Tall Bloke Samba Member
Joined: October 07, 2005 Posts: 233 Location: UK>Ohio>UK
Posted: Thu Oct 05, 2006 7:16 am Post subject: What is this hook ? |
Does anybody know if this is a coat hook or rear seat latch hook? It was found under the rear seat of my Dec 58 coupe. I am missing the coat hooks ( thought they are chromed steel) this part is Aluminium, and it is different to the the rear shelf hook.
Tim _________________ -------------------
All of 30 horses ! |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Thu Oct 05, 2006 7:28 am Post subject: |
I didn't think ghia's came with seat belts until the later 60's..... |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Thu Oct 05, 2006 7:33 am Post subject: Re: What is this hook ? |
Tall Bloke wrote: |
Tim |
Man, that hook is HUGE when compared to the size of your car!!
(looks like rear seat latch hook to me) |
retrowagen Samba Member
Posted: Thu Oct 05, 2006 8:19 am Post subject: |
Rear seat latch hook. _________________ David Ruby
President, Karmann-Ghia World Club |
KPottorff Samba Member
Posted: Thu Oct 05, 2006 11:49 am Post subject: |
I gotta go against the grain.
I think its a coat hook and you will probably find only one of them on the passenger side. |
walkerman Samba Member
Posted: Thu Oct 05, 2006 12:04 pm Post subject: |
It's the hook for your shoulder seat belt, so you don't have to keep reaching behind the seat to find it. |
coad Samba Scapegoat
Posted: Thu Oct 05, 2006 12:16 pm Post subject: |
retrowagen wrote: |
Rear seat latch hook. |
Agreed.
Unless that is your actual car and not a model the hook is next to. In that case the thing is huge and I have no idea what it's for. |
bt Samba Member
Joined: January 29, 2004 Posts: 441 Location: chicago
Posted: Thu Oct 05, 2006 2:14 pm Post subject: |
looks like the hook on verts that guides the tension cable. Those are usually black. |
honky Samba Member
Joined: August 10, 2006 Posts: 149 Location: Connecticut, USA
Posted: Thu Oct 05, 2006 8:28 pm Post subject: Hooked |
Its either the hook for the strap on the rear shelf when the rear seat back is up or the hold down hook for the strap when in the down position |
HouseofGhia Samba Member
Joined: February 17, 2005 Posts: 855 Location: Salem, or
Posted: Fri Oct 06, 2006 12:06 am Post subject: |
retrowagen wrote: |
No argument.....Retro's correct. _________________ House of Ghia specializing in Karmann Ghia parts, service, and restorations. www.house-of-ghia.com |
Posted: Fri Oct 06, 2006 6:50 am Post subject: |
Rear Seat Backrest hook
Part Number: 885-561 56 67 RP
Ghia through 67.
1956 - 1967
Our Price: $6.95
Item in stock! |
jimmy4 Samba Member
Joined: March 06, 2004 Posts: 230 Location: Toronto Canada
Posted: Fri Oct 06, 2006 1:01 pm Post subject: |
it's a coat hook, i have it in my car. |
Posted: Fri Oct 06, 2006 1:20 pm Post subject: Re: What is this hook ? |
Rear seat backrest hook
coat hook _________________ House of Ghia specializing in Karmann Ghia parts, service, and restorations. www.house-of-ghia.com |
DaveM Mad Samba Scientist
Joined: June 11, 2002 Posts: 3010 Location: Dry side of Oregon
Posted: Fri Oct 06, 2006 1:26 pm Post subject: |
And to note, there are two rear seat back hooks, one to keep it up and the other to keep it down. _________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
Posted: Fri Oct 06, 2006 1:27 pm Post subject: |
I hadn't noticed the difference before - one is flatter than the other throught the hook. |
Posted: Fri Oct 06, 2006 1:42 pm Post subject: |
DaveM wrote: |
And to note, there are two rear seat back hooks, one to keep it up and the other to keep it down. |
True ....one on the parcel tray or rear shelf, and the other on the front seat bottom support (although most of the time these are missing) _________________ House of Ghia specializing in Karmann Ghia parts, service, and restorations. www.house-of-ghia.com |
Posted: Fri Oct 06, 2006 1:45 pm Post subject: |
Interesting thought... I can see how in the up position, the rubber hold'em piece faces correctly back towards the rear parcel shelf. But in the down position, the rubber would have to be bent 180 degrees to hook onto bottom the hook . Or am I missing something? _________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Fri Oct 06, 2006 5:37 pm Post subject: |
DaveM wrote: |
Interesting thought... I can see how in the up position, the rubber hold'em piece faces correctly back towards the rear parcel shelf. But in the down position, the rubber would have to be bent 180 degrees to hook onto bottom the hook . Or am I missing something? |
The rubber strap has a metal washer that allows it to spin 360 degrees. _________________ It's not about the window, it's about the people.
German Folks |
Banzai KG Samba Member
Joined: April 10, 2004 Posts: 2992 Location: Sunnyvale, CA
Posted: Fri Oct 06, 2006 6:09 pm Post subject: Re: What is this hook ? |
I too agree with the rear seat strap hook, compared it with my rear seat strap hook and looks the same to me. _________________ Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/ |
execk2 Samba Member
Joined: April 30, 2005 Posts: 1359 Location: Quebec City
Posted: Mon Oct 09, 2006 5:33 am Post subject: |
WOW looks like a boat anchor in retrospect to the size of the car. Could be you drop it out incase of brake failure? _________________ Mike
www.mikeandjosee.com |
