Installing clutch cable
frogsheath
frogsheath is offline
PostPosted: Tue Oct 10, 2006 3:55 pm    Post subject: Installing clutch cable Reply with quote
Hi Folks,
I finally got a little time to fiddle with pushing a new clutch cable through the Bowden Tube and connected it to the lever on the trans side (adjusting wing nut is on), and the pedal is connected as well- though I'm not entirely sure I put the clevis back on the right way. The play is not right. I push down and the pedal just kind of sits there instead of springing back. Anyway, I'm quitting for now and will resume in the morning. I need a manual. Any suggestions or ideas would be appreciated.
Eric
nemobuscaptain
nemobuscaptain is offline
PostPosted: Tue Oct 10, 2006 10:54 pm    Post subject: Reply with quote
Start here: http://www.vw-resource.com/cable.html
http://www.vw-resource.com/clutch_cable.html
No diagrams though.
Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
Wildthings
Wildthings is offline
PostPosted: Tue Oct 10, 2006 11:44 pm    Post subject: Reply with quote
A lot of the clutch cables you find these days are about a 1/2 inch too long. They are a pain to deal with as there is not enough thread to be able to properly tighten the cable.
namwv
namwv is offline
PostPosted: Wed Oct 11, 2006 3:27 am    Post subject: Reply with quote
Clutch return spring at tranney was broken on Olde leroy and would work but did not have enough tension to make it return petal quickly and completely. Yours may be same problem, only its sticking in place. I also cleaned up all the componets at petal assembly and greased with lithium.
79 Sunroof Bus named Olde Leroy
2.0 FI
nemobuscaptain
PostPosted: Wed Oct 11, 2006 7:47 am    Post subject: Reply with quote
I've never run into one of those. Are you sure you have the metal (stock) or plastic bowden tube?
Wildthings
PostPosted: Wed Oct 11, 2006 9:03 am    Post subject: Reply with quote
No doubt at all, laid it out next to the old one and it was 1/2 inch or more longer. Took it back and all the ones on the shelf were the same length. This was about three years ago and I heard several complaints from others at the same time.
germansupplyscott
germansupplyscott is offline
PostPosted: Wed Oct 11, 2006 9:09 am    Post subject: Reply with quote
you can use 211 721 335 E, which is the cable for a 68-71 bus, it is 15mm shorter. you also need to use the 68-71 clevis pin.
SL
frogsheath
PostPosted: Wed Oct 11, 2006 3:36 pm    Post subject: Reply with quote
Thanks everyone. I got it done. Not too bad. A lot easier than I expected, especially adjusting the wingnut. A gloved hand and a locking pliers helps. Didn't jack it up so it was pretty tight under there and it's raining today so a little messy but I'm prety much done. I'll order a few things to replace (the Bowden Tube is going -- just a few cracks in the rubber-, and the rubber boots for the pedal are pretty gone). I also kinked the cable the other day trying to jam it thru the tube. Lots of grease is what worked eventually. I straightened the kink out as much as I could while tightening the wingnut. It seems to work fine. Just like it did a few weeks back before it snapped off. Or better. Now I can get it over to my parking space off street. It's supposed to freeze tonight. No salt will touch her -- 74 Westy Dual carb camper named Betsy.
Thanks people. It's a great feeling
kookrod
kookrod is offline
PostPosted: Wed Oct 11, 2006 6:56 pm    Post subject: Reply with quote
You might get a little stretch on the new cable. So you may have to go back under the bus to give it a little more adjustment. I like to give a new clutch cable an initial adjustment. Then run it through its travel by pressing the pedal five or six times to see how it feels and to stretch the cable. Then give it a final adjustment if it needs it. Idea
nemobuscaptain
PostPosted: Thu Oct 12, 2006 9:28 am    Post subject: Reply with quote
[quote="Wildthings"]
I guess that's to offset the fact that all the accel cables I can find are about 1/2 too darn short!!!! Smile
nemobuscaptain
PostPosted: Thu Oct 12, 2006 9:31 am    Post subject: Reply with quote
Make sure you are carrying a spare, because that kinked cable won't last as long. Not saying it will break tomorrow, but eventually the stress will probably make it fail in the location of the kink.
I usually carry several spares of the clutch and accel cable.
Next time you are in there, take a close look at the clutch pedal area where the clevis is inserted and see if it is elongating. Also check the lever on the tranny. Either of those can wear out and cause problems too.
phowland48
phowland48 is offline
PostPosted: Sun Apr 11, 2021 5:21 pm    Post subject: Re: Installing clutch cable Reply with quote
I have a 1972 Bus. I installed a new clutch cable. I can't get it adjusted. I used up all of the threads and the pedal doesn't make contact until it is near the floor.
I see from the old posts that others have had this problem. What is the solution?
Please help
sjbartnik
sjbartnik is offline
PostPosted: Sun Apr 11, 2021 6:18 pm    Post subject: Re: Installing clutch cable Reply with quote
You got the wrong cable (too long)
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
timvw7476
timvw7476 is offline
PostPosted: Sun Apr 11, 2021 6:25 pm    Post subject: Re: Installing clutch cable Reply with quote
the bowden tube, black shield at the end point of the transaxle, requires 'sag'
via a washer or three, four. You get the idea. The sag at the bowden tube acts as a preload & then the clutch cable lives a nice loooooong life. No preload, you get six to seven weeks and do it again the right way.
The washers are applied at the nipple like end of the tube, which forms a droop
at the welded perch on the rear torsion tube, so there's a sag in the tube down there, once you have 3/4" or more of sag the cable should begin adjusting in proper fashion & you will have decent pedal 'feel'.
If you have no washers at the end of your bowden tube, I see a visit to the hardware store in your future. Take the bowden tube with you to get the right size.
Wildthings
PostPosted: Mon Apr 12, 2021 3:45 pm    Post subject: Re: Installing clutch cable Reply with quote
Compare the length of your old and new cable, the stretched and frayed older cable should be a bit longer.
