winter approaches...an idea for warmth.
brooklynvan
brooklynvan is offline
PostPosted: Sun Oct 08, 2006 8:20 pm    Post subject: winter approaches...an idea for warmth. Reply with quote
I've only had my van since last Feb, but the one trip to VT last winter left my feet mighty cold in the front, while my rear passengers were just fine.
i got the thinking (and then the weather got warm) that the coolant must be a little cool by the time it makes it to the radiator and front heater core when it's 10deg out.
Today I was at Lowe's and looking at some water pipe insulation, and thought. hmmm. maybe I could zip-tie some of that onto my coolant pipes and keep some heat in for the winter.
Anyone ever tried this? good or bad results?
1990 Vanagon "Plain Jane" Bostig in the Back
TRADED: 1967 Panel for 1976 BMW 2002
SOLD: 1984 Sunroof Vanagon with EJ22
RIP 1986 Saab turbo
and my daily commuter: a Bicycle
View user's profile Send private message Visit poster's website Instagram Classifieds Feedback
scottcollins72
scottcollins72 is offline
PostPosted: Sun Oct 08, 2006 11:04 pm    Post subject: Reply with quote
Never tried it because my van's aircooled, but I am a plumber and I can tell you it works awesome for keeping water lines from freezing in underground parking lots. Get the 1" thick stuff of the correct diameter for the hoses and it should keep a bit more warmth in there. Certainly can't hurt.
crukab
Samba Chef
crukab is offline
PostPosted: Mon Oct 09, 2006 5:23 am    Post subject: Reply with quote
Are your fresh air ducts closed ?? If they don't close totally, you will get colder air up front.
Tom
Dude, you "Stone Cold looser" you lost, get over it.
My Pops:
In the yard right now:
'65 Bus/Panel/camper W/T
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon
mightyart
mightyart is offline
PostPosted: Mon Oct 09, 2006 6:52 am    Post subject: Reply with quote
You need to make sure that coolent is going through the front heater core, sometimes people block them off because of the Vanagon "hot foot syndrome".
Common home repair for this:
Valve turns off coolent to heater core, but the flaps in the heater are the real cause of the "Hot foot"
You're coolent isn't cooling that much on the way to the radiator, you have a problem with your front heater, could be clogged from someones lame attempt at fixing a leak, not uncommon.
brooklynvan
PostPosted: Mon Oct 09, 2006 7:36 pm    Post subject: Reply with quote
I'm sure the heater works.
when it's above 30 deg out i can be nice and toasty up front.
when driving around town in lower temps I'm fine too.
but when on the highway in winter it never blows warm, and my temp gauge drops way down.
might be the vents stuck open, as there was a mouse nest in one whole side that I removed in the spring, so that could have been part of the trouble.
RIP 1986 Saab turbo
Wildthings
Wildthings is offline
PostPosted: Mon Oct 09, 2006 9:38 pm    Post subject: Reply with quote
Sounds like your thermostat is not sealing well. You can get thermostats with a plastic seal that should seal better than metal on metal type. Partially closing the valve on the rear heater will also force more coolant to the front one.
danfromsyr
danfromsyr is offline
PostPosted: Tue Oct 10, 2006 6:51 am    Post subject: Reply with quote
heated seat kits are about $100/seat for the DIY, it's on my winter TODO list. DS 1st then the PS can have one..
do a google on heated seat kits. theres a few differant vendors.
Terry Kay
Banned
Terry Kay is offline
PostPosted: Tue Oct 10, 2006 8:05 am    Post subject: Reply with quote
Block off the front air intake grill.
The foam seals on the heater box door's are more than likely leaking, allowing cold air past them.
Pretty common.
I made a maroon sunbrella winter cover for the fresh ar intake behind the upper grill , and it stopped the cold air passing through the heater box door's and helps keep the front end of the Van toasty.
In the spring it ges removed.
Simple Fix---: )
T.K.
brooklynvan
PostPosted: Tue Oct 10, 2006 6:28 pm    Post subject: Reply with quote
Good call Terry.
I'll give that a shot.
RIP 1986 Saab turbo
lovedavdubs
lovedavdubs is offline
PostPosted: Tue Oct 10, 2006 7:03 pm    Post subject: Reply with quote
Hey Brooklyn why don't we just migrate with the birds Laughing
82 Air-cooled Westy (Lola)...My other vehicle is a subway.
brooklynvan
PostPosted: Tue Oct 10, 2006 7:12 pm    Post subject: Reply with quote
That's a great idea. I'd love to be nomadic. and we could drive in formation....
too bad I don't think the wife would go for it.
as much as she loves camping in the van, Brooklyn is home.
RIP 1986 Saab turbo
lovedavdubs
PostPosted: Tue Oct 10, 2006 7:15 pm    Post subject: Reply with quote
Yea mine either Rolling Eyes A guy can dream Wink
Terry Kay
Banned
PostPosted: Tue Oct 10, 2006 7:47 pm    Post subject: Reply with quote
Once you get most of the air shut down coming from the fron air intake--check this out just for grins--and it has to be pretty cold out to get the full effect---
At 60--70 mph, ust drop your left hand down towards the step in the wheel well.
Just because of the age of the weather striping arond the door's you'll actually be able to feel cold air leaking in the Van--
and for some reason especially down towards the botttom.
( not to say it isin't going to leak air anywhere else--it will.)
The only cure for this is to replace the door seals.
Phooey--a time consuming crummy job---
The best you can do for right now that's easy is the air dam up front.
Anyway---
I wanna migrate for the winter to Tahiti / Bora Bora---where's the road west?---: )
T.K.
