I would like to thank my bug's PO for...
Page: 1, 2, 3 ... 15, 16, 17  Next
atye
atye is offline
PostPosted: Sat Oct 07, 2006 11:16 am    Post subject: I would like to thank my bug's PO for... Reply with quote
Anyone have any horror stories that they found later after buying a VW?
Rolling Eyes
I'd like to thank the PO of my VW for: Doing such a great job on re-welding the frame head back on the pan after what must have been a good hit to the front. He did such a great job that the entire beam was moved to the rear about 3-4 inches and he added some sort of homemade reinforcement tubes from the pan to the beam on each side. I ended up replacing the whole pan because that one was so bad.
Who's next?
Wink
Alex
1968 VW Beetle (Class 11 look-alike project)
2004 Kawasaki ZG1000 Concours
2005 BMW 330ci convertible
BrianHulud
BrianHulud is offline
PostPosted: Sat Oct 07, 2006 11:35 am    Post subject: Reply with quote
somehow getting a fist sized rust hole behind the drivers seat when the rest of the car paint undercoat pan etc was in PERFECT condition...and for removing the Zbar (i just put this back in)
justbuggin
Resident Brit
justbuggin is offline
PostPosted: Sat Oct 07, 2006 11:37 am    Post subject: Reply with quote
Thanks to my PO for getting part whay through a disasterous RHD conversion on my 58, before giving up & selling it:
Rob
www.justbuggin.co.uk
1958 Rag Cal Import
T25 Panel Van
Paul Wilson
Paul Wilson is offline
PostPosted: Sat Oct 07, 2006 12:44 pm    Post subject: Reply with quote
Damn ! You mean you guys buy this kind of junk after looking the car over ? I mean you couldn't tell the beam was push back this far ?
Paul
atye
atye is offline
PostPosted: Sat Oct 07, 2006 12:54 pm    Post subject: Reply with quote
Paul
Well, not at the time... believe it or not. I noticed it when i was looking at the loose king/link pins and saw a strip of green paint ahead ofthe shock tower underneath the spray-on undercaoting where the shock tower USED to be... LOL. The body was in pretty good shape and I was looking for a mild project anyway.
I'll tell you about the 3/8 rubber fuel line he ran under the running boards alllllll the way to the back of the car later. Wink
The car is sitting on a 1972 IRS pan now after a "weekend job" that turned into 6 months.
Alex
xnakx
xnakx is offline
PostPosted: Sat Oct 07, 2006 2:03 pm    Post subject: Reply with quote
try replaceing a head that was JB welded to the barrels and the barrels JB'd to the case. Smile
-- The Backyard Butcher --
66 Sedan WIP (Work In Progress)
71_transporter
71_transporter is offline
PostPosted: Sat Oct 07, 2006 6:08 pm    Post subject: Reply with quote
wow the jb weld king was in the house that must suck. kinda like the p.o. of my super cutting it into a baja. stupid
Bryan
Old hippies never Die, They just go up in Smoke!
63 Bug
67 Bug
82 WestfaliaVanagon
xnakx
xnakx is offline
PostPosted: Sat Oct 07, 2006 6:30 pm    Post subject: Reply with quote
after i found what looked to be JB on the case seem i tool a hammer and a chisle to it. I wanted to keep the cam and crank.
i must say that it did not leak at all though when it was running Smile
RareAir
RareAir is offline
PostPosted: Sat Oct 07, 2006 8:18 pm    Post subject: Reply with quote
I'd like to thank all the previous owners of all my current rides. They took very good care of them as none of my cars are hack jobs- unless you count my '61 sunroof which I grafted an original Golde sunroof to it Wink but that would be my fault Embarassed
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
.FRY
.FRY is offline
PostPosted: Sat Oct 07, 2006 9:27 pm    Post subject: Reply with quote
I would thank my PO for installing a nice Gene Berg built 1835 in it back in 1991 (PO gave me all of the receipts from this car), and covering the original paint with black primer. Not to mention all of the other Berg parts, like the mid trannie mount, and the rear traction bar, the berg 1.5 qt sump and full flow. I had to get rid of the butt-rock air scoop (on a shelf in my bedroom).
When I found it.
As it sits today.
Boiler Up.
56 SC.
62 Bug.
scottyhoffo
scottyhoffo is offline
PostPosted: Sat Oct 07, 2006 11:21 pm    Post subject: PO and POS Reply with quote
I thank whichever PO of my '61 decided to cut the dash to put in an aftermarket radio. Schmuck.
...at least they left the "no gas gauge" dash trim in place. Smile
Scott Hoffman
1961 Beetle sedan
"You've been Volkswagened- passed by 40 hp!"
Kris Styes
Kris Styes is offline
PostPosted: Sun Oct 08, 2006 1:58 am    Post subject: Reply with quote
Our PO cleaned the contacts on the fuse box. When we purchased the car, nothing (I mean nothing) worked. It was a great selling / bargaining point for us.
Spent 15 minutes and $ 15.00 at the mechanics shop making / changing the wire connects to the box, and everything worked!
Some PO work is disastrous, but in our case, it was financially advantageous.
Kris (Kansas)
Nothing to say!
Pfc J
Pfc J is offline
PostPosted: Sun Oct 08, 2006 6:02 am    Post subject: Reply with quote
I'd like to thank my PO for the hack welding job done to my clutch fork with what suspiciously looks to be small bit's of coat hanger, the one bolt holding the master cylinder in, and hand tight axle nuts.
I would like to thank them for not every touching the inside. Very Happy
Alan Willis
Banned
Alan Willis is offline
PostPosted: Sun Oct 08, 2006 6:24 am    Post subject: Reply with quote
I would like to thank all the PO's that abandon their cars in feilds, so I can get them cheap Cool
die schwarzen Schafe #666
Jason C
Jason C is offline
PostPosted: Sun Oct 08, 2006 8:21 am    Post subject: Reply with quote
I had a euro 66 that had the same dash. I could never figure out why? The hair brained ideas that some people get. While looking for a junk car with a donor dash, I found my 64 in better condition with good performance parts on it for $300. The dash even still has the radio hole still in tacked. Thanks PO.
Throw me a bone here. All I wanted were
sharks with friggen laser beams attached to their heads.
64 Bug
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Oct 08, 2006 9:54 am    Post subject: Reply with quote
The PO of my '65 Bug that used a thick paper clip to extend the clutch cable at the pedal cluster (he connected it at the rear first so it couldn't reach the hook at the cluster--so he then added washers at the rear end under the wingnut). Knifed right through the metal. Did I mention he was proud that he had also rebuilt the engine? I started saving for a rebuild that day.
AZ65CalBug
AZ65CalBug is offline
PostPosted: Sun Oct 08, 2006 10:44 am    Post subject: Reply with quote
My dash was torn out to by the PO. Damn PA!
My Current Project is at:
https://www.facebook.com/pages/1965-Cal-Bug/172194646214739
please like the page to get updates as they happen.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger Facebook Gallery Classifieds Feedback
millerje78
Samba Amishman
millerje78 is offline
PostPosted: Sun Oct 08, 2006 11:20 am    Post subject: Reply with quote
I would like to extend my gratitude to all Previous Owners...without them, none of us would have our small wonders. Smile even when they are hacked up, we still enjoy fixing them.
always seeking a better way
my 73 standard project
do your research, consult with experts, and buy quality parts. you won't be sorry
KTPhil is offline
PostPosted: Sun Oct 08, 2006 11:41 am    Post subject: Reply with quote
Yes, I have gratitude for my dad's foresight to buy the '71 fastback new and then hand it down to me... now being restored so he can drive it again.
rickc'svdubs
rickc'svdubs is offline
PostPosted: Sun Oct 08, 2006 12:08 pm    Post subject: Reply with quote
When I found it.
As it sits today.
what did you use to remove the black primer without destroying the paint underneath? i have tried grafitti remover, pledge power dissolver, wet sanding...
Page 1 of 17
