QtrMileJunky Samba Member
Joined: October 19, 2005 Posts: 147 Location: Richmond VA
Posted: Sun Oct 08, 2006 6:24 am Post subject: Brake upgrade and lowering options (pics) |
I have a 67 pan (with 65 body) with wide 5s and ball joints. The stock brakes SUCK and the front looks like a 4WD!
I want to make it stop better and lower it. It is not fast enough, driven enough or worth enough to get a $600+ disk brake kit. I do NOT want to mess with the beam either.
I heard that there was a drum upgrade from a bus or something.
1. what are my cheap brake improvement options? Cost?
2. I think I want to get drop spindles (67). How much are they, will they work with bigger drums? AND will my full leangth beam work with drops?
Thanks
Ian _________________ 40 cars in 40 years and counting
Currently driving: 65 bug, 88 Mustang GT w/350HP 5.0, 95 BMW 325i, 77 F150 4x4, and a 2007 Focus Wagon |
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Sun Oct 08, 2006 6:29 am Post subject: |
What do you mean by your brakes suck? With everything functioning prtoperly, stock VW brakes work fine. You can change the shoes to semi-metallic, and change the MC to a later model dual and add a '67 reservoir. The semi shoes grab better than OG shoes, and the dual MC has bigger chambers than a single MC which will apply more force to the shoes enabling better stopping power. _________________ die schwarzen Schafe #666 |
aircooledberndoggie Samba Member
Joined: September 04, 2005 Posts: 136 Location: Central Coast via SO CAL
Posted: Sun Oct 08, 2006 7:08 am Post subject: |
I know you dont wanna mess with the beam; but I removed and cut mine and it's actually really easy to do {66 ball joint} myself and had adjusters welded in . Welding $40.00 adjusters $40.00 {with shipping} from CIP1, and got 4 1/2 inches of drop. {The drop depends on the angle you weld in the adjusters}Dropped spindles will cost somewhere around $175.00 but the ride is way better. As for brakes.......Thats a whole other subject i also need to deal with ........Peace |
henrym Samba Member
Joined: August 19, 2006 Posts: 1002 Location: Marina Del Rey, California
Posted: Sun Oct 08, 2006 9:22 am Post subject: |
I agree on the stock brakes. I drive other cars with mombo disc brakes and I have to hand it to VW, those little drum brakes aren't actually that bad. If they are adjusted correctly and a good MC and plumbing, they do the job.
That being said, I am switching to discs in the front. Only because I am putting in dropped spindles and I figured while I have the thing apart, I might as well do the job right and get the discs. I real wallet bender though...ouch. |
Posted: Sun Oct 08, 2006 9:32 am Post subject: |
I replaced the master and adjusted them and they suck. They are dangerous _________________ 40 cars in 40 years and counting
wethebmx Samba Member
Posted: Sun Oct 08, 2006 12:44 pm Post subject: |
yah man, stock vw brakes work great. the brakes on my 62 rock, and they are all stock. new pads all around, wheel cylinders. they are nice. as far as lowering it. man, i just yanked outr the torsion bars. i think i did 5 in each tube. its rides rough, but definately liveable. and its free. alot of people say dont do it that way, but people used to do it like that all the time, just now, everyone narrows the beam, gets dropped spindles, disks. they all work great, but i guarntee you'll be pretty happy by going the cheap route.
David.
if you dont like the ride, you can always put the torsion bars back in ad go the expensive route |
boogerbandit04 Samba Member
Joined: September 15, 2006 Posts: 376 Location: San Jose, CA
Posted: Sun Oct 08, 2006 12:54 pm Post subject: |
You know, alot goes to USER ERROR!!! I just replaced the whole break system (drums, shoes, hoses) and to be honest, the drums are FINE!! They do the job really well, dangerous i dont know about, unless you tweeked something when working on them. And as far as lowering, get some drop spindels. It will go down about 2 inches and retain stock ride, but improve handeling a little. Dont have that kind of attitude about your car, anything you do to it is going to improve it value, so its not like your really flushing money down the shitter. |
Posted: Sun Oct 08, 2006 1:08 pm Post subject: |
OK OK I will deff give the stock brakes another shot, maybe I will overhaul them. I just hate working on drum brakes Every time I do I swear it will be the last!
Here is another question: I have some play in the front end, what parts should I change while I am in there to make this car feel more safe at high speeds? Got list?
Thanks!!! _________________ 40 cars in 40 years and counting
rloaircool Samba Member
Joined: January 21, 2004 Posts: 304 Location: Idaho Falls, Idaho
Posted: Sun Oct 08, 2006 2:46 pm Post subject: |
QtrMileJunky wrote: |
Thanks!!! |
Get CB dropped spindles.
http://cbperformance.com/catalog.asp?ProductID=478
You will also need 145s if you don't want to rub.
http://www.thesamba.com/vw/classifieds/detail.php?id=131715
Go through the front end, replace everything that needs it. Check bearings, ball joints, shoes, drums, master cylinder to reservior line, brake hoses, wheel cylinders, drums, steering stabilizer, tie rod ends. Chances are you atleast need new tie rod ends. _________________ 59 ragtop beetle |
dog_jr911 Swamp Donkey Assistant
Posted: Sun Oct 08, 2006 3:38 pm Post subject: |
get all around discs! its great!
my friend has a 72 bug, with new pads and he cant stop great, but he can.
i love my discs!
PO installed front, i installed back
back = $380 _________________ AKA Chris™
ROCKIN a ESP LTD F2E |
