP also has cam bearings and uses 356A cylinder heads with serious mods to the case and heads. It runs 14:1 CR as well... _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Wed Oct 04, 2006 5:16 pm Post subject: |
Jake Raby wrote: |
Lets just say it makes power in the 3 digit levels on my dyno... |
Ummm, 3 digit power levels? Would that be something like, say 40.2...?? I look forward to hearing more about this one, Jake!
I like the sound of the hotrod 36'er - Why not go with a Ducati-style desmo valvetrain while you're at it? Or go with rotary valve heads...
http://www.coatesengine.com/engine_of_the_future.html
Air-cooleds are great; be different!
bnc |
Posted: Wed Oct 04, 2006 5:18 pm Post subject: |
The money he has spent on this endeavor could buy 10, 200 HP engines!!
But he is bound and determined to head to Bonneville for speed week next year! _________________ Jake Raby
EXITSTRATEGY Samba Member
Joined: March 27, 2006 Posts: 450 Location: rolling thunder river company, nantahalla gorge. NC
Posted: Wed Oct 04, 2006 5:46 pm Post subject: |
and these 3?'s will look stock? _________________ I'm living down by the river and i don't even have my 'van'... |
Posted: Wed Oct 04, 2006 6:05 pm Post subject: |
I hear you about that "salt" ailment, Jake. There's a pair of brothers around here that caught the fever a few years ago with a blown flathead Ford. |
