BirdLives Samba Member
Joined: August 20, 2005 Posts: 329 Location: NorCal East Bay
Posted: Fri Sep 29, 2006 1:32 pm Post subject: New engine for the 67 |
The stock engine in the 67 I just bought 3 weeks ago seized cruising back from the Bugs by Bay show.
I've decided to put my money into quality parts rather than trying to go faster. Engine will be a stock H-case 1500 single-port (really 1600),stock carb, heads and exhaust. Here are the changes I'm considering and some questions.
-doghouse fan/cooler
Can I still use my generator?
-case tapped for full-flow with Berg kit, also case savers
The oil pump studs are different on the 1500, will that berg pump cover fit? Also, what size oil pump should I use? Can the stock one handle the full-flow?
-counterweighted 69mm crank from DPR or DMS
-Very mild cam like a webcam 119 (.422 lift, 242 duration @.050)
Am I waisting my time with this? Short of ceramic what lifters should I use with this or the stock cam?
Let me know what you think. Thanks. _________________ 1967 Bug, 1967 Ghia
NorCal Aircooled Group (N.A.G.)
meets every 2nd Friday in Pleasanton
www.norcalaircooledgroup.com |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Fri Sep 29, 2006 1:34 pm Post subject: Re: New engine for the 67 |
BirdLives wrote: |
Let me know what you think. Thanks. |
Doghouse cooler would work... and you can keep the gen...
BUT... IMHO you should get a late model dual relief case and not spend the money on that H case.
http://www.thesamba.com/vw/forum/viewtopic.php?t=61572&highlight=savers
http://www.thesamba.com/vw/forum/viewtopic.php?t=78104&highlight=case |
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Fri Sep 29, 2006 2:59 pm Post subject: |
I second that! If you want a more bulletproof engine, use a modern case. _________________ die schwarzen Schafe #666 |
Alan Willis Banned
Posted: Fri Sep 29, 2006 3:48 pm Post subject: |
Yes. Those cases are as good as you can get! John has made many 2332's out of that style case with no probs. _________________ die schwarzen Schafe #666 |
Posted: Fri Sep 29, 2006 5:10 pm Post subject: |
I guess it is silly to skimp on the case, that would also solve my compatability problems with the oil cooler and pump cover. I kinda like the idea of having that "H" on there for originality sake, but I can let it go to avoid seeing the tow-truck man again.
I know it's really controversial, but what do you guys think about the cam/lifters? SLR'd scats with that webcam? _________________ 1967 Bug, 1967 Ghia
Alan Willis Banned
Posted: Fri Sep 29, 2006 6:50 pm Post subject: |
I only use Engle cams and stock German lifters.SLR covered lifters are bulletproof,but are you building a high horse engine? _________________ die schwarzen Schafe #666 |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Sat Sep 30, 2006 5:59 am Post subject: |
your new case can be stamped with anything as they are not stamped. pump can be installed with washers-per gene berg tech articles. the berg articles are worth the $35 they cost. the combo of the the berg tech articles and the bentley manual for 66-69 beetle will give you correct info to do this build once. i would use a engle 100 or 110 cam thou' _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
volksfiend Samba Member
Joined: June 01, 2004 Posts: 283 Location: Mo....West of Mexico
Posted: Sat Sep 30, 2006 6:47 am Post subject: |
Just a tip. Start adding up all the bits for doing your build correctly....then consider the factory crate longblock from a reputable vendor. Some nice details on the new mexizillian blocks. Long reach spark plugs, larger valve adjusters, REAL VALVE GUIDE SEALS. All new..factory built. |
Posted: Sat Sep 30, 2006 11:03 am Post subject: |
bill may wrote: |
the berg articles are worth the $35 they cost. the combo of the the berg tech articles and the bentley manual for 66-69 beetle will give you correct info to do this build once. i would use a engle 100 or 110 cam thou' |
Glad you chimed in Bill, I was trying to lure you in by putting '67' in the title. I've got the Bently, I'll order the Berg articles along with the full-flow kit. Anything else I should absolutely order from Berg?
I'm under the impression that even the Engle 100 would be too much cam for the single-port heads and stock exhaust. I do a lot more hill driving in 3rd than freeway driving so I want a good powerband in the 2-4k rpm range. Will the engle give me that? Do you agree with Alan that VW lifters are the way to go? I'm really freaked out by all the flattened cams I've read about.
Volksfiend-
I am still considering it. I agree, when you add up the cost of all the parts you don't save all that much. One big thing turning me off from the pro builders is the 3-month turn-around times for most of them. Also, I'm just a real "do-it-yourself" kind of person. I plan to own acvw's for the rest of my life, so the learning experience is worth a lot. This would be my second engine build (though the first one still isn't running right ) Also, I'm now lucky enough to be part of a local club with some very knowledgeble guys to help me out, something I didn't have on the first one. _________________ 1967 Bug, 1967 Ghia
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Sat Sep 30, 2006 4:00 pm Post subject: |
if your still wanting to retain the single port heads i would just build the engine up stock. if you go with dual ports, you could throw ina mild cam and some kads...but id use a counterweighted crank for sure. _________________ 67 bug x3
67 ghia
64 bug |
Alan Willis Banned
Posted: Sat Sep 30, 2006 5:22 pm Post subject: |
A.J. made a badass single port engine (with the help of Jason Lauffer I think) If memory serves it was either a 1915 0r 1904? I remember it made good hp, but great torque for its size;a real sleeper! _________________ die schwarzen Schafe #666 |
Posted: Thu Jan 04, 2007 6:19 pm Post subject: |
Opened the case today with Mikes help -thanks Mike- Thought you guys might like to see a taste of the carnage.
The cam was broken into 4 pieces and the case mushroomed out around the cam bearings.
Anybody need a boat anchor _________________ 1967 Bug, 1967 Ghia
Posted: Thu Jan 04, 2007 7:24 pm Post subject: |
WOW
too bad you wernt able to enjoy the car longer before she gave up the ghost. btw i spoke to my dad a few weeks ago and i inquired if you had contacted him about an engine, he said he couldnt place your name, and could not recall an email from you. he did however have some computer problems, so your info could have gotten lost. he is coming out here soon and i hope his itenerary includes a NAG meet day so he can meet you and everyone else.
how are the rebuild plans going? _________________ 67 bug x3
67 ghia
64 bug |
dog_jr911 Swamp Donkey Assistant
Posted: Thu Jan 04, 2007 7:43 pm Post subject: |
if you are going to rebuild the engine, you should go get a 500 $$ case. you can still get used new model cases for cheap. _________________ AKA Chris™
ROCKIN a ESP LTD F2E |
60's Burnout Samba Member
Joined: December 10, 2006 Posts: 424 Location: SF Bay Area
Posted: Fri Jan 05, 2007 2:11 am Post subject: |
Not to diss you, but do you have a 10,000 watt sound system? Turned to 11?
That rod must have been banging for a quite a while to get that blue. Were you on 680 doing 75, to keep up with traffic? You could have fragged it in 30 seconds or so there.
Build two engines, a stocker and a 2276 with your choice of goodies. You can swap them out in a couple of hours.
If you can afford to live in the Bay Area, you can buy two engines. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Fri Jan 05, 2007 11:32 am Post subject: |
Sorry to hear of your engine mishap; your car looks very nice. I know your pain; a mild 1600 dual-port that I built from scratch, though with many good/serviceable used parts, blew up on me after less than 300 miles. Have not investigated yet what happened. My success is way down building VW engines, even mild ones.
I'd also recommend Berg's dipstick oil temperature warning "stick" which flickers the oil warning light in the speedo (the one on the right) when the oil temp gets above about 220F. This may not prevent a situation like you just experienced, but certainly is another visual clue for prevention.
I see no reason why a well tuned stock 1500/1600 cannot maintain "75mph", and would not hesitate to do so.
Have you notified your engine builder of this damage?
The GoldenGate chapter of the vintage VW Club of America is very active in the Bay area; actually down in the San Jose area. They meet monthly and have several people who are excellent in building dependable, stock engines. That is the club which puts on the Kelley Park meet in San Jose mid-April. |
Posted: Fri Jan 05, 2007 1:24 pm Post subject: |
Hey, thanks for all the advice guys. I think at this point I'm just going to build it back to stock but with a dual-relief case, cw crank and full-flow. It will have to be as the budget allows which at this point may mean after I sell the ghia.
60's Burnout wrote: |
It was about 20 seconds total from the first unusual sound to the enigine seizing. For the first 4 seconds or so I thought the sound was coming from a neigboring car since I was in traffic with the windows open and the radio on. Before that it was performing great and I am confident I didn't ask more of it than a stock 1500 should be capable of. It happened cruising at 60 on flat ground, it was just it's time to go. About a week before it shredded a fan belt at a stop light and I had to drive about 1/2 block to pull over, it did get pretty hot I suppose it could have contributed.
I would love to have 2 engines, but with no garage I don't think my wife will let me keep the spare in the bathtub. As for living in the Bay Area, I rent a condo that my Grandfather bought in '73, if not for that I couldn't afford to live here. _________________ 1967 Bug, 1967 Ghia
Posted: Fri Jan 05, 2007 1:33 pm Post subject: |
Rome wrote: |
The engine was built for the previous owner by a garage in San Rafael. I hadn't really thought of contacting them, maybe I'll look through the stack of receipts that came with the car and see how many miles it had on it.
Ya, Kelly Park is the best show of the year in Nor Cal in my opinion. One of their members, Jim Kikuchi is also a member of my east-bay club NAG (Norcal Aircooled Group). There are a lot of really knowledgeable people there too. In fact, when I get all the parts together I'm thinking engine building party - pizza, beer, setting end-play - well, maybe not in that order. Jason, Jim, Regis, Mike, what do guys think? Maybe when the weather gets a little warmer... _________________ 1967 Bug, 1967 Ghia
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
I'm with Bill on stamping a new case with your numbers if you want to be "purist". While it is all apart and you are building from scratch I would build it a 1776cc, have a set of single port heads opened up to 041 specs and ported, use an Engle 100 cam ( due to single carb) and run a counter weighted crank. Everything will work fine with a late model doghouse oil cooler & fan housing, you'll need a late front breastplate tin & the various bits of ducting. I have a customer running this spec 1776 that I built 15 years and 150,000 miles ago and aside from a valve job with guides and new rings for good measure at 115,000 miles it is still going strong. _________________ Midwest Autosavers, Inc. Woodstock, IL |
